Old 01-10-2018, 09:07 PM   #2619
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
The evap system performs a periodic pressure test of the gas tank, it's mentioned in the manual.
ineedyourdiddly
B T (01-11-2018)
Old 01-10-2018, 09:28 PM   #2620
tyler_win_photo
tyler_win_photo's Avatar
Drives: 2014 Scion FRS (Asphalt)
Originally Posted by jordanthebass View Post
Second, I already have a high flow fuel pump sitting on my desk, but would the DW 700cc injectors be enough to get me to 300whp? (of course after we solve the above issue )
Not without e85. On pump gas you're going to be octane limited before you hit 300whp.
tyler_win_photo is offline   Reply With Quote
Old 01-10-2018, 11:12 PM   #2621
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Yes, I'm well aware of that. But the question is whether the supercharger water pump is turning on by itself, or only when the evap system performs its pressure test. Does anyone know the frequency of the evap system test and how the frequency is determined?
shiumai is offline   Reply With Quote
Old 01-11-2018, 11:46 AM   #2622
gtengr
Drives: 2017 BRZ
The water pump only turns on when the relay is activated. The relay is activated when 12v is sent to it through the evap connector. Either the relay has to have an intermittent short (seems unlikely given the descriptions), or the evap is telling the relay to activate the circuit at certain intervals while the car is turned off. If all that's true, the solution is to scrap the evap harness splice and find another switched 12v source to trigger the relay.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
shiumai (01-11-2018)
Old 01-12-2018, 12:35 AM   #2623
86fun
Drives: 2013 FRS
How often does it do it? Does it turn off by itself?
Just about every other time I go into my garage I hear but evap pump going and/or the IC pump going. I do believe they are related since I often hear them together. The most times I've heard it in one day is 2-3 times, when I just happened to be in there, so figure it's a bit more than that each day. I have no idea what other dependencies the evap system has to kick off though, maybe it varies depending on conditions?
86fun is offline   Reply With Quote
The Following User Says Thank You to 86fun For This Useful Post:
shiumai (01-12-2018)
Old 01-12-2018, 08:36 AM   #2624
shiumai
shiumai's Avatar
Huh - I definitely hear it a lot less often that you do; as I mentioned before, I've noticed the evap pump going maybe half a dozen times total.
Old 01-12-2018, 11:05 AM   #2625
jordanthebass
Judson
jordanthebass's Avatar
Drives: 15 FRS 6spd Edelbrock SC
Soudns like you have a short somewhere.
You don't need a fuel pump unless you're going ethanol.
We replaced the alternator, it had been given a nice shower in coolant so the battery was at 12.5 volts with the car ON. now its at about 14.7v with the working alternator with all electronics on and sub causing earthquakes.
jordanthebass is offline   Reply With Quote
The Following User Says Thank You to jordanthebass For This Useful Post:
CSG Mike (01-12-2018)
Old 01-13-2018, 06:03 PM   #2626
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
Originally Posted by ThatAsianBradah View Post
It's been several months since I got my 2017 86 boosted with Edelbrock and for the first time I got a CEL to show up. I didn't check the codes yet, but I'm immediately thinking it's a dirty MAF sensor. Just curious if there are other 2017 owners with this supercharger that had a CEL randomly show up and what they did to remedy the issue.
Sent from my SM-G950U using Tapatalk
How did you install the kit I thought it didn't fit 2017.
Joeyb860 is offline   Reply With Quote
Old 01-13-2018, 06:35 PM   #2627
Teseo
Drives: frs
Maybe it fit cuz kit replace the intake?
The Following User Says Thank You to Teseo For This Useful Post:
Joeyb860 (01-13-2018)
Old 01-13-2018, 07:07 PM   #2628
Barefootdan
Barefootdan's Avatar
Drives: 2017 BRZ
Nope, it doesn’t fit due to the alternator and ecu bracket. If they made it fit then they had to either replace the alternator with a 13-16 model or redo the connector. The ecu bracket just needs a simple trim.
Barefootdan is offline   Reply With Quote
The Following 3 Users Say Thank You to Barefootdan For This Useful Post:
Joeyb860 (01-13-2018), Teseo (01-13-2018), ThatAsianBradah (01-14-2018)
Old 01-13-2018, 08:35 PM   #2629
Teseo
Drives: frs
I prefer do the trim rather than electrical issues. But thanks for the info mate
Old 01-14-2018, 07:36 AM   #2630
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
I made it fit on my 2017 cuz I had to lift a pin on the alternator that allowed plugins to fit by. I'll have to take a picture of the fitment later on when I get the chance.
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
The Following 2 Users Say Thank You to ThatAsianBradah For This Useful Post:
CSG Mike (01-14-2018), Teseo (01-14-2018)
Old 01-19-2018, 11:48 AM   #2631
ForcedFed
Drives: Toyota 86
What kind of exhaust setup is everyone running?
Currently on stock exhaust and want to get a header/catback combo...
Would like a system that isn't super loud but it doesn't have to be as quiet as stock.
Also, it's worth mentioning that my car is RHD.
ForcedFed is offline   Reply With Quote
Old 01-20-2018, 05:59 PM   #2632
Barefootdan
Drives: 2017 BRZ
Any word on when the 2017 kits are to be released?
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
