#113 |
Tcoat has an excellent point. I get what he means now.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Swoldier86 (12-29-2017) |
#114 |
Drives: 2013 BRZ Limited
When I pull up it doesn’t take much pressure at all barely any, almost like if I blew on the pedal it would pop up into place. Also there is no noise from the TOB or anything when I pull up. Only the pedal itself making some noise.
My clutch is even with my brake pedal when I pull up on it. |
#115 |
Drives: 2005 Toyota Camry
| The Following 2 Users Say Thank You to mav1178 For This Useful Post: | Swoldier86 (12-29-2017), Ultramaroon (12-29-2017) |
#116 |
Nope. No rumble until it total blew. It was just a gradual increase in the pressure needed to push the clutch. In fact it was gradual enough that I never noticed the change but the pressure required was much the same as yours. That was why I didn't think there was a huge difference when I drove yours. With the new clutch the difference is night and day. I had simply forgotten that you can push these things in with a feather. I bet it has been slowly getting worse for over a year. The squeal is just one symptom that occurs someplace in the middle and is not the first indicator as we have always thought.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | Swoldier86 (12-29-2017), Ultramaroon (12-29-2017) |
#117 |
Ah, I totally see it now.
OP, I went back and reviewed. The burning smell - did it smell like burning plastic?
#118 |
Guys!! I think I have fixed it but I am not going to rule anything out yet.
Just got home checked the clutch adjustment the bolt was loose it was looooow and there was like some dark rings on the front end of the clutch bolt looked like it had went down further almost like it had been sitting there for a while and had moved. I watched a video on YouTube adjusted the clutch to a higher position and oh my god it feels great! It’s springy and coming up all the way now, when I let go of the clutch fast or slow there is no play at the top for me to pull up with!!! Now the trouble is that I almost stalled backing it of my garage because the clutch is letting out about halfway up lol. I am wondering if the nut being loose had caused the bolt to slip down lower and lower overtime and this caused my issue?? |
| The Following User Says Thank You to Swoldier86 For This Useful Post: | humfrz (12-29-2017) |
#119 |
Here is a picture of where I have it adjusted to now. The previous spot had the bolt coming through almost twice as long.
#120 |
This makes so much sense. I remember now, this is how the clutch pedal used to feel and it used to let out at the top almost my girlfriend just reminded me also. My clutch feels just like the new BRZ did today. So here is my theory.
I think the clutch bolt was loose and overnight the pedal slid down the bolt some so when I first tried it wouldn’t work. But after I pull-up the bolt slid back just enough and was grabbing to push the little rod in far enough and then it kind of stayed that way throughout the day. Kim telling you guys it feels great now and there is no play at the top of the clutch pedal I can’t pul up at all on it. I guess only time will tell but I tightened that nut up on the clutch adjustment so we will see. |
#121 |
Anyone have any thoughts on whether this was my issue? I feel so strongly that his is my issue.
Definitely ruled out hydraulic pressure a master cylinder now lol |
#122 | |
It seems like ol @Ultramaroon said something like "You need to adjust your clutch pedal back to the way it was." ........ back in post #4 ....... ![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Swoldier86 (12-29-2017), Ultramaroon (12-30-2017) |
#123 | |
I think me pulling up on the pedal allowed it to come back up just enough so that in the next Press it went in enough to allow me to engage. The pedal feels strong and crisp just like the one at the dealership today did. So time will tell if anything changes I will update everyone if not then it seems the winner is......Ultramaroon lol. Atleast I learned a lot about how to replace my clutch for when the day comes and how the clutch works and the hydraulic system works lol |
#124 |
Yep, we hope you have enjoyed your experience on the educational channel .....
humfrz |
#125 |
Adjusting the pedal height would not impact any of the many symptoms that you have mentioned.
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (12-30-2017) |
#126 | |
Also there is the mystery of the loose cruise interlock switch. That has to be adjusted just so after the the clutch pedal travel is dialed in. I'm not saying one way or another about the issue, just that something still doesn't add up.
| Urgent need of help | 86z | Issues | Warranty | Recalls / TSB | 6 | 11-12-2016 10:48 AM |
| Urgent help needed to identify blown engine | driftking96 | Engine, Exhaust, Transmission | 30 | 06-14-2016 10:32 PM |
| WTB: CAMSHAFTS urgent! | Ondreiko | Want-To-Buy Requests | 0 | 09-25-2014 01:17 AM |
| FS LED kits(Urgent) [WA] | GTiko | Australia Classifieds | 1 | 10-29-2012 10:43 AM |
