Drives: 2014 brz limited
Anybody here know about airbag systems?
Ok so heres my problem i have a 14 subaru brz that got hit on the side my seat airbag deployed (got a new seat) my curtain airbag deployed and seatbelts broke. My questions are if i buy a used airbag module will it work or will i need to have it programmed to my car? Also is there any crash sensors that i need to replace or are those still good if they arent broken. Also are the seatbelts and side airbag interchangeable between brz and frs thanks all
#2 | |
All impacted sensors will need to be replaced. They are one shot only. I do not believe that the modules on these cars are programmed to the vehicle but no doubt somebody will correct me if I am wrong. The service manual does not state it requires programing. Follow the installation requirements to the letter (i.e. do not reuse bolts, disconnect battery before doing anything, etc) https://demos.starbase7.net/t3Portal..._rm_index.html Interior/supplemental restraint systems
#3 | |
#4 |
The sensors are in the body of the car. The info you need will be in the service manual I attached. To be perfectly straight with you this is not a project you should tackle if you are not 100% confident you know what you are doing. You are dealing with explosive charges that can kill or seriously injure you if you screw up even a little. You should probably talk to a pro and get a cost on this project.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (01-04-2018) |
#5 | |
#6 | |
Sort of like attempting to disarm a land mine ....... you don't get a second chance ...... ![]() humfrz |
#7 | |
The manual will tell you if you need to program the module. It doesn't appear that you do but I only skimmed it.
| The Following User Says Thank You to Tcoat For This Useful Post: | Wally86 (06-30-2022) |
#8 |
You're right i didn't but i only asked because every car has different locations. One goes in the door but im getting a new door so probably not needed to get that one
#9 | |
Here is an option for the module: http://www.ft86club.com/forums/showthread.php?t=107947
#10 |
Drives: Gt86 2013
I got a hit on my wheel and the left side curtain airbag deployed… sensors are all good, body of the car not damaged, it’s just the wheel, suspension and controls arm that were damaged.
I replaced the airbag already but the manual states also to replace the airbag control module if I’m not mistaken… so is there a way to reset this module or is toasted for good? |
| WTB: 86 Airbag cover, no airbag needed | stevesnj | Australia Classifieds | 0 | 02-18-2016 09:17 PM |
| WTB: FRS oem driver airbag, clock spring, both front seat belts, airbag module | 14_GT86 | Want-To-Buy Requests | 3 | 04-01-2015 12:26 AM |
| WTB Passenger Curtain Airbag + Wheel Airbag | markkisl | Want-To-Buy Requests | 4 | 08-26-2014 01:16 AM |
| FS: JDM FT-86/FR-S Airbag and Airbag Cover | JDM_AE86 | Interior Parts (Incl. Lighting) | 13 | 03-20-2014 03:42 AM |
| FS: JDM 86 Airbag horn cover with airbag | turbos86 | Interior Parts (Incl. Lighting) | 5 | 11-20-2013 01:17 AM |
