Old 02-27-2017, 12:37 AM   #827
Shiok86
Drives: GTS AT
Sorry for noob questions.
What caused the oil starvation and what would be a fix?
I assume the carbon fibre doors and mirrors are for looking tough as you already very light. So light that you mentioned you need a full tank of fuel to get a quicker lap! More downforce needed?
Any recommendation for a good mechanic and tuner in Perth? Thanks
Shiok86 is offline   Reply With Quote
Old 02-28-2017, 09:19 PM   #828
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
More weight reduction
stevo_12v is offline   Reply With Quote
Old 10-01-2017, 01:36 AM   #829
nzbrooke
Drives: 2013 Firestorm GT-86
Are you alive?
nzbrooke is offline   Reply With Quote
Old 10-21-2017, 06:59 AM   #830
stevo_12v
Yeah, not much to update.
Car is STILL at the workshop. Too much stuffing around with a 3rd party(who was meant to do the closed decking) and they couldn't pull their finger out, so I'm going for an outfront closed deck halves it looks like.
And most probably the Full-Race EFR 7163 turbo kit. #FirstInPerth
Car also needs new clutch, so going for an Exedy. And also a bigger radiator so a Koyo is on the shopping list too
Old 12-28-2017, 01:07 AM   #831
stevo_12v
Bit of an update
Crank has been 'WPC treated'. Pretty handy since the company WPC Treatment and Outfront are both in Torrance CA, a 45min or so drive.
Old 12-28-2017, 05:15 PM   #832
arthur93
Drives: Toyota 86 GTS
Hey man. Loving this build. What is your end power goal for this build. I too am looking at getting the full race kit but with the EFR6758. This won't be happening for a few years as still under warranty but doing all my research now. My aim is around the 220wkw on 98. I was looking at getting the CP Carrillo 10:1 pistons, CP conrods, GSC valve springs, Verus Engineering Denso radiator, ID1050X injectors and DW65C fuel pump. You seem to know quite a bit of what will be required. Do you reckon this will be sufficient for my power aim?
Will you be using the full race intercooler and their crash beam? Mine is going to stay road registered so I am looking at getting a custom intercooler to fit with the stock beam.
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
Old 12-28-2017, 06:01 PM   #833
stevo_12v
Thanks. I'm going for the Tunehouse "THR" kit, with Borwarger EFR 7163 twinscroll. Aiming for a reliable high 300's rwhp for track. Maybe go for a 400-ish rwhp dyno run and see what I can get before breaking the gearbox. Will be using Flexfuel obviously to achieve that.
Car is more track orientated, but I think a reliable 400rwhp in a 1200kg car would be nice.
Old 12-29-2017, 01:43 AM   #834
arthur93
Man that is going to be an absolute bullet. With that power/weight ratio you will be matching if not beating V8s.
Instagram: artym93
Old 04-05-2018, 04:25 AM   #835
stevo_12v
HKS GTIII-RS
Changed my mind on the turbo kit, luckily the workshop is snowed under with work and the cars on the back burner. Will be happy to max out 450 if possible.
Old 04-22-2018, 06:32 AM   #836
stevo_12v
HKS Turbo unboxed
Old 04-27-2019, 03:06 PM   #837
stevo_12v
Bit of an update
Old 04-27-2019, 04:17 PM   #838
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
YOU LIVE!!!!!
MS, CSCS, TSAC-F, CPT
Old 06-22-2019, 05:11 AM   #839
stevo_12v
Quick update.
Just waiting for the fabricator to finish up the custom 3in overpipe and 3in front pipe. Car should be ready in a few days. Some progress pics..
Old 06-22-2019, 10:37 AM   #840
Conman
Conman's Avatar
Drives: Red FRS
Wow this is serious
Conman is offline   Reply With Quote
36yroldvirginscar, keyboardwarrior, trd
Dumb idea to get auto tranny? tinnyms3 BRZ First-Gen (2012+) — General Topics 85 06-22-2012 05:22 PM
After this last winter is RWD such a bad idea Nate219BRZ Great Lakes 3 03-14-2012 05:03 PM
Any Idea of U.S. Pre-Order Numbers? markemark24 Scion FR-S / Toyota 86 GT86 General Forum 1 02-21-2012 12:29 PM
I have a great idea! ftw-86 Scion FR-S / Toyota 86 GT86 General Forum 56 07-24-2011 11:14 AM
Marketing Idea for the FT-86 JDMluv Scion FR-S / Toyota 86 GT86 General Forum 21 05-02-2011 05:29 AM
