View Poll Results: Do you have chirping (cricket) noise during idle once the car is warmed up?
Yes (Please only vote after you have 300 miles or more on the odometer) 3,101 85.22%
No (Please only vote after you have 300 miles or more on the odometer) 538 14.78%
Voters: 3639. You may not vote on this poll
Old 07-08-2012, 05:59 PM   #155
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
Originally Posted by fistpoint View Post
Or Subaru's inability to design the part with other gasoline types in minds.
The fuel system is toyota btw.
Hanzo is offline   Reply With Quote
Old 07-08-2012, 08:28 PM   #156
dnL
Drives: Ultramarine FR-S
I sat in a lush green area at a complete standstill today. The cricket chirping was perfect for making the car one with nature. Gave the plants a nice soundtrack to go along with the rustling of the leaves. This is the greenest car I've ever driven and plan to drive. All them Priuses are just posers. Good job, Toyobaru!
dnL is offline   Reply With Quote
The Following 2 Users Say Thank You to dnL For This Useful Post:
Jayde (07-08-2012), Sportsguy83 (07-08-2012)
Old 07-08-2012, 10:05 PM   #157
Indestruct
Drives: 2013 SWP Limited BRZ, MT
I put in a service request w/my dealer to investigate and complain about the many issues I'm experiencing with this car. I recommend everyone do the same as well.
Here is what I wrote to them:
Traffic on Nav Not working. Engine has a high frequency Squeal/Chirp. Car has rough idle (idle will fall to 400-500 rpms frequently and shake the car). Fix Rattle coming from trunk area. See if any codes were pulled from a slow start.
Indestruct is offline   Reply With Quote
Old 07-08-2012, 11:03 PM   #158
fistpoint
Drives: Supercharged Golf Cart
Oops, forgot about that. One of the few things Toyo did...
Don't feel isolated, those are the same issues nearly all of them are having so you are not alone and it should be well known to all the dealers by now.
As for the rattle, you must find it before you bring it in otherwise they'll do nothing or tear the car apart searching for it. It's always best to discover the exact source and location of rattles beforehand. Don't ask, tell instead.
fistpoint is offline   Reply With Quote
Old 07-09-2012, 12:45 AM   #159
sierra
Drives: Skoda Yeti DSG diesel 4x4
As posted on another thread but this topic has spread so it's not getting through. This sounds the real deal below and if it is, a splash of 2 stroke oil, high quality, in the tank should prove the point. Say 100ml just before filling up for 1:500 in the 50L tank, so it's just a light dose of lubrication simlilar to what the Japanese fuel might have? Not 1:40 or anything like that. Hopefully that will almost instantly shut the dry washer up unless it's too stuffed?
If this is the problem they will have to modify the HP fuel pump to cope with the US quality fuel.
I'll leave you guys to work in out in the measures you use over there.
It's just to prove a point and hopefully shut it up until they bring out the fix.
http://www.fr-sforum.com/forums/fr-s...-problems.html
FRS direct injection fule pump problems.
Just wanted to give you all a heads up. I had to replace this pump today due to the fact it was making a loud chriping noise almost like a wet drive belt. The toyota reps came out to my work and listened to it. It only happens once the temp gets to around 140f. They explained it to me as follows. The pump has a washer inside of it which if not lubercated properly it will make that noise. They said that Japan gas is way better and has more lub in it the USA gas. SO the usa gas casued the washer to not be lubed properly. There is no known fix or TSB for this. i got a new pump but keep your ears open so you can catch it and report it. Its not a preformance issue jsut an annoying sound thats all. Hope this helps.
sierra is offline   Reply With Quote
The Following 2 Users Say Thank You to sierra For This Useful Post:
Bonburner (07-09-2012), Jayde (07-09-2012)
Old 07-09-2012, 12:49 AM   #160
excited86
Drives: none
from what you said, then we are all screwed. WE cannot just import jp fuel for the fr-s.
We are just gonna have to cover our ears, until, they figure out how to lub washer?
excited86 is offline   Reply With Quote
Old 07-09-2012, 12:55 AM   #161
Razz
Razz's Avatar
Drives: Fast
So you have to add pre-mix just like the Rotory engines.
Oh well...
That's just too bad, as no other manufacturer can make a fuel pump with out chirping.
Razz is offline   Reply With Quote
Old 07-09-2012, 12:57 AM   #162
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Intriguing.... Mine's pretty loud. I'd love to do something to silence it but I don't know how even a little 2-stroke oil would effect other aspects of the fuel system/engine.
It may be harmless but without knowing I'm not comfortable.
Chewie4299 is offline   Reply With Quote
Old 07-09-2012, 01:19 AM   #163
Indestruct
This is ridiculous, so we're all screwed basically? How hard is it to get a fuel pump that actually works...
Old 07-09-2012, 01:20 AM   #164
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Is this just annoying or is a symptom of impending failure? I imagine something that needs better lubrication (like that from JDM fuel) and doesn't receive it the results would be eventual failure. That's my concern.
If there's a little "chirp" at idle but the pump can last for 300k, I wouldn't worry too much. However, if the "chirp" means my fuel pump could fail at 20k when I'm in between Seattle and Spokane then yeah.. I want that remedied asap!
Old 07-09-2012, 01:25 AM   #165
Marrk
Drives: Honda Fit
Does anybody know for a fact that there is any significant difference between JDM fuel standards and USD fuel standards?
Marrk is offline   Reply With Quote
Old 07-09-2012, 01:32 AM   #166
excited86
Drives: none
This fuel type difference does not make sense. How can 20% of the people reported no issue? Did they use octane 94? How can we get ourselves into the 20%?
The Following User Says Thank You to excited86 For This Useful Post:
Marrk (07-09-2012)
Old 07-09-2012, 01:49 AM   #167
sierra
I have a GTS 86 on order but have been driving a Mitsubishi Triton single cab with a 2.5 common rail direct injection turbo diesel for the last 3 years. The low sulphur content diesel lacks the lubrication it used to and the pumps have had to be designed with that in mind.
To be safe I have added 2 stroke oil at 1:200 since it was new with the only side effects being a quieter engine, and slightly better fuel economy.
2T is designed to disperse in gasoline, provide lubrication and burn cleanly.
What is the lubrication in the Japanese fuel that 'some?' of yours lacks?
Personally I would give it a go as being the best choice until they fix the problem but I can understand others hesitating but then I have a technical background. Think of all the other additives that people throw in the tank without really having a clue what they are?
Old 07-09-2012, 02:05 AM   #168
excited86
Drives: none
From reviewing post in this thread, this issue seems to be unique in usa. It could also be that there are a lot of frs in usa.
In general, there is no issue for people in canada using high grade fuel, ie 94 octane.
Can people confirm if this is true?
Is this idle noise normal? robo_robb Engine, Exhaust, Transmission 288 01-25-2022 09:40 AM
Squeak noise from engine. Fish Scion FR-S / Toyota 86 GT86 General Forum 52 05-08-2014 01:06 PM
Video of chirping at idle Julio86 Engine, Exhaust, Transmission 15 02-01-2013 10:37 AM
Starting to get worried - Engine noise Laika BRZ First-Gen (2012+) — General Topics 49 07-02-2012 03:45 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
