Old 01-12-2018, 07:17 PM   #239
86league
Drives: '13 BRZ Limited
Any idea how well these flow? Any potential issue with oil pressure with a setup like this vs. the setup Jackson Racing supplied?
Originally Posted by METAL_SU-37 View Post
So, I have a 2017 BRZ Series Yellow and I installed this radiator myself
I ran into an issue where the metal 90 of the hose ran into the stock air box, even when rotated. it also completely blocked off my oil fill cap...
I recommend this from Mishimoto
https://www.mishimoto.com/banjo-fitt...0an-black.html
86league is offline   Reply With Quote
Old 01-12-2018, 08:50 PM   #240
METAL_SU-37
METAL_SU-37's Avatar
Drives: 2017 BRZ Series.Yellow
Honestly, no idea about flow...
I know the reverse plate that I got has a port for a temperature and pressure sensor gauge. I don't have an oil pressure sensor and gauge installed yet though. where as the jackson racing one you will have to use the location on the block for one. this is one of the things
I spoke with a rep from mishimoto about the thermostatic plate. the thermostat still allows oil to flow though the filter without being warm, it just prevents the cold oil from flowing to the cooler to ease warm up cycle. though, going this route doesn't get you a oil catch plate for the filter. still need to find one for myself
I do notice that the temperatures with the thermostatic plate help warm up faster than without it. (for daily driving use, and to 180*) the total amount of oil the engine is heating up is less that that of the cooler so the temperatures level off while the t-stat starts to allow flow, once the t-stat partially opens, the temperature levels off at about 190* while the cold oil in the cooler is now introduced to the warmer oil already in the engine.
The setup works pretty well, I had to ease up on my driving on i-70 in a stock configuration driving up the mountains as I have seen without the cooler, about 260*F driving.... sketchy. Now the Highest I have seen now with the cooler is 220..? rarely gets that high
Good thing about this radiator combo is it's very hidden, stock look.
bad thing, install is a difficult. i thought it would take me about 4 hours, took me 8... albeit i had distractions... and food... and well you know.
METAL_SU-37 is offline   Reply With Quote
Old 01-20-2018, 07:00 PM   #241
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Will this fit an AVO turbo setup with stock airbox? More curious if the intercooler piping will be an issue.
tyler_win_photo is offline   Reply With Quote
Old 01-21-2018, 09:19 PM   #242
Sundawg
Drives: SWP BRZ Premium
It's possible with some modification. The stock layout runs one of the lines right into the intercooler pipe. Rotating the line causes it to interfere with the air box. I used a Mishimoto plate (similar to METAL_SU-37) and one banjo bolt to rotate the line and clear the filter The other side uses a straight fitting and the original JR 90 connection.
Sundawg is offline   Reply With Quote
Old 01-22-2018, 12:14 PM   #243
toast
Drives: 14 BSP Edelbrock BRZ
After I bought the Banjo bolts and thermostatic plate from Mishimoto
much cleaner, thermostatically controlled, and clearance to actually open the air box and remove a filter.
If you are going to run a thermostatic sandwich you are defeating one of the major points of this unit, which is to have the coolant stabilize the oil temp and bring it up to operating temps faster. You could have saved ~500 and just run a separate oil cooler at this point.
toast is offline   Reply With Quote
Old 01-22-2018, 07:00 PM   #244
Misfire
Misfire's Avatar
Drives: 2017 Series.Yellow, 2005 LGT wagon
I was going to mention this too. Coolant heats up faster than the oil will, which would in turn heat up the oil in the cooler faster. The thermostat will negate the JR unit's ability to do that, and will cause the oil to heat up as if it were stock. Also, I believe he had the JR unit before the Mishimoto bits. The Mishimoto bits were to prevent the oil lines from crashing into the 2017 airbox. Mishimoto does sell a plate without the thermostat.
Misfire is offline   Reply With Quote
Old 01-22-2018, 07:21 PM   #245
Grady
Grady's Avatar
You may want to check with Jackson Racing. My understanding there is a clearance issue with the AVO intercooler and this thicker radiator.
Old 01-22-2018, 08:58 PM   #246
tyler_win_photo
Do you happen to have a photo of your setup?
Old 01-23-2018, 11:36 AM   #247
toast
That was my point. If you need the connectors for space that's fine but don't get the thermostat plate.
Old 01-29-2018, 01:40 PM   #248
METAL_SU-37
I thought so too, but as I daily drive 35 miles of highway, oil temps actually raised slower with the radiator combo than without it. about 15-20 miles for oil temps to be reasonable.... was not pleased when I found that out but it makes sense. Whatever heat goes into the oil is sucked out by the coolant. even still, not only are you trying to heat up an additional quart of oil, but it's always flowing thru the cooler. so any amount of airflow thru the radiator combo will add to the cooling effect.
The reason I bought the Thermostatic plate instead of just a plate is because with the oil temps remaining cold for a good 15 miles after driving, the highest I ever saw was 170..... thermostatic plate makes sure my temps are closer to the recommended 230 from the factory that's all. which it does its job beautifully for what I want.
I agree a little bit I think a separate oil cooler would have been better, for the sake of oil coolers alone, however this tackles 2 things, a larger radiator and an oil cooler, as one. keeps a stock look too...
additional comment:
I don't think that the thermostatic plate is a waste of money, 160 for the t-plate versus 85 for a short plate to work with the banjo bolts, however I am now getting quicker oil warm up as cool oil isn't being chilled by the radiator combo while warming up, I actually warm up around 10 miles sooner with the thermostatic plate than without it. plus it maintains a better operating temperature closer to manufacture recommendations.
I don't think the radiator combo is a waste compared to just a separate oil cooler because it has 2 functions, thicker radiator for more cooling, and oil cooler with stock look, win in my book
if your worried about saving money, don't mod in the first place. but look at people who buy the cosworth supercharger kit for $7k and only gain 80 hp..... there are gems hidden in the mod community for these cars, and I think these 2 mods work beautifully for what I need. just throwing in my experiences to help aid people thinking about buying this combo.
2017 Subaru BRZ Series.Yellow
Yellow 013
RM 86 Cup
NASA RM TT5
SCCA TT
Old 01-29-2018, 04:50 PM   #249
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
I think the thing we have to keep in mind here is that the antifreeze coolant is on a thermostat, and the coolant in the radiator does not start flowing through the engine until it has come up to temperature and opened the thermostat, so this radiator/cooler combo part is not going to do much to warm up the oil on cold start.
killboy is offline   Reply With Quote
The Following 3 Users Say Thank You to killboy For This Useful Post:
gtengr (01-29-2018), Hades (01-30-2018), venturaII (01-30-2018)
Old 01-29-2018, 06:50 PM   #250
METAL_SU-37
Great explanation!
Can't thank the post yet because I guess I haven't posted enough
Yellow 013
RM 86 Cup
NASA RM TT5
SCCA TT
The Following User Says Thank You to METAL_SU-37 For This Useful Post:
killboy (02-20-2018)
Old 01-30-2018, 11:24 AM   #251
Colombo
Drives: '13 BRZ
I have fit it in my car. I ended up shaving the back side corner of the air box and attached a flat piece of plastic to cover the hole. It’s not pretty but it is a solid solution. Also, clearance is still extremely tight.
Sent from my iPhone using Tapatalk Pro
Colombo is offline   Reply With Quote
Old 01-30-2018, 01:28 PM   #252
Hades
Hades's Avatar
Drives: 2013 Scion FRS
So, from what I've read here, this dual radiator/oil cooler should
1) Warm oil up slower than stock
2) Warm oil up faster than oil cooler w/o thermo plate
3) Warm oil up slower than oil cooler w/ thermo plate
Question is, is just this dual radiator/oil cooler adequate for daily driving? Sounds like anything under 20 miles and the oil won't be warm enough, which is no bueno.
Hades is offline   Reply With Quote
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
