Old 01-02-2018, 11:20 AM   #225
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Originally Posted by zshazz View Post
In case anyone was wondering, this radiator does _not_ fit the stock 2017 MT Airbox and will require switching to a 2013-2016 airbox or going to an aftermarket solution.
Jackson Racing (edit for precision) stated they have not released the 2017 solution yet, but that's the current situation.
Questions:
  • Has the status of this changed yet for MY17+ cars?
  • If not, is there a plan to address this and is there a reasonable time frame?
  • Would Jackson Racing ever be able to give the option for braided oil lines that would not kink? This is one of those items in a car I would never want to worry about when driving 10/10ths.
Thank you!
dowroa is offline   Reply With Quote
Old 01-02-2018, 04:31 PM   #226
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Just found out about this & love it.
But is this gonna fit with the US TRD intake box?......?? Anyone can test for me?...
Old 01-02-2018, 05:26 PM   #227
Teseo
Drives: frs
Ditch the intake
Old 01-02-2018, 09:18 PM   #228
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by dowroa View Post
Questions:
Thank you!
Originally Posted by Teseo View Post
Ditch the intake
Man but i like those TRD in RED captial letters
Well , I emailed Jackson Racing, they said the updated version is coming out soon.... atleast the one will fit the 2017+ model.
If those still wont work, maybe?
I guess I can finally use my STI sound tube thing again if I swap back to stock intake.
The Following 3 Users Say Thank You to chaoskaze For This Useful Post:
CxG (01-10-2018), dowroa (01-02-2018), Teseo (01-02-2018)
Old 01-03-2018, 04:24 PM   #229
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
Originally Posted by Paulo86 View Post
Hi guys ! Just ordered mine !
Does anybody know if there is a 1/8 npt thread in the sandwich plate so i can put my pressure sensor in it ?
Nobody ?
Paulo86 is offline   Reply With Quote
Old 01-03-2018, 05:18 PM   #230
CSG Mike
CSG Mike's Avatar
There is not. use the galley plug.
Paulo86 (01-04-2018)
Old 01-03-2018, 05:19 PM   #231
CSG Mike
CSG Mike's Avatar
It does not unless you don't mind the line touching the box.
chaoskaze (01-04-2018)
Old 01-03-2018, 05:19 PM   #232
CSG Mike
CSG Mike's Avatar
Questions:
Thank you!
Still in progress. "soon".
JR will not be offering optional lines, but it's not difficult to get your own custom line made locally.
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
AllThePeat (09-13-2019), chaoskaze (01-04-2018), dowroa (01-03-2018)
Old 01-03-2018, 11:22 PM   #233
churchx
churchx's Avatar
Drives: 2014 GT86
CSG Mike: still, it simplifies if one is able to get complete package w/o having to search something separately. And if JR isn't bothered by it, then CSG might offer optional other lines for JR sold through your shop, no?
The Following 3 Users Say Thank You to churchx For This Useful Post:
dowroa (01-03-2018), KoreanJesus (12-15-2018), Teseo (01-03-2018)
Old 01-04-2018, 01:04 PM   #234
Grady
Grady's Avatar
Questions:
Thank you!
Since this is an option I may consider, I do not understand the “would not kink” statement. A hose will not kink if it is installed correct. So is the problem?
A) People are having troubles because they are installing and getting below the minimum bend radius of the hose?
B) The installation does not allow you to maintain the correct bend radius?
If it is B then I would think JR should supply the correct hose
The Following User Says Thank You to Grady For This Useful Post:
CSG Mike (01-04-2018)
Old 01-04-2018, 06:15 PM   #235
CSG Mike
CSG Mike's Avatar
Kinks are exclusive A), installer error. The hose should be installed in a manner which has minimum twist and maximum radius.
This is a tried and proven solution that has won multiple national championships in off-the-shelf form. An aftermarket line is not *necessary*, but some people do it for peace of mind, or to add some further customization to their engine bay.
CxG (01-10-2018), Grady (01-04-2018), Jackson Racing (01-05-2018)
Old 01-04-2018, 11:19 PM   #236
Grady
Grady's Avatar
Good info! Thanks!!
Old 01-12-2018, 05:08 PM   #237
METAL_SU-37
METAL_SU-37's Avatar
Drives: 2017 BRZ Series.Yellow
So, I have a 2017 BRZ Series Yellow and I installed this radiator myself
I ran into an issue where the metal 90 of the hose ran into the stock air box, even when rotated. it also completely blocked off my oil fill cap...
I recommend this from Mishimoto
https://www.mishimoto.com/banjo-fitt...0an-black.html
Here are some pictures of the install
The Damage done:
After I bought the Banjo bolts and thermostatic plate from Mishimoto
much cleaner, thermostatically controlled, and clearance to actually open the air box and remove a filter.
METAL_SU-37 is offline   Reply With Quote
The Following 3 Users Say Thank You to METAL_SU-37 For This Useful Post:
7 skulls (01-12-2018), dowroa (01-12-2018), wrh3 (01-12-2018)
Old 01-12-2018, 05:33 PM   #238
ThatAsianBradah
ThatAsianBradah's Avatar
Drives: Toyota 86 2017 TRD Modded
How's the fitment of this Dual Radiator/Oil Cooler when installing on a 2017 86 that has an Edelbrock SC on it?
Sent from my SM-G950U using Tapatalk
Life is like a car, you press the gas to go, steer around all the things blocking your way through Life, and park it when you reach your destination
ThatAsianBradah is offline   Reply With Quote
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 05:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 11:26 AM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 02:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 11:04 AM
