Old 01-16-2018, 09:07 PM   #1
Launcher
Drives: Subaru BRZ Limited 2013
Custom Hood vs Hood Duct
Opinions on the difference between hood duct and custom hood with built in hood duct type.
I was looking at the TS- Style Siebon
http://seiboncarbon.com/tsii-style-c...ubaru-brz.html
Currently in stock
I would need to buy that, have someone paint it black OEM color for my Subaru BRZ so could see it adding up cost fast but if it is worth it and makes a difference in look compared to the hood duct I would be fine with it.
I have never had a custom hood or hood duct on a car so curious on that as well. I see several hood ducts that I assume a car shop could just add to my current hood?
Something like the following:
https://shop.namelessperformance.com...d-duct-system/
Thoughts and main differences between the two or am I way off?
Leaning towards the Siebon TS-Style hood but want to make sure when I buy it I can get someone to pain the carbon fiber and fitted and have no issues.
Launcher is offline   Reply With Quote
Old 01-16-2018, 11:37 PM   #2
Well, Launcher, I must ask ....... why do you want either one ..... ??
* to make the hood lighter ..??
* to allow hot air to escape the engine compartment .. ??
* to look cool ..... cause CF ..??
* other
humfrz is online now   Reply With Quote
ls1ac (01-17-2018)
Old 01-17-2018, 12:15 AM   #3
StraightOuttaCanadaEh
Wes
From an aesthetic standpoint, I would go for the carbon variety, paint it, and leave the carbon louvres unpainted. Then again, it's always form>function for me. My two cents
Instagram: @gt86ws
Old 01-17-2018, 07:11 AM   #4
NRXRaptor
If you are going to paint a carbon fiber hood it defeats the purpose to me. From what I know most consumer level carbon fiber bits are carbon fiber molded/stuck onto a hood shaped piece of fiberglass. My 2 cents
NRXRaptor is offline   Reply With Quote
Old 01-17-2018, 10:27 AM   #5
daskaman
Drives: Burz
Factory hood is surprisingly light for what it is.
Unless you have other reasons for wanting to switch, or just a different look.
daskaman is offline   Reply With Quote
Old 01-17-2018, 05:34 PM   #6
Leonardo
Country Boy 4 Life
Leonardo's Avatar
These look cool! About half the price of a hood.
via Imgflip Meme Generator
There are more options... Some that look sleeker...
My $0.02 I live in Oregon. My louvered hood let water sit on my engine and corroded the aluminum parts which made them look terrible. (different car)
I LIKE TIRES!
norcalpb (01-18-2018)
Old 01-17-2018, 06:45 PM   #7
Pat
Pat's Avatar
Drives: 2023 BRZ
Defeats the purpose? What is the purpose?
The Following User Says Thank You to Pat For This Useful Post:
Sapphireho (01-17-2018)
Old 01-17-2018, 07:20 PM   #8
gtengr
Drives: 2017 BRZ
Has anyone drilled holes in the windshield cowl? Seems like it would be a good stealth way to vent the engine compartment.
gtengr is offline   Reply With Quote
Old 01-17-2018, 07:26 PM   #9
Leonardo
Country Boy 4 Life
Leonardo's Avatar
[ame="https://www.youtube.com/watch?v=G3ja6Hn8ps4"]https://www.youtube.com/watch?v=G3ja6Hn8ps4[/ame]
I LIKE TIRES!
Raven86Project (01-18-2018)
Old 01-17-2018, 07:57 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
The cowl is not a low pressure zone. That would provide no benefit. Often what "seems like" would work does not. This is especially true with aerodynamics.
plucas (01-19-2018)
Old 01-17-2018, 09:33 PM   #11
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
This is actually a high pressure area. Ever hear of "Cowl Induction"?
I bought this Mustang hood vent off e-bay for 90 bucks.
Lunatic is offline   Reply With Quote
The Following User Says Thank You to Lunatic For This Useful Post:
Leonardo (01-17-2018)
Old 01-17-2018, 09:43 PM   #12
gtengr
Drives: 2017 BRZ
The cowl piece is shielded from airflow, so I think that's debatable. I think it's likely a low pressure area exists in the airflow void where the vents would be. Also need to consider there is an underhood pressure component, and the underhood air is hotter. Seems you should know that once you cut a vent into something that the pressure zones can easily change and need to be reanalyzed.
Old 01-17-2018, 10:01 PM   #13
gtengr
Drives: 2017 BRZ
Yes, but they project upwards from the rear hoodline and towards the windshield to ensure the rear opening gets into the high pressure zone, and this is typically done to cars that aren't as streamlined and have an abrupt hood to windshield transition that helps to more clearly create a high pressure area. I'm not saying it would positively work, but I don't think it can be so simply dismissed.
Old 01-17-2018, 10:31 PM   #14
gtengr
Drives: 2017 BRZ
Here's an example of what I'm thinking about using the 2019 ZR1. Ignore for a second that its hood vent caused a dramatic change to the high pressure zone in the center of the windshield. Just look at the area I zoomed in on and notice how the high pressure area on the windshield ends at roughly the height of the back of the hood, and what's under that point is low pressure.
HELP: hood pins/latches on carbon fiber hood scubie.brz Cosmetic Modification (Interior/Exterior/Lighting) 1 05-13-2016 01:10 PM
Custom GT 300 hood vents/heat managment kuczynskika Cosmetic Modification (Interior/Exterior/Lighting) 7 10-21-2015 01:00 PM
Florida: Trade Silver hood for Black hood 555 Exterior Parts (Aero, Lighting, Etc.) 0 05-06-2015 11:52 AM
