Old 01-19-2018, 11:35 PM   #1
NoobBRZ
Drives: Blue brz
Overpipe troubles
So I bought an entire exhaust system... headerback consisting of Tomei UEL and invidia overpipe front pipe and catback
Now I took off the stock catback and front pipe but I am really struggling to take the heat shield off the overpipe. Not only are the bolts rusted but I can’t get enough leverage and I don’t have air tools. I’m wondering if you guys have any tips or suggestions?
Also if anyone bought the invidia front pipe, is it me or does the gasket that goes between the front pipe and midpipe section of the catback seem to small?
Sorry for being such a noob... I’m using this car to learn how to work on cars lol
NoobBRZ is offline   Reply With Quote
Old 01-19-2018, 11:54 PM   #2
gtengr
Drives: 2017 BRZ
Have you tried spraying the bolts with PB Blaster and letting it soak?
If the heat shield is too much of a PITA, you can always loosen the motor mounts and trans mount and jack the engine to remove the overpipe in one piece. It'll take a little longer but not a big deal imo.
gtengr is offline   Reply With Quote
Old 01-20-2018, 12:10 AM   #3
NoobBRZ
Drives: Blue brz
Yea I have and I’m going to try that motor mount loosening method. Can you tell me where I can find the motor mounts?
Old 01-20-2018, 12:25 AM   #4
gtengr
Drives: 2017 BRZ
They attach to the front subframe. Check out google images for pictures. Remove the nut on those, then unbolt the trans mount, then use a flat piece of wood to jack the engine by the oil pan enough to wiggle the overpipe out.
Old 01-20-2018, 12:30 AM   #5
NoobBRZ
Drives: Blue brz
Sweet thanks man and I’m guessing the nut size is like a 12 or 14 mm right?
Old 01-20-2018, 03:55 PM   #6
S. Snake
S. Snake's Avatar
Drives: 13' Asphalt
Before I bought air tools and when I lived in the rust belt I bought myself a MAPP gas torch (about $30 from home depot) and when I used that after letting bolts or nuts soaked overnight in pb blaster that usually did the trick. Also a piece of pipe or a short breaker bar could also help. Good luck
Sent from my SM-G930V using Tapatalk
"always forward" >>>>>>>>>>>
S. Snake is offline   Reply With Quote
The Following User Says Thank You to S. Snake For This Useful Post:
humfrz (01-21-2018)
Old 01-20-2018, 10:43 PM   #7
NRXRaptor
I loosened the passenger side engine mount and jacked the engine up a few inches. Big success for me
NRXRaptor is offline   Reply With Quote
Old 01-21-2018, 01:02 AM   #8
.....yep, nutten like the old blow torch ......
S. Snake (01-21-2018)
Old 01-21-2018, 10:59 PM   #9
NoobBRZ
Drives: Blue brz
I’d like to thank all for the advice and tips I finally got the overpipe out and installed my
Headerback exhaust with no prior experience.... the car sounds amazing and I feel even better and extremely proud!
The Following User Says Thank You to NoobBRZ For This Useful Post:
gtengr (01-21-2018)
Having troubles starting car Tomahawk Southern California 0 01-31-2016 04:13 PM
Having some troubles with OFT. Vroomin86 Software Tuning 15 06-01-2015 06:54 PM
Helmet troubles... Sonolin Tracking / Autocross / HPDE / Drifting 1 10-11-2013 07:10 PM
Lug nut troubles Krait1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-14-2013 12:46 AM
Dealer Troubles shawnperolis Scion FR-S / Toyota 86 GT86 General Forum 39 02-23-2013 02:42 AM
