#198 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
Anticipate any oil drain issues with the low-mounted turbo, or is it not THAT low.
#199 |
Drives: turbo scion tc
He said that he is going to use a scavenge pump so yea no oil return issues
#200 |
Pegasus White
Drives: 86
I need more pictures!!
![]() Can't wait awww sounds like the best thing ever!!
Driving: Pegasus White Manual GTS 86.
#202 |
Would Definately have issues being gravity drained. These pumps we use nowadays are pretty stable. Used alot of this pump on project cars in and out of the shop and haven't had any issues.
-Don |
#203 |
Drives: 2013 BRZ Limited
subscribed.
#204 |
Final redesign of the IC piping routing.
2" Primary into IC 2.5" out into 3" TB
| The Following 12 Users Say Thank You to Don@Accelerated For This Useful Post: | Bonburner (07-09-2012), Chewie4299 (07-13-2012), ChrisOkc8 (07-09-2012), civicdrivr (07-09-2012), colHolm (07-08-2012), Guff (07-12-2012), kidgogeta (07-08-2012), Spaceywilly (07-08-2012), Starscream15 (07-08-2012), SVTSHC (07-18-2012), Turbowned (07-10-2012), wcbjr (07-09-2012) |
#205 | |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
I see in the picture that there are two none attached sections, are you planning on using hump couplers to allow flex? |
#206 |
El Presidente
Drives: it like I stole it!
#207 |
Drives: DGM BRZ limited
Looks good, I'm in for more pics.
What were your reasons for the 2" piping? Is there enough room for 2.5/3 the way you routed it? |
#208 |
Drives: 13 GTI
#209 |
Also, what does the hot side look like?
#210 |
Could certainly go larger. 2.5 and 3 is doable, however, There would be no gain to even stray from 2". The bump to 2.5" is more than sufficient plus 500hp.
| Accelerated Performance 2013 BRZ Intake Dyno Testing Video | Don@Accelerated | Engine, Exhaust, Transmission | 109 | 05-17-2013 11:24 AM |
| Accelerated Performance 2013 BRZ Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 135 | 09-03-2012 11:24 PM |
| Accelerated Performance 2013 BRZ/FRS Exhaust Systems | Don@Accelerated | Engine, Exhaust, Bolt-Ons | 24 | 07-07-2012 07:05 AM |
| Hello from Accelerated Performance! | Don@Accelerated | Announcements, Contests, Giveaways | 5 | 07-04-2012 08:14 PM |
