Drives: Scion FR-S
Anyone seen these turn signal/drl less?
What do you guys think? Do they light up white and then when you turn your turn signal on, they blink amber?
http://www.ebay.com/itm/2013-Scion-F...#ht_4367wt_986 |
#2 | |
Yep!
Drives: 2015 WRX Sti
#3 |
Photojournalist
Drives: Firestorm FR-S, EG8 civic
only thing is if you install the resistors you'll have to hack up your stock harness...no bueno for that...so i would look into an adapter harness or something...well it may be tough finding an adapter which fits a bulb seat unless you make one...hmmm to ponder
#4 |
Drives: 86 ZN6
way overpriced!!
automation (a vendor here) will have these bulbs available soon for $10 |
| The Following User Says Thank You to 86_ZN6 For This Useful Post: | SkAsphalt (09-29-2012) |
#5 |
Photojournalist
I'm sure you can find the same bulb type for cheaper on ebay...just look for the correct base and bulb type with dual color LED's...also look for the correct resistor
#6 |
Drives: Scion FR-S
#7 |
Drives: 86 stock
I bought those lights after a long research
yeah, they are pricey but completely worth it. It's impossible these lights will cost $10, and they include a set of resistors, these are the brightest leds I've had, they even offset my new hids.
#8 |
Photojournalist
I found a thread where you don't need to hack wiring, just replace the relay under the dash http://www.ft86club.com/forums/showthread.php?t=11444
| Turn signal lights | Brzer | Cosmetic Modification (Interior/Exterior/Lighting) | 9 | 10-18-2012 01:36 PM |
| Turn Signal Repeaters | Ben_G | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-22-2012 10:26 PM |
| LED exterior and turn signal conversion | fenton | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-07-2012 11:33 PM |
| FR-S / FT-86 Prototype Sound Clips! Startup, On Track, Turn Signal, Seat Belt, Gazoo! | Harinjo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 85 | 01-26-2012 10:17 AM |
