Old 01-08-2018, 08:22 PM   #981
zeal86
zeal86's Avatar
Drives:
Well... turns out to be safe from having to do this again down the line, I'm going to cut a little bit more above the arcs. No biggie... good thing I didn't get to weld yet though...
Also, I became aware of required cuts I have to make to the front bumper. It should not affect any of my preconceived plans for the front bumper... actually it pretty much guarantees I'll be molding the entire front bumper.... that's going to be fun!
More to come soon...
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram @zeal.eightsix
zeal86 is offline   Reply With Quote
Old 01-08-2018, 08:39 PM   #982
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Do you ever just stop to look in the mirror in awe of how awesome you are?
Originally Posted by humfrz
I'm old and lazy
Kami Speed (01-09-2018)
Old 01-08-2018, 09:55 PM   #983
zeal86
zeal86's Avatar
Drives:
Funniest thing I've heard all day!
Old 01-09-2018, 09:45 PM   #984
zeal86
zeal86's Avatar
Drives:
It sucks having so little time to tackle this install the way I want to... Anyways, I'll just have to do what I can with the time that I have...
Today I only marked my adjustments and the cuts on my front bumper. I'm raising my rear quarter cuts by 3/4". Hopefully I'll get to cutting on Friday.
The Following User Says Thank You to zeal86 For This Useful Post:
DustinS (01-10-2018)
Old 01-10-2018, 06:43 PM   #985
Ashikabi
Ashikabi's Avatar
Why do you need to cut the front bumper at all?
Old 01-10-2018, 10:15 PM   #986
zeal86
zeal86's Avatar
Drives:
Wheel and tire clearance... Wider wheels and tires will rub at that point if not cut.
Bumper caps are dual function... they extend to meet the wider fenders but they also create the required clearance at that point.
Old 01-10-2018, 11:31 PM   #987
zeal86
zeal86's Avatar
Drives:
So today I found enough time to cut a bit more from the driver side rear quarter arc. I was also able to prepare it to be welded... whenever that happens...
Tomorrow or Friday I'll try to finish the passenger side rear quarter... then I'll need to cut the front and rear bumpers.
Once everything is welded I'll begin my fiberglass work on the wheels arcs.
Old 01-13-2018, 10:59 PM   #988
zeal86
zeal86's Avatar
Drives:
I finished up my rear quarters minus tack welding... I also cut my front bumper.
Tomorrow I'll cut the rear bumper. Almost done with my provisions!
Old 01-14-2018, 07:05 PM   #989
zeal86
zeal86's Avatar
Drives:
Okay... so all my cuts are done...I'm still waiting on the tack welding though. Once I get that done I'll start test fitting everything before securing them in place.
I'll be ordering my body work supplies real soon.
DustinS (01-15-2018)
Old 01-14-2018, 08:22 PM   #990
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
one of your pics is broken...it has a return/enter inserted
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
zeal86 (01-14-2018)
Old 01-15-2018, 10:25 PM   #991
zeal86
zeal86's Avatar
Drives:
I got tired of waiting so I borrowed a Lincoln Electronics MIG welder. I practiced on some spare metal and went to town. I have never welded before today. I was putting down some killer tack welds... Kidding... I would consider what I did ugly as fuck...lol but it held. At least I'm moving forward with this wide body install!
I'm going over the whole area with short hair body filler then fiberglass and resin. I still need to clean up what I did on the driver side then weld the passenger side.
Maybe I'll post pics tomorrow... lol
Irace86.2.0 (01-16-2018)
Old 01-16-2018, 12:43 AM   #992
Irace86.2.0
Mig welding is pretty easy for someone to get into with no knowledge. Most of what it takes to get clean welds has to do with good prep work, that would be, removing oil, dust, paint, etc to get things down to bare, clean metal, and then to make sure your settings with your shielding gas, wire-feed speed and amps are inline with your metal thickness.
zeal86 (01-16-2018)
Old 01-17-2018, 12:29 PM   #993
zeal86
zeal86's Avatar
Drives:
I practiced some more welding yesterday. I bought a smaller gauge wire and played around with my settings untill I was hearing that bacon sizzling sound. I already re-prepped my area to put down some tacks I could be more proud of... lol
Should be back on the project Friday or Saturday!
Old 01-17-2018, 07:03 PM   #994
Irace86.2.0
Nice. Yea prepwork helps to prevent the swiss cheese effect and that big popping that can happen when particles vaparize in the arc versus that even sizzle sound you want to have.
Also, you can use products to prevent slag from sticking everywhere.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
Kylefrs Build Thread kylefrs Member's Car Journals 14 01-28-2015 09:27 PM
Jac's BRZ build thread Jac Member's Car Journals 0 04-30-2014 08:09 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
