| Other Vehicles & General Automotive Discussions Discuss all other cars and automotive news here. |
Drives: 01 Echo, 01 prelude, 99 civic
I know this isn't exactly the right place, but I cannot find an answer for the life of me!!
I bought a 02 echo with a MT. Ad stated it needed a new trans, that a clutch was put in about 6 months ago... Jacked up the front, started, put in gear, wheels turn, seems fine? Road test: Start in 1st gear, everything seems fine. Shift to second, going about 20mph... SCREEEEEEECH. Both front wheels lock up like you tried your best to put the brake pedal through the floor!!!! Engine stayed alive as I pressed in the clutch asap... Tried to move in 1st, wheels are locked. Friend with a truck pulls the car a few feet... Car is free to move now, but does the same thing again in 1st gear SCREEEECH. I'm assuming this is a catastrophic transmission failure? Thing is, I can't find anyone, with any kind of car via google that this has ever happened to. It's relatively hard to source a reasonable priced echo MT. So... Before I go buying a new trans, any suggestions? Input? Comments, smart remarks? Thanks for the help!!! Last edited by zooandbio4me; 01-15-2018 at 03:41 PM. Reason: Email notification |
#2 |
Drives: frs
Civic... triggered
| The Following 3 Users Say Thank You to Teseo For This Useful Post: |
#3 |
LMGTFY
Drives: 13 FRS, 91 Miata
Find another trans or another car.
The trans is toast. |
| The Following 2 Users Say Thank You to x808drifter For This Useful Post: | Cole (01-15-2018), JazzleSAURUS (01-15-2018) |
#4 |
[insert cool phrase here]
Drives: BRZ Premium
Well, nothing more I can say than it's the tranny.
Pretty much the only way to know for sure is to take out the tranny and open her up. At that point your pretty much halfway done.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | Cole (01-15-2018) |
#5 |
Only users lose drugs.
Drives: All the time
Boneyard transmission for an Echo can't be that expensive..?
EDIT: curiosity got the best of me so I did a little searching and it looks like $500 is an average price for a used transmission. Hope you have tools.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | Cole (01-15-2018) |
#6 |
Drives: BRZ SWP Limited -6MT
any chance the guys on the nissan z forum were of any help? or maybe the hummer forum.
you win the award of most random question thus far this year! the prize crew is coming by in a creepy van |
| The Following 2 Users Say Thank You to bababooey For This Useful Post: | Captain Snooze (01-18-2018), JoeC (01-19-2018) |
#7 |
Drives: 2017 BRZ
sounds like the ad was accurate
| The Following User Says Thank You to gtengr For This Useful Post: | Summerwolf (01-15-2018) |
#8 | |
![]() Yep, it does sound like your transmission is messed up. I figure the cost of a transmission plus labor to install it, would be more than the car is worth. I'd suggest you give it away or junk it. Time to let er go. ![]() humfrz |
#9 |
Drives: 2013 WRB BRZ 6MT
Check your local scrap yards and be prepared to put some elbow grease into it if you don't want to pay a fortune in labour.
| The Following User Says Thank You to Lynxis For This Useful Post: | Cole (01-15-2018) |
#10 |
Drives: 2017 BRZ
Engine swap a 2.0L boxer engine and matching transmission into it. You can probably find someone around here to sell you one.
#11 |
The echo and the early Tercels used the same trans. With that, you could probably use your echo trans bellhousing and bolt it to a c56 which should be more plentiful. Not sure on axles or the far upper trans mount. I say probably because I've done the other way in using a C56 bellhousing to the tercel trans to put a 1zz into a tercel. Beer and boredom make dumb things happen.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily 2013 BRZ limited - new toy |
#12 | |
Only happy when it rains.
Drives: series.blue
op should check yarisworld. It is a shell of its former self, but there are still some good people that check in every so often. |
#13 |
Panda Trueno
Drives: No twin now.
Have you double checked the clutch install? I doubt that would be it after your description but I had a vehicle before that would lock the clutch up after it got hot and you could break it free forcefully or let it cool down. Cold and in neutral it would roll back and forth without issue.
#14 |
Thanks for all of the posts guys! Posted in an echo forum somewhere and got crickets!! I've been a mechanic most of my life, bought the car for $100 with intentions of flipping it.
Does anyone know for sure if I can just take any c150 trans (Yaris, paseo, Tercel etc) and swap the bell housing? Are the axle splines going to be the same? I've found a pulled, tested and good echo trans for around $420 shipped but there are plenty of Tercels and a few paseos maybe one Yaris in a local yard... Thanks again guys!! Sent from my Moto Z (2) using Tapatalk |
| Tags |
| echo, manual, transmission |
| Amazon echo dot Alexa in BRZ [video] | edigeek | DIY (Do-It-Yourself) Guides | 7 | 06-23-2017 08:48 AM |
| My nightmare with my BRZ is over!! | Slade | BRZ First-Gen (2012+) — General Topics | 17 | 09-08-2015 08:15 PM |
| 2005 Echo Hatchback | Frost | Other Vehicles & General Automotive Discussions | 0 | 12-23-2013 09:13 AM |
| Pioneer X9310BT Echo | 01s0uljah | Electronics | Audio | NAV | Infotainment | 2 | 01-24-2013 05:54 PM |
| Car nightmare | ichitaka05 | Other Vehicles & General Automotive Discussions | 30 | 09-11-2011 01:23 AM |
