Old 10-20-2017, 08:11 PM   #281
SmartedPanda
SmartedPanda's Avatar
Drives: SWP BRZ Limited Manual. 2014
Took them off for mudflaps, so much weights. Also the lugnuts scratched the hell out of the lugnut holes.
[| Blox 490 Knob | Mishimoto Silicon Intake | K&N Filter | DD Always-On DRL | Tomei 60S | Weather Tech | RED USDM TOM's Tail Lights | OEM Underbody Panels | Intec High Mount Brake | RexSpeed Heated Wide Mirrors | TC105N 17x9 | Super Sport 245/40R17 |TRD Quickshifter | Porsche Brake Air Duct | TRD Sliding Armrest| OEM Knee Pads | MTEC Shifter Springs| WRX OEM Oil Cooler| Generic PVC Catch Can|]
SmartedPanda is offline   Reply With Quote
Old 10-20-2017, 11:31 PM   #282
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
Is your wheel bent?
tigermack is offline   Reply With Quote
Old 10-21-2017, 02:23 PM   #283
SmartedPanda
Originally Posted by tigermack View Post
Is your wheel bent?
Nope brand new-new.
Side note, my lug holes are completely stripped due to the lug nuts.
Old 10-31-2017, 09:28 PM   #284
Bimble Bamble
Drives: 10 Series
17x9 245/40 on TRD Springs, SPC bolts, stock struts
Bimble Bamble is offline   Reply With Quote
Old 12-12-2017, 03:36 PM   #285
jmark
Drives: '97 NSX-T, '18 Type R
Anyone running these on a 2017 BRZ with PP Brembo brakes?
jmark is offline   Reply With Quote
Old 12-13-2017, 10:17 PM   #286
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
yes they fit perfectly. 17x9 +35
Surok is offline   Reply With Quote
The Following User Says Thank You to Surok For This Useful Post:
jmark (12-14-2017)
Old 12-14-2017, 08:38 AM   #287
jmark
Do you have photos? Thanks!
The Following User Says Thank You to jmark For This Useful Post:
Surok (01-05-2018)
Old 01-04-2018, 12:47 AM   #288
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Would love some photo of these wheels with the PP Brembos too!
mistople is offline   Reply With Quote
The Following User Says Thank You to mistople For This Useful Post:
Surok (01-05-2018)
Old 01-04-2018, 03:20 PM   #289
DarkSideFRS
Drives: 2013 pearl white FR-S
how much camber u running?
DarkSideFRS is offline   Reply With Quote
Old 01-05-2018, 06:45 PM   #290
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
[quote=jmark;3016252]Do you have photos? Thanks![/quote
The Following 5 Users Say Thank You to Surok For This Useful Post:
asdf (01-05-2018), jmark (01-10-2018), Kami Speed (01-11-2018), ryann.mendoza (01-09-2018), timurrrr (08-10-2019)
Old 01-10-2018, 12:04 AM   #291
mistople
mistople's Avatar
Out of curiosity, what is the minimum camber I could run with these before they poke?
My DGM are on their way
Old 01-11-2018, 03:04 PM   #292
df.dima
Drives: FR-S and Mazda 3 Sky
I would say, depends on your tolerance of poke / desired flush, I would say 1.6 min, 2 would be good and above 2 is great.
Also note the profile of the tire, some are more square and some are more rounded, that may affect the visuals.
eg MPSS round off and sidewall is a little bit angled towards the fender, so to me they look good with 2 ish, but with a more squared off sidewall, like RS3 if i remember their visuals, I would think they'd need "moar".
You will go nuts analyzing photos on the forum, but in real life things are real It depends on the angle you look and your mood too haha.
df.dima is offline   Reply With Quote
The Following User Says Thank You to df.dima For This Useful Post:
mistople (02-11-2018)
Old 01-22-2018, 11:32 PM   #293
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
[quote=Surok;3024423]
Where did you buy these from in Aus? Or did you import?
Also are those the PP brakes or the STI ones?
Thanks in advance.
Wise is offline   Reply With Quote
Old 01-22-2018, 11:51 PM   #294
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
[quote=Wise;3032040]
Thanks in advance.
BRZ standard performance pack brakes.
buy the wheels from http://www.autotechnik.com.au/index....67_100_191_115
The Following 2 Users Say Thank You to Surok For This Useful Post:
chaoskaze (05-10-2018), Wise (01-23-2018)
dunlop, frs, jrz, rally armor, renzo marsano, star spec, tc105n, wedssport
Wedssport TC105N 17x9+25 5x100 YDNA Wheels and Tires 24 04-04-2014 01:05 PM
FS: Wedssport TC105n 17x9 +25 donutfilling Wheels and Tires 19 03-26-2014 06:59 PM
Wedssport TC105N 17x9 and 17x8 donutfilling Wheels and Tires 9 09-27-2013 04:04 AM
WEDSSPORT TC105N 17x8.0/17x9.0 and 18x8.5/18x9.5 *** with Special. Ed Sticker *** RavSpec Wheels and Tires 47 06-22-2013 11:49 AM
WEDSSPORT TC105N - 17x8.0 +42 / 17x9.0 +35mm 5x100 ~ 15 Lbs Per Wheel RavSpec Wheels and Tires 72 12-04-2012 03:58 PM
