#1289 |
Drives: toyota gt86 1st edition
the bolt you are referring is this?
#1290 |
Drives: 2013 satin white brz limited
#1291 |
i'll try to slide in the overpipe wiggling it...
one big problem is... i'm alone doing this |
#1292 |
#1293 |
Drives: 2014 GT86
maicolp: imho you'll have much harder and longer to work if you'll do w/o engine rising, especially, if you are only one doing it.
But should rising engine be that hard? Just put some stand below engine by pan, undo mounts .. and lower car a bit .
#1294 | |
I am disappoint.
#1295 |
Drives: '14 981CS, '99 NB1
| The Following User Says Thank You to johan For This Useful Post: | Ultramaroon (01-22-2018) |
#1296 |
Drives: 2015 BRZ Limited
Delicious finished my Ace 350, Ace FP, Touring 86 tune today!
Overall I really like it. Zach was telling me my setup was making a bit less power than other's with the ACE setup, but it's still amazing. Highly recommend. I'm putting the car on a dyno Saturday, and will post the before and after charts when I get them.
Harrop Supercharger | Delicious Tuning Flex Fuel Kit | ACE Type-A 350 Header + OP | CSG Touring 86 Catback | RacerX Fabrication Catch Can | Jackson Racing Dual Radiator/Oil Cooler | Tuned by Zach from CSG
| The Following 3 Users Say Thank You to FunnyGopher For This Useful Post: |
#1297 |
Drives: Subaru BRZ
I see that the 150 pushes more HP on the top end at the expense of low end torque, but how bad is it really on the streets? noticeable vs 350?
#1298 | |
![]() Travis, the owner of the dyno, was telling me his reads a bit lower than most. For reference though, here's a comparison of a friend of mine who ran right before me, running with the typical UEL, decatted exhaust, and e54 tune. I'm still on 91. ![]() ![]() He made more than I did, but not by much. I'm starting to think my next upgrade will be a flex kit.
| The Following 5 Users Say Thank You to FunnyGopher For This Useful Post: | CSG Mike (01-27-2018), gtengr (01-27-2018), new2subaru (01-28-2018), Pat (01-28-2018), Williampreza (01-28-2018) |
#1299 |
Drives: 2013 frs red
That's a nice chart. Congrats!
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | FunnyGopher (01-28-2018) |
#1300 |
At the risk of being flamed, do you think it might do better with stock intake and throttle body?
#1301 | |
Drives: 2013 FR-S Argento
What the heck was going on with the top end of your "before" curve, the drop off on the top end makes me thing something was wrong with whatever setup you had before. Even a stock header & tune should not drop off like that. |
#1302 |
Might be where he let off.
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
