Old 01-08-2018, 07:18 PM   #99
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Originally Posted by Xxyion View Post
To the OP.
How much money do you think you will save i'm curious. I know you've talked about saving money to get exactly what you want and how people tell you, you wont. But i have yet to see some real numbers being thrown around.
It sounds like you want to stick under 5000$...Thats fair. But i also saw that you are trying to piece together various parts from various kits. The customization itself is going to take a toll on your budget. Think in the thousands easy. You claimed earlier that you are already 2k in with the turbo, and the manifold. You are almost halfway through with your budget and you dont even have the important parts that will allow your car to even start up much less run properly. You want E85 too? Thats already going to cost you anywhere between 600-800$ depending on who does your tune. If you dyno tune expect to spend another 250-500$. So now you are 3k in from your 5k budget. Ok so piping? Thats another 300$ if you go with a cheap ebay option. Oil cooler? Theres 600$ minimum right there. How about a boost controller? Or maybe something to gauge your boost to make sure you arent over boosting? Thats almost another 700$ right there. And this is assuming you are installing everything yourself. Oh can we mention we havent even finished building your turbo kit yet?
So now you are 5k into your 5k budget, you dont have a complete turbo kit and you've left no room to purchase the other small items you need or to pay for the custom fabrication you are going to need to get all the parts to fit.
And yet you dont want to buy a JDL V2 kit which can be custom to your specs and WITH a Flex Fuel Kit you will be out the door just under 5k. Assuming you install everything yourself.
There hasnt been anything in this thread that has convinced anyone that you know what you are doing. Hell I dont even really know what i'm doing and i still know that buying a kit is not only going to be more cost effective in the short AND long term. But i also know the kit will legitimately work.
We all know this guy is clueless and is going to end up learning "the hard way".
But since it really makes me a sad panda when people when people don't know what is in their food, where it comes from or how to make the food they eat, I will play devils advocate in his favor lol.
His budget of $5000 may actually be higher than his end goal could cost.
- Buy horrible quality controlled Chinese knock off Garrett turbo
- Get JDL turbo header
- Have welder from the hood on speed dial
- Weld together a pipe using a V-band flange
- Weld other side of pipe to overpipe style flange
- Know how to piece together oil fitting to oil lines (not difficult)
- Get random oil cooler core
- Oil sandwich
- Get Pipe with pre-welded blow off valve flange of your choosing
- Get an generic intercooler (they come in many generic sizes online)
- Get generic piping/couplers which mate everything together (no welding)
- Buy wastegate
- Rubber vacuum hoses
- T-Bolt clamps (just a person preference)
- Weld/bend/drill together brackets to mate intercooler/oil cooler to car
- Garret turbo install kit
- Piece together the turbo oil and coolant hoses + fittings (not difficult)
- Sit back
- and PROFIT!
The above list can be accomplished under the $5000 budget. Sourcing the needed hoses, fittings, IC pipes, couplers, flanges is pretty easy and cost effective with this crazy internet thing. Being able to at least purchase the JDL turbo header on its own does a lot to make things easier.
THINGS TO THINK ABOUT:
- Welding skills and materials used will determine exhaust ghetto factor
- Intercooler piping will not be as fitted as car specific piping does
- Oil cooler lines will look better since you can take the slack out
- Ebay intercoolers work well. (This was a thing in the evo 8/9 world)
- Generic or fabbed up does not = bad as long as you know what you're doing
- Fabbing up your own kit or any component is not a "90's thing". It still happens on contemporary platforms (Or did we already forget about Phantom E-superchargers)? lol
- Please spend the extra money and get a real Garret/Mitsu component turbo
Example of site to buy real turbo/turbo parts from:
http://www.turbokits.com/Turbo_Charg...Gen_II_Series/
Example of IC piping/coupler generic part website:
http://www.siliconeintakes.com/?osCs...d0e45c324961c1
Example of generic intercooler on a major website:
https://www.amazon.com/Mishimoto-MMI...NFT5YJDKVH4K9R
“Only those who attempt the absurd can achieve the impossible.”
― Albert Einstein
TachyonBomb is offline   Reply With Quote
The Following 3 Users Say Thank You to TachyonBomb For This Useful Post:
CxG (01-09-2018), nickdd6237 (01-08-2018), Teseo (01-10-2018)
Old 01-08-2018, 08:44 PM   #100
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Sounds like he can just simplify this entire process by getting a JDL Kit lmao
Alltezza is offline   Reply With Quote
Old 01-08-2018, 11:27 PM   #101
nickdd6237
Drives: 09 vw gti
- Oil sandwich
- Buy wastegate
- Sit back
- and PROFIT!
― Albert Einstein
Why the JDL manifold instead of the
https://www.maperformance.com/produc...s-ft86-tkit-hp?
It'd be best to buy the turbo manifold and turbo first before anything right? Then I can figure out the intercooler piping one that stuff is installed.
nickdd6237 is offline   Reply With Quote
Old 01-08-2018, 11:39 PM   #102
nickdd6237
Drives: 09 vw gti
This wont be my daily driver so I'm still kinda iffy on the Flex Fuel. I know the car shouldnt be sitting longer than a week with e85. This also gives me time to get fitments right and all the pieces together since I have another car to drive.
Old 01-09-2018, 01:08 PM   #103
CSG Mike
CSG Mike's Avatar
My car sits longer than that with E85 all the time.
TachyonBomb (01-13-2018)
Old 01-09-2018, 03:03 PM   #104
Joeyb860
Joeyb860's Avatar
Drives: 2017 860 SPRINTEK
You can make 300whp at 6-7 psi.
This isnt' a 20 year old B series.
What kit are you running? I like the AVO kit but was worried about the clutch. What are your thoughts?
Joeyb860 is offline   Reply With Quote
Old 01-09-2018, 03:06 PM   #105
jasonojordan
Drives: 2013 satin white brz limited
In the summer my car will sit 2 weeks at a time or more all the time on ethanol never had a issue.
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
nickdd6237 (01-10-2018)
Old 01-09-2018, 04:00 PM   #106
CSG Mike
CSG Mike's Avatar
GReddy + Delicious Tuning FF kit + Tune.
PM me if you want to replicate any part of my setup. I make that power on a *stock* clutch.
Joeyb860 (01-10-2018), nickdd6237 (01-10-2018)
Old 01-10-2018, 10:50 AM   #107
nickdd6237
Drives: 09 vw gti
Cool, good to know.
Old 01-10-2018, 11:04 AM   #108
nickdd6237
Drives: 09 vw gti
I saw that ECU-Tek will rent you out the connector and chip for a week if you buy the license. So does that mean I can just rent it, take it to a tuner, and get it tuned? I dont NEED to have the ECU-TEk connector once its tuned do I? This way would be alot cheaper.
Old 01-10-2018, 11:20 AM   #109
jasonojordan
Alot of reputable tuners will just sell your a license when they tune your car. Any tuner that is ECU-TEK dealer certified will already have the cables and what not along with the tuner license so no need to rent the cables.
Old 01-10-2018, 01:21 PM   #110
nickdd6237
Drives: 09 vw gti
ah ok thanks. So I will have to pay for the Licence and Tune seperately right?
Old 01-10-2018, 01:34 PM   #111
jasonojordan
Correct. I believe a ECU-Tek License runs around $300-$400
Old 01-11-2018, 04:21 PM   #112
mjanmohammad
Drives: Boosted 2017 BRZ PP. GT2860RS, JDL.
A lot of tuners bundle the tune/license together. When I got mine done, my tuner charged me $750 which included the tuning time, license, and free minor revisions for 6 months.
mjanmohammad is offline   Reply With Quote
Mod ideas? _anthonygd BRZ First-Gen (2012+) — General Topics 42 09-08-2015 06:28 PM
New Here Need Ideas FRStrent Scion FR-S / Toyota 86 GT86 General Forum 30 07-10-2014 10:22 PM
In Need Of Ideas!! bh7990 Scion FR-S / Toyota 86 GT86 General Forum 28 05-19-2014 12:14 PM
Turbo, white smoke out the exhaust, ideas? Synack Forced Induction 44 09-09-2013 09:57 AM
Need ideas for possible (new-to-me) used car suprachica79 Other Vehicles & General Automotive Discussions 66 02-20-2012 06:42 PM
