Old 12-28-2017, 05:58 PM   #785
cjd
cjd's Avatar
Drives: 2017 BRZ
I disagree with, and am offended by your characterization of snowflakes.
To this I would add: "special snowflake" has turned into a common ad hominem and now carries far more weight than it typically did. Usually thrown in with a number of other common fallacious argument tricks.
In this case, the sticker might be considered a disarming technique; embrace the accusation as specious, even if accurate, and allow focus once again on the subject at hand.
It is often a great (of not sobering or even mortifying) opportunity to observe Dunning-Kruger in full effect if you hear this being used to describe someone (at least, within American politics at the moment).
Go enjoy the special class and make it a success.
The Following User Says Thank You to cjd For This Useful Post:
tony_r (12-28-2017)
Old 12-28-2017, 06:16 PM   #786
Don't know yet what it means but I updated my title for the time being.
cjd (01-01-2018)
Old 12-28-2017, 06:22 PM   #787
I like it.
Old 12-28-2017, 06:29 PM   #788
tony_r
tony_r's Avatar
Drives: '15 STX
I would like to shake your hand. Can I shake your hand?
tony_r is offline   Reply With Quote
The Following User Says Thank You to tony_r For This Useful Post:
cjd (01-01-2018)
Old 01-01-2018, 06:12 PM   #789
Doji Style
Drives: 2014 SWP BRZ
Has anyone paid to have this kit installed?
My current living arrangements won’t allow me to install it myself so I will be calling around tomorrow to get quotes. I have absolutely no idea what to expect as I’ve never paid for this. I’m in the Phoenix market, we have a few known shops (Goodspeed, Subiworx) and my local club referred me to two individuals who sound quite competent.
I’m just looking for an idea of what to expect so I have some context going into this.
2014 SWP Subaru BRZ
2014 VW GTI
2013 Asphalt FR-S - Sold
Doji Style is offline   Reply With Quote
Old 01-01-2018, 06:17 PM   #790
Radster
Radster's Avatar
Drives: 2014 FR-S
Our local autox shop here in NJ charges $650. See the link below for details of what that includes.
https://m.facebook.com/groups/185031...56464307716855
Radster is offline   Reply With Quote
The Following User Says Thank You to Radster For This Useful Post:
Lex_K (01-02-2018)
Old 01-01-2018, 06:41 PM   #791
dutchman1
Drives: 2017 86 6-Speed
I'd like to point out too that you shouldn't just go for the cheapest quote. You're going to be autocrossing the car and want the kit to be working optimally. Shitty mechanics tend to ignore things like lubing bushings, torque specs/sequence, bushing preload, etc. Good shops charge more because they do better work. I'd spend the extra couple hundred bucks and find a reputable racing shop to install it.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
Old 01-03-2018, 03:41 PM   #792
tony_r
tony_r's Avatar
Drives: '15 STX
To be fair there isn't much to this kit installation. If you know how to torque things down you're pretty much set. Preload and the like can be handled by a good alignment tech.
Old 01-03-2018, 04:21 PM   #793
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Hoping treadwear rating gets revised in the mid Jan announcement and A7 is the spec tire.
iLuveKetchup is offline   Reply With Quote
Old 01-05-2018, 10:03 AM   #794
chucky12012
Drives: 2013 Asphalt Scion FR-S
Note, after two events I think I've already busted one of the stock front end links... which was something I figured was bound to happen with that massive front bar.
chucky12012 is offline   Reply With Quote
The Following User Says Thank You to chucky12012 For This Useful Post:
strat61caster (01-05-2018)
Old 01-05-2018, 10:52 AM   #795
iLuveKetchup
Drives: EFF JAY
Are you running Hoosiers? Pics
Old 01-05-2018, 12:37 PM   #796
tony_r
tony_r's Avatar
Drives: '15 STX
Yeah what the shit? We've got way more than two events on concrete, with 3-4 drivers per event, and have zero issues with front links, rear camber or rear links.
Are your lots rallycross fields?
Old 01-05-2018, 02:05 PM   #797
chucky12012
It's not like the thing is ripped apart, but the joint is damaged and expelling grease. The thing had been sitting in the attic for years not being used, so who knows how it was feeling when it got installed again.
I haven't noticed any issues with the rear.
Old 01-05-2018, 02:06 PM   #798
chucky12012
No, just the spec tire obviously
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
