Old 01-11-2018, 03:30 AM   #18187
Roth
Roth's Avatar
Drives: 2013 Gt86
Just took my '13 gt86 to the dealer to replace the driver door window, that was badly scratched. Warranty repair even though the car is almost 5years old
I'll get it back after job
Roth is offline   Reply With Quote
Old 01-11-2018, 01:21 PM   #18188
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
Realized some punk keyed the passenger side of my car, from the mirror to the top of the rear wheel. Paint chipped at the gap beween the door and quarterpanel. Luckily none of the panels bent.
[ame="https://www.youtube.com/watch?v=VO48Vr4KIc8"]My sentiment[/ame]
mrderp is offline   Reply With Quote
The Following User Says Thank You to mrderp For This Useful Post:
Adam_L (01-15-2018)
Old 01-13-2018, 06:38 PM   #18189
Young_makaveli
Young_makaveli's Avatar
Drives: 2013 frs
Hi guys didn't want to make a new thread for this simple question
Was checking under the hood today only to realise that one of my pulleys is wobbling .. is this normal and if not how do I fix it?
Sent from my SM-N950W using Tapatalk
Young_makaveli is offline   Reply With Quote
Old 01-13-2018, 07:14 PM   #18190
Impureclient
Drives: 2015 FR-S
No problems there, that's normal.
The Following User Says Thank You to Impureclient For This Useful Post:
Young_makaveli (01-13-2018)
Old 01-13-2018, 07:18 PM   #18191
new2subaru
Weight Weenie
Drives: 15 FR-S
As said above, normal. That's the belt tensioner at work.
The Following User Says Thank You to new2subaru For This Useful Post:
Old 01-13-2018, 07:37 PM   #18192
Young_makaveli
Drives: 2013 frs
Thanks for the reply guys !
Does yours wobble like in my video? It's my first time noticing this that's why
At first I thought it was an idler pulley but if it's a tensioner I guess that makes sense for it to have some sort of play
Good to know it's normal 😁
Old 01-13-2018, 07:47 PM   #18193
Impureclient
Drives: 2015 FR-S
Just started up to see exactly how much it moved and without using a light like you did, it's hard to say.
It seems like a little less, like if yours is moving 1/16" back and forth, then mine looks like 1/32".
You have a bright light on yours so it could be just seeing it lit up amplifies the visual movement some.
Nothing to adjust since it's adjusts it self. Good to go!
Old 01-13-2018, 07:50 PM   #18194
Young_makaveli
Drives: 2013 frs
Thanks man I'll just leave it as it is
Appreciate your input 😁👍👍
The Following User Says Thank You to Young_makaveli For This Useful Post:
Impureclient (01-13-2018)
Old 01-14-2018, 09:15 PM   #18195
ERA
Drives: .
Drove it with a buddy from work through the mountains! A picture before we took off!
ERA is offline   Reply With Quote
The Following User Says Thank You to ERA For This Useful Post:
HachiRokuX (01-29-2018)
Old 01-15-2018, 12:35 AM   #18196
notout86
Drives: GTS 86 auto
Left the interior light on saturday, and woke up today to a dead battery.
I believe LED bulbs use less battery. I fitted the brightest compatible one and WOW is it bright and nice and white (not that weak yellow glow). While I was at it I changed the black (DOH??) interior of the light housing to white with correction fluid. Al foil would work but might make an unwanted electrical connection.
GTS86 Auto (Australia)
The Following User Says Thank You to notout86 For This Useful Post:
StraightOuttaCanadaEh (01-15-2018)
Old 01-15-2018, 01:27 PM   #18197
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Trying a new look...
I LIKE TIRES!
Overdrive (01-21-2018)
Old 01-15-2018, 01:39 PM   #18198
Well, at least ..... you tried ......
Leonardo (01-15-2018)
Old 01-15-2018, 05:54 PM   #18199
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Ohhhh, if Tony Montana would have been there.... big party, forget the cars!
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 01-15-2018, 07:12 PM   #18200
Thornley
Thornley's Avatar
Drives: Silver FRS
It has been a long time since I have posted on this forum.
Installed the Perrin transmission mount and Perrin shifter bushing
Here is how she currently sits @thornleanMotors on Instagram if anyone is interested.
Thornley is offline   Reply With Quote
The Following 12 Users Say Thank You to Thornley For This Useful Post:
86geek (01-16-2018), Adam_L (01-21-2018), Kestrel (01-15-2018), Leonardo (01-16-2018), MJones_RB (01-19-2018), monkeybike (01-15-2018), MrSkubi (02-05-2018), new2subaru (01-21-2018), olsonpg (01-15-2018), Overdrive (01-21-2018), stranger things (01-16-2018), Street_Shark (01-21-2018)
