#1373 |
Drives:
[ame="https://www.youtube.com/watch?v=Cr39S8OzWn4"]Grange Black Friday Drift Recap 11/24 - YouTube[/ame]
Drifting at Grange Motor Circuit; Apple Valley, CA The event was hosted by www.SlideFactory.org and is great for all driver levels from straight beginner to advance. It's a safe track and a great place to learn dynamic car control.
#1374 |
Just had the PBM knuckle + outer tie rod installed. I realized at full lock my wheel is grinding into the outer tie rod. What offest do I need to prevent this from happening or what offset are you guys running with the knuckles? I'm currently 16x8.5 -6. I'm noticing a trend that anyone with the full kit from PBM has overfenders...
#1375 | |
Wanna-be
Drives: 2013 Firestorm FR-S
The offset spacers may help prevent that. Or depending on how much it runs, a small slip on spacer might give you the clearance you need. |
#1376 |
#1377 |
Noob here. I'm getting an opportunity to drift on an actual race track and I've only initiated in 2nd gear and have no experience in 3rd or above. How do they differ and any pointers?
#1378 |
Drives: '24 GR86
More speed, more throttle, more commitment. That's pretty much it honestly. You'll probably want to start a bit higher on rear tire pressure and then lower accordingly depending on how the car feels.
#1379 |
Drives: 2013 Scion FRS
^^^. This. Commitment being the key part’
#1380 |
IG: @_southwell_86
Drives: Rwd Prius.
Wishing winter was over.... sigh
#1381 |
Drives: '24 GR86
#1382 |
IG: @_southwell_86
Drives: Rwd Prius.
#1383 |
Drives: 2017 86
What is everyone running for alignment? I've got some BC coilovers, SPC lcas, SPC toe bushings, and Megan racing inner tie rods. Thinking something along the lines of -4 deg camber up front with slight toe out, -1 deg rear with slight toe in.
#1384 | |
Drives: '24 GR86
For the rear, -1 to -2 is ok. If you can get under -1.5 then you should be good as far as tire wear goes. For toe, it depends on your preference. Personally, I found zero toe on the rear to be better. If you want more rear stability, a touch of toe in will help.
#1385 | |
Drives: 2017 86
#1386 |
Drives: 2015 BRZ
Hey guys, haven't posted in a while so I figured I'd share some stuff from last year.
Vide of me and some C group guys, https://www.facebook.com/clubloose/v...a0&pnref=story IMG_0286 by photography.B, on Flickr IMG_0276 by photography.B, on Flickr![]() ![]() AXX_5289+ by Johnathan Cseh, on Flickr![]() ![]() [ame="https://www.youtube.com/watch?v=yhe3qyiMQ6o"]Club loose clinic 3/11/17 - YouTube[/ame] Still struggling with consistency. What is everyone running for dampening? |
| Is there a thread for 'people doing stupid things in their brand new car' thread? | Symbiont | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 36 | 02-18-2013 01:24 PM |
| BRZ Drifting. | Hunter | BRZ Photos, Videos, Wallpapers, Gallery Forum | 7 | 09-20-2012 09:57 AM |
| So Cal drifting | Thefear13 | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 08-10-2012 05:53 PM |
| REAL drifting thread | TylerLieberman | Off-Topic Lounge [WARNING: NO POLITICS] | 17 | 02-28-2012 05:20 PM |
| FT-86 II (RC) Drifting | ft86cbx | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 8 | 11-11-2011 03:02 AM |
