#38543 |
Famous Potatoes
Drives: '15 ultramarine
#38544 |
Not a troll
#38545 |
Just the tip
Drives: 2017 DGM BRZ
Dealershit wants $430 + the cost of oil to do my 12month/20k service.
LOL. Yeah I think I'll keep my money and buy some lowering springs, my own oil, and several cases of beer. What a joke. |
#38546 | |
Famous Potatoes
What exactly where they going to do other than change the oil and maybe rotate the tires? That sounds crazy. |
#38547 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Garbage day here is Wed.
In honor of x-mas and new yr the removal company offset garbage day one day later for both weeks. Wandering around bumping into walls and doors now. Guess it's Stormday today. Likely to have the power out for a few hours.
"I gotta rock." -- Charley Brown |
#38548 | |
![]() humfrz |
#38549 | |
![]() humfrz |
#38550 | |
Just the tip
Replace engine oil and filter Remove, inspect and service front and rear brakes Service battery Test coolant, inspect hoses and clamps Lubricate all latches, hinges and locks Check under body for damage Inspect air filter, replace if necessary Inspect all steering and suspension components Inspect and adjust all fluid levels Inspect and adjust drive belt tension Inspect and adjust rear differential gear oil Inspect axle boot condition Inspect cabin air filter, replace if necessary Inspect clutch operation (if applicable) Inspect operation of all lights, wipers and washers Inspect parking brake Inspect tire condition and adjust tire pressures, including spare tire Road test Rotate tires Already did my cabin filter and intake filter myself. The only thing I wouldn't know how to do is check the drive belt tension and differential oil... and I'm not even sure that's necessary at this point. The 6 month one was quoted very expensive too, albeit with less "inspections". $130+ cost of oil. Did not partake. |
| The Following User Says Thank You to wolffbite For This Useful Post: | Tcoat (01-11-2018) |
#38551 | |
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | wolffbite (01-11-2018) |
#38552 | |
Famous Potatoes
So basically 30 minutes labor. Rip-off! |
#38553 | |
Drives: 2017 BRZ
1-8 on fingers. Second set adds one thumb. Third set adds the other thumb. I'm not trying to design a system that lets humans count to the highest possible number using just the digits on their hands; I'm balancing just how stupid a human can be and still use it reasonably consistently. Plus 8 makes some vague mathematical sense, being 2^3. not that any of this matters.
#38554 | |
Famous Potatoes
Yep. Going to go a little smaller than a ranch. My only requirements for our retirement house is at least a 3 car garage, RV storage for my boat, and a large heated shop. After that, whatever Mrs. S-ho wants is ok with me. |
#38555 | |
Also depends on if they actually do the whole brake service and don't just slap some lube on the sliders and call it a day. I don't mind paying for service where actual work is done but that is a shitload of money for "inspecting" stuff.
| The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (01-11-2018) |
#38556 | |
Well within your price range ........ just outside of Boise ....... https://www.zillow.com/homes/for_sal...t/8_zm/0_mmm/? humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Sapphireho (01-11-2018) |
| Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
| Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
| Random Rubber Part | OoLong | BRZ First-Gen (2012+) — General Topics | 8 | 01-28-2014 10:31 AM |
| Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
