Old 01-07-2018, 11:44 PM   #43
Brink
Drives: 2017 BRZ
I run 265 tires and a stock exhaust. And a rather large wing.
I think you need a bigger wing on there.
Brink is offline   Reply With Quote
The Following 2 Users Say Thank You to Brink For This Useful Post:
CSG Mike (01-08-2018), guybo (01-08-2018)
Old 01-08-2018, 12:23 AM   #44
Originally Posted by Logikal Reazon View Post
1 . 400hp 2000 Mustang GT
2. 48 month 0% interest, 5k-10k
3. Yes I will do my own work. Learning as I go.
Ok. Sounds reasonable money-wise. Learn to do the little things first.
Take!
Your!
Time!
Logikal Reazon (01-08-2018), Spuds (01-08-2018)
Old 01-08-2018, 12:37 AM   #45
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Don't you have a header?
Old 01-08-2018, 12:39 AM   #46
He does but he's also smart with his moneys.
Well, 'cept for that big ol' Kang wang.
Old 01-08-2018, 02:28 AM   #47
Logikal Reazon
Logikal Reazon's Avatar
Drives: 2017 Toyota 86
Take!
Your!
Time!
I plan on "feeling" each upgrade before I move to the next, very sound advice. Thank you.
As far as the specific parts I chose do you have any suggestions and reasons behind them?
This is the first forum I joined amd participated in and I'm finding it a bit fun.
Sent from my SM-N950U using Tapatalk
Logikal Reazon is offline   Reply With Quote
Old 01-08-2018, 02:30 AM   #48
Logikal Reazon
Originally Posted by Impureclient View Post
I was just being silly.
I can't say since I'm only like 1.5-2k into these but I only got a little over 8k out of my MPSS. These still look like brand new so I know they'll go much longer than the 8k for sure.
I'm going to seriously consider the Firehawks, the fact that you said you get superior performance and they are a fraction of the price is really interesting.
How is the wet performance?
Thank you.
Old 01-08-2018, 04:46 AM   #49
CSG Mike
CSG Mike's Avatar
Been thinking about it.
@CSG MikeIs that a square setup or staggered? Also what else do you have done to the car?
Thanks!
Square. GReddy turbo, Delicious Flex Fuel, CSG Flex A coilovers, ATS LSD, and some other stuff.
Sure do, although it would technically be a turbo manifold now.
Old 01-08-2018, 04:47 AM   #50
CSG Mike
CSG Mike's Avatar
Thank you.
I wouldn't call the RE003/Firehawk Indy 500 superior to the MPSS.
Old 01-08-2018, 04:48 AM   #51
Logikal Reazon
What do you run? Why?
Thanks!
Old 01-08-2018, 05:18 AM   #52
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
When I bought my tires, I considered price, what I had heard from others at car meets and this Consumer Reports round up. My first choice was the BFG Sport Comp 2, but there is very little stock in my size nationwide. I had gone to BJ's and ordered them- they had a great deal- but they tried to sell me 3 year old tires- no way.
I ended up with MPSS only a couple months old. MPSS is rated to be the #1 tire in the Ultra Perf Summer tire category by CR and pretty much everywhere else- look at reviews and talk to people. The only down side is price, but when I couldn't get the best tire for the buck (Comp 2), I decided to just get the best tire (MPSS). Firestone Indy 500's were further down the list near where the Comp 2's were at. Not on the top recommended list.
Here are the other CR Recommended tires. Remember one thing though- tire naming is tricky. When you go to get your tires, make sure you get the EXACT same model
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Old 01-08-2018, 05:25 AM   #53
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Hey guys car semi-noob here. Just bought a 2017 Toyota 86! Has about 2300 miles on it now.
So far only switched out the trans and diff oil with Gear 300 and dimple magnetic plugs for the drain and fill plugs for both trans and diff.
Next thing I have on my list are 18x9.5 +35 Volk te37 SL wheels wrapped in Michelin 255/35 PSS.
Then KW V3 coilovers.
Just the first two things alone tell me you are doing this wrong.
If you really have some goals in mind of looks/handling, the first step is to get the basic power mods you want, and doing the suspension/wheels later on at the same time.
I know you said you are a noob but you should really research wheel fitment, alignment, and wheel to strut clearance first before just saying "I want XYZ wheels with ABC suspension". Things like alignment and tire/fender clearance matter.
-alex
Old 01-08-2018, 09:15 AM   #54
Spuds
The Dictater
Spuds's Avatar
So not stock exhaust. And FI. When did the wider wheels and tires come around relative to the FI? Iirc, you were running e85 fuel and a header(and an aftermarket catback) before you got off the stock tires?
Old 01-08-2018, 09:47 AM   #55
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Stock catback.
Old 01-08-2018, 09:49 AM   #56
Impureclient
Drives: 2015 FR-S
On paper no but in reality for me, yes. Having driven on them back to back I can say that the Firestone was superior in every way. Wet, dry quietness, and it appears the longevity, Firestone all day long.
I'm not going to argue with a few people over the internet over which tire is better since going from a stock 215 to anything 255 will be an improvement in traction and without experiencing both tires in
the same size, he'll be happy with either new tire. I don't track my car but in daily driving, I spun out 3 times on the Michelins when pushing them to their limit and would constantly slide around like
they were wet when it was dry out. The Firestones just stick unless I floor it and jerk the steering wheel in a tight turn and even then, they seem to have better control in a slide. Maybe if the Michelins are
thoroughly heated up they perform better in racing but on the street they sucked balls. If the prices were switched on those two tires and the Firestones were $400 more, I would still buy the Firestones.
Maybe I got suckered and had a older set of the Michelins(didn't happen to see the manufacturer date) but I am 100% sure that the Firestone has better traction than that Michelin.
A/T Owners how satisfied are you with the transmission. Thoughts/Suggestions? darthpnoy1984 Engine, Exhaust, Transmission 2 04-30-2017 02:58 PM
Suggestions for long highway cruising mods migueralliart Scion FR-S / Toyota 86 GT86 General Forum 88 03-12-2016 06:28 PM
Member Thoughts CARBONGT86 CANADA 2 02-02-2016 11:49 PM
My Mods So Far. New To Modding! Share your thoughts. Jolt182 Scion FR-S / Toyota 86 GT86 General Forum 12 07-16-2015 02:23 PM
[Body Mods & Kits] Suggestions using others cars as reference 1086 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-06-2014 01:59 PM
