Old 12-29-2017, 12:37 PM   #1
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Who would want 12,000rpms to play with?
The 42psi turbo would be sweet, but 12,000rpms would be sweeter.
[ame="https://www.youtube.com/watch?v=1UwI-Rtuc38"]The 12,000rpm Subaru called Betty 😲 | Built by GotitRex - YouTube[/ame]
So destroking the engine...this would be removing stroke, so the piston doesn't travel as far. This reduces piston acceleration for a given rpm meaning there becomes a potential higher rev limit for the block. To do this one would need to build a custom set of light-weight, rods and a custom crank shaft, right, then build the head? The head would need some stiffer and lighter weight components like titanium springs, right? Would compression need to change? What needs to be changed for the transmission to handle the rpms?
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
TofuJoe (12-29-2017)
Old 12-29-2017, 02:01 PM   #2
-Willis-86touge
Drives: Stock
Fuel pump can only handle 8200 Rpms so was of time unless you change this too.
-Willis-86touge is offline   Reply With Quote
Old 12-29-2017, 02:18 PM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
If you are speaking about FA20 engine in ours, you'll hit oiling problems way way before 12K rpm. In fact, you probably won't reach even 9000, at least if you care for engine to outlast one race, with 8200 being more probable upper limit.
Old 12-29-2017, 02:23 PM   #4
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Yeah but did they get rid of the torque dip?
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Teseo (12-29-2017), Ultramaroon (12-29-2017)
Old 12-29-2017, 02:25 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
better to just buy this motor:
https://www.facebook.com/hhatada/posts/1956904927668033
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
strat61caster (12-29-2017), Zentec (01-01-2018)
Old 12-29-2017, 03:13 PM   #6
Originally Posted by mav1178 View Post
Dry sump would be sweet.
Old 12-29-2017, 03:26 PM   #7
Teseo
Drives: frs
More revs mean more wear, right?
Old 12-29-2017, 03:52 PM   #8
fang_gt86
FR Noob
fang_gt86's Avatar
Yes. Unless unless everything's coated with unobtainium.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in
fang_gt86 is offline   Reply With Quote
Old 12-29-2017, 04:11 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Or this:
https://www.synergypower.co.nz/
The Following 3 Users Say Thank You to Captain Snooze For This Useful Post:
strat61caster (12-31-2017), Ultramaroon (12-29-2017), Zentec (01-01-2018)
Old 12-29-2017, 04:34 PM   #10
Old 12-29-2017, 04:47 PM   #11
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
If you want to spin a motor to 12-13K buy a vehicle with a motor that spins 12-13K - A ZX Kowalski, an R1, or a CBR-RR Honda would be a place to start. You'll probably shoot your eye out, but it will probably hurt less than trying to spin an FA into five figure territory.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Spuds (12-29-2017)
Old 12-29-2017, 04:59 PM   #12
Captain Snooze
Drives: Red Herring
But a slightly more serious question is why? I mean 12k rpm is all well and good but from the little I have seen of modified Subaru engines big power is available at "normal" rpms. What benefit does high rpm bring?
Old 12-29-2017, 05:04 PM   #13
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
Not 12K rpms but this is probably the closest you'll get with an FA20 http://elementtuning.com/competition...r-wrx-fa20dit/
If I had the funds for a no expense spared build I'd be buying one of their turbo blocks with the big valve heads right now. Honestly seems like not bad of a deal for the upgrades done. They are not you're typical "built" motor.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 12-29-2017, 05:08 PM   #14
Detroiter
Detroiter's Avatar
I feel the same way about it to an extent. For the average build a motor that will make plenty of power at the standard rpm range.
Where the high rpm's give you benefit is where you can extend the power band of the BIG turbos out there. It's one of the many reasons you can see Evos running well over 1000whp from a 4 cylinder. They have built the engines to see excessive rpm's allowing for a turbo that will flow that much air to spool.
[ame="https://www.youtube.com/watch?v=iIRVrQ5cRks"]Mitsubishi Evo - Almost 2000hp 12k rpm - YouTube[/ame]
Raven
The Following 5 Users Say Thank You to Detroiter For This Useful Post:
Captain Snooze (12-29-2017), Irace86.2.0 (12-29-2017), JazzleSAURUS (12-30-2017), Ultramaroon (12-29-2017), x808drifter (12-29-2017)
USB play 86Boyz Electronics | Audio | NAV | Infotainment 8 11-15-2016 07:27 AM
Who wants to play? D K Tracking / Autocross / HPDE / Drifting 4 02-13-2016 01:42 PM
Anybody play GT5? barabia Scion FR-S / Toyota 86 GT86 General Forum 28 06-23-2013 02:50 AM
Anyone play GT5? Vmax911 Off-Topic Lounge [WARNING: NO POLITICS] 0 05-31-2013 09:26 PM
How to play with your 86 ZakD Scion FR-S / Toyota 86 GT86 General Forum 5 10-10-2012 11:50 PM
