Old 12-30-2017, 01:08 AM   #127
Swoldier86
Swoldier86's Avatar
Drives: 2013 BRZ Limited
I don't know. I'm puzzled about the lifting of the pedal. I get exactly what @Tcoat meant about it hanging up on the way back. The burning smell matches because I can picture the TOB hanging up on the center bushing as it melts. :/
Also there is the mystery of the loose cruise interlock switch. That has to be adjusted just so after the the clutch pedal travel is dialed in.
I'm not saying one way or another about the issue, just that something still doesn't add up.
The burning smell was just one time. After driving home in the rain with the AC on for the first time in a while. Could have been water and the exhaust causing the smell maybe I’m
Not sure.
The pedal never really felt like it was hanging on anything when I pulled up.
The cruise interlock switch nuts were loose, as well as the clutch adjustment nut. I am positive that the clutch has slipped down on that bolt over time, you could see where it used to be and where it was now. If you look at that picture I posted of it, it was so far down I couldn’t even see the threads on the back side at all.
Swoldier86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Swoldier86 For This Useful Post:
humfrz (12-30-2017), Ultramaroon (12-30-2017)
Old 12-30-2017, 01:25 AM   #128
Not sure.
Wow, ok. Previous owner adjusted the pedal but did a shitty job of it. Do you want to go over proper adjustment to make sure you have it right?
Swoldier86 (12-30-2017)
Old 12-30-2017, 07:32 AM   #129
ermax
ermax's Avatar
What else did the previous owner do a half ass job on? I think I would grab a torque wrench and go around the car with it. Hahaha
Old 12-30-2017, 08:48 AM   #130
Swoldier86
Swoldier86's Avatar
Yeah I’m not sure on proper adjustment I just moved it up a lot lol. Then I adjusted the cruise control switch back a little to where the clutch touches it.
This is why the cruise control quit working because the clutch pedal had slid down so much over time it wasn’t coming up enough to meet the cruise switch any longer. It was down so far that I couldn’t engage the cluttch.
But when I would pull up with my foot it would pull up on the bolt and the threads would probably twist just enough that when I pressed back down it had enough distance to engage the clutch.
Old 12-30-2017, 02:17 PM   #131
I can picture it. It sounds like you pretty much nailed the adjustment. As long as the cruise switch allows the master cylinder plunger to fully extend, you're good to go.
Old 12-31-2017, 01:54 PM   #132
Speaking of a cruise control ...... that brings to mind a back-on-the-farm story.
It was a very warm, sunny, spring day, when I was driving our Oliver 70 tractor, pulling a disk, on the back 40. The neighbor girl, named Mary Ann was working the neighboring field, driving an Oliver 88 (a more powerful tractor) pulling a larger disk.
Now, Mary Ann was quite well endowed and had the reputation of being what we called a "c _ _ k teaser".
She was wearing short shorts and a halter top so she could get a tan. She would play this game of taking off her top when I was at the other end of the field ..... and then put it back on when I could catch up (in my field).
hmmmm....... what to do ....... her tractor was more powerful, so I couldn't catch her.
Ah ...... ha ...... I ran a length of baling wire from the governor on my tractor up to the seat. Then on one pass, while she was topless, I caught her looking, pulled the governor wide open and closed the distance to get a good look at her perky, subtle breasts, jiggling and shimmering in the sunlight .......
THAT'S ALL FOLKS ........
Ultramaroon (12-31-2017)
Old 12-31-2017, 03:00 PM   #133
Genius comes from just wanting something badly enough.
humfrz (12-31-2017)
Old 12-31-2017, 08:59 PM   #134
Yep, she was playing "catch me if you can" ........
Old 12-31-2017, 09:07 PM   #135
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
She let you see. Like you said, c••• tease.
humfrz (12-31-2017)
Urgent need of help 86z Issues | Warranty | Recalls / TSB 6 11-12-2016 10:48 AM
Urgent help needed to identify blown engine driftking96 Engine, Exhaust, Transmission 30 06-14-2016 10:32 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
FS LED kits(Urgent) [WA] GTiko Australia Classifieds 1 10-29-2012 10:43 AM
