Old 12-29-2017, 10:33 AM   #37955
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Cole View Post
Damn, that's a good point that I didn't even think about. Guess I'll pick up the parts today, drive to my parent's place early tomorrow morning and do it after waiting for 40 minutes or an hour.
Do you have an o2 socket? Need something that'll clear the wires. A shop might insist on dropping the header? Not sure how easy access is in your car.
Cold sucks for car work. I want to start on mine, but not in this weather! Need to at least swap front studs so I can put winter tires on though... Its warm today, getting up to 16 (-9C) so maybe it's time...
cjd is offline
Old 12-29-2017, 10:39 AM   #37956
Cole
Not a troll
Cole's Avatar
I do not have an o2 socket, but iirc, a 7/8ths(?) works very well. Should be easy enough to access by removing the passenger front wheel, removing the fender liner and havin' at 'er.
Edit: although before I resort to replacing it, I'll just check the fuses first.
Cole is offline
Old 12-29-2017, 10:46 AM   #37957
this is a real place about 30min drive(no traffic) from where I live.
https://www.beavertoyotacumming.com/...RoCRQUQAvD_BwE
I don't know where to start but I know I need to.
I would actually leave that dealer plate frame on the car!
Tcoat is offline
echo419 (12-29-2017)
Old 12-29-2017, 11:20 AM   #37958
cjd
cjd's Avatar
Drives: 2017 BRZ
Good point on the wheel well lining.
The trick is the wires on the sensor... sockets typically don't work so well. If you can get in from the side you'll be fine with a standard wrench, but a socket may be tough no matter how you work it. 7/8" or 22mm it is, though.
cjd is offline
The Following User Says Thank You to cjd For This Useful Post:
Cole (12-29-2017)
Old 12-29-2017, 11:35 AM   #37959
Cole
Not a troll
Cole's Avatar
Yeah, when I swapped the header, I just threaded the wires through the wrench and did it that way. The open ended wrench should work.
It's also not the fuse, so yay.
Cole is offline
The Following User Says Thank You to Cole For This Useful Post:
cjd (12-29-2017)
Old 12-29-2017, 11:50 AM   #37960
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
One of my Christmas presents from my daughter . I dare you to watch some videos.
Are they as weird as Tool music videos?
Andrew025 is offline
Old 12-29-2017, 11:52 AM   #37961
Cole
Not a troll
Cole's Avatar
Well, this is the last time I come to this dealership for anything. Service advisor, techs, really anyone who has hopped in my car has revved the piss out of it.
Cole is offline
Old 12-29-2017, 12:35 PM   #37962
Teseo
Drives: frs
Frig, turns out that I will actually need to replace my rear o2 sensor.
Anyone know what the dealership would charge to do it? Should be like an hour right? I need to get my oil changed, so I'll be there anyways and I don't overly want to do it myself with the weather we're having.
You can buy the o2 sensor and bring the car to a muffler shop, 15min labor. No need to cool down, they have gloves for those purposes
Teseo is offline
The Following 4 Users Say Thank You to Teseo For This Useful Post:
Cole (12-29-2017), humfrz (12-29-2017), Spuds (12-29-2017), Ultramaroon (12-29-2017)
Old 12-29-2017, 01:54 PM   #37963
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
How do you know?
Spuds is offline
Old 12-29-2017, 02:00 PM   #37964
Cole
Not a troll
Cole's Avatar
How do you know?
Because I saw them do it with my own eyeballs and earballs?
Cole is offline
The Following 2 Users Say Thank You to Cole For This Useful Post:
cdrazic93 (12-29-2017), Spuds (12-29-2017)
Old 12-29-2017, 03:31 PM   #37965
Spuds
The Dictater
Spuds's Avatar
Dare I ask what "earballs" look like?
Spuds is offline
Old 12-29-2017, 04:04 PM   #37966
"Logic is a pretty wreath of flowers which smell bad."
Ultramaroon is offline
Old 12-29-2017, 05:32 PM   #37967
Cole
Not a troll
Cole's Avatar
Oh, so I've found out that I should always buy my parts from a Subaru dealer.
Got a quote for the rear o2 sensor from the Toyota dealer since I was there anyways, and they wanted nearly $490 for it. Ended up going to the Subi dealer across the road from my apartment, and they wanted $266.
Absolute insanity.
Cole is offline
Old 12-29-2017, 05:34 PM   #37968
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Absolute insanity.
Good to know. That is a crazy difference!
I think I'll check with both when I need something to see who is cheaper.
Sapphireho is offline
