Old 12-30-2017, 02:16 PM   #37983
Cole
Not a troll
Cole's Avatar
Well fuck me gently with a chainsaw. I now have a gigantic exhaust leak.
And of course, it didn't happen until I passed my parents place while I was on the way to the cottage.
Cole is offline
Old 12-30-2017, 02:25 PM   #37984
shit
Ultramaroon is offline
Old 12-30-2017, 03:56 PM   #37985
ft86sf
Old 12-30-2017, 04:09 PM   #37986
Maybe it costs extra for the subie dealer to tighten down the O2 sensor you had replaced for cheap ......
OR
Maybe you have replaced the muffler so many times, that the flange bolts just wore out ......
humfrz is offline
Old 12-30-2017, 08:23 PM   #37987
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I've bought so many flange nuts and bolts from Subaru the last four years that it has became the default question whenever I walk towards the dealer parts counter; "Back for more bolts?"
krayzie is offline
Old 12-30-2017, 09:33 PM   #37988
Teseo
Drives: frs
I thought i was the only one but my case is on wheel studs
Teseo is offline
Old 12-30-2017, 10:59 PM   #37989
@krayzie
@Teseo
Rule #1 - don't work on your car after 6 beers
Rule #2 - squirt nuts with kerosene or coal oil before you start
Rule #3 - to take off most nuts, turn them counterclockwise (lefty is losy)
Rule #4 - you DO NOT need a 1.5" air impact wrench for most nuts
Rule #5 - if you "work out" or don't have a calibrated wrist .... use a torque wrench
OR
Do it the humfrz way ...... take your machine up to your local auto shop for the work, that way if Bubba twists off the nut/bolt ...... he has to fix it.
See ...... pretty simple ......
humfrz is offline
Old 12-30-2017, 11:05 PM   #37990
My Review Of the JDM Underbody Panel Kit sold by FT86SF
Ups:
Fits perfectly.
MUCH quieter ride. Surprisingly effective.
5 MPH gain in top speed. (not really)
Downs:
Shipped with standard 8 mm hex nuts when factory uses locking flange nuts. I added my own washers and tightened gently over plastic parts using blue loctite.
Needs 3 mm-tall spacers or new screws with taller shoulders for the six forward-most shoulder screws. Fully tightening the originals over a double layer of fiber board will destroy the boards. I also finger-tightened these after applying blue loctite.
Old 12-30-2017, 11:14 PM   #37991
@krayzie
@Teseo
OR
#2 is also a very effective treatment for crabs.
Tcoat is offline
Old 12-30-2017, 11:23 PM   #37992
Ups:
Fits perfectly.
Downs:
Questions:
Did you put your car on a lift to attach the parts?
How long does it take?
I would be interested in the quieter part.
humfrz is offline
Old 12-30-2017, 11:27 PM   #37993
Back in the old army, we used 10% DDT dust ....... we burnt the other stuff in our multi-fuel vehicles.
humfrz is offline
Old 12-30-2017, 11:30 PM   #37994
Questions:
Rhino ramps up front and jack stands in back.
I could do it again in under an hour taking my time with a coffee break.
Old 12-30-2017, 11:56 PM   #37995
So, Bubba, using a lift, should be able to do it within an hour ......
Oh, wait, I just read an internet instruction piece about attaching the panels .... I'm ah feared Bubba isn't the man for the job...... too many small delicate pieces.
So, that leaves me and you Ultramaroon ...... I'll supply the panels, furnish the garage, ramps and jack stands and I'll make the coffee ........since you have the experience, I'll allow you to attach the panels ...... oh, yes, I'll slide tools to you as needed .........
humfrz is offline
Old 12-31-2017, 12:00 AM   #37996
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Ups:
Fits perfectly.
Downs:
Sapphireho is offline
