Old 12-24-2017, 12:34 AM   #1
pr086
Drives: fast
Strange sound after exhaust install, please help identify.
I had my corsa exhaust installed yesterday and it sounds great. Took it out today for a longer drive and noticed once it warms up i get a strange sound at exactly 2400 rpm in all gears. Its like a high pitched screeching sound, the closest thing i can think of is when someones brakes are worn out. That screech kind of sound. Its most noticable when im off the gas and the revs are falling. If im going down a hill and the revs are holding right in that 2400 range it will continue to make the screech. I also noticed when i shut the car off it made a squeek when the exhaust vibrated from shutting down.
Whats the most likely cause of this? Is it something that will go away as it breaks in? If i get it back on the lift what should i be looking for?
pr086 is offline   Reply With Quote
Old 12-24-2017, 02:55 AM   #2
StraightOuttaCanadaEh
Wes
Mine didn't do that. Sure it's not a leak?
Instagram: @gt86ws
Old 12-24-2017, 03:16 AM   #3
I'd have the person who installed the exhaust check the usual suspects:
* exhaust leak at the connections
* see if part of the exhaust system is touching a part of the frame
* check for a lose hangar
* check welds for exhaust smudge (leakage)
If you don't see anything obvious, Bubba says to fire it up, while it's on the rack, rev to 2400 rpms then beat the hell out of it with a big rubber mallet till it's quiet ........
Old 12-24-2017, 03:18 AM   #4
Mine didn't do that........
Well, now THAT was a big fucking help !!.......
The Following 7 Users Say Thank You to humfrz For This Useful Post:
86geek (12-24-2017), D_Thissen (12-24-2017), JD001 (12-24-2017), Teseo (12-24-2017), Ultramaroon (12-24-2017), weederr33 (12-24-2017)
Old 12-24-2017, 04:49 AM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
But hey Humfrz? You did hear it coming?
The Following User Says Thank You to JD001 For This Useful Post:
humfrz (12-24-2017)
Old 12-24-2017, 09:30 AM   #6
pr086
Drives: fast
It only happens after the exhaust heats up a good bit. Does that point to one thing over another?
Old 12-24-2017, 10:12 AM   #7
pr086
Drives: fast
Ok if i grab the pipe leading into the muffler and give it a shake i can hear a squeek coming from towards the front of the car. I can imagine if its vibrating fast that squeek could be the screech i hear. What would squeek like that? A hanger? Would spraying with wd 40 help?
Old 12-24-2017, 11:24 AM   #8
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The flange between the mid pipe and front pipe has a donut gasket. That can be hard to get perfect and may need some adjustment. Tighten the spring bolts a couple turns and if that doesn't work LOOSEN them a couple turns.
I helped a friend install a catback and it took a few tries to get it perfect and get rid of the noisey leak it had.
guybo is offline   Reply With Quote
Old 12-24-2017, 12:47 PM   #9
ermax
ermax's Avatar
The donut bolts are spring loaded though. You tighten them all the way until they bottom out and then torque them to spec. Tightening them more than that has no impact on the donut because it’s just springs putting pressure on it. The only way to make it tighter would be to shim the springs or get stiffer springs.
Old 12-24-2017, 01:24 PM   #10
Cole
Not a troll
Cole's Avatar
@guybo and @ermax, you're both wrong. Maybe don't give advice if you don't know what you're talking about. The Corsa does not use the donut gasket, it uses a flat gasket.
For what it's worth, my Corsa does the same thing at around 2k or 2100, it's rubbing close to the rear subframe, and have just been too lazy to do anything about it.
Cole is offline   Reply With Quote
The Following User Says Thank You to Cole For This Useful Post:
Old 12-24-2017, 03:37 PM   #11
guybo
Huge E85 fan!
guybo's Avatar
It's possible to over tighten or unevenly tighten them. It probably wouldn't whistle but it's worth a look
Old 12-24-2017, 05:15 PM   #12
ermax
ermax's Avatar
I am not familiar with this exhaust. Guy made reference to donut gaskets which was what I was responding too. No need to be such an ass though. In my short history on this forum I’ve noticed that 100% of your comments are douchey. You only respond when you find a chance to be a douche. Handclap
Old 12-24-2017, 05:26 PM   #13
Good point ......... but, DANG.....the way you say it ........
Remember, the shelf elf is watching you .......
86geek (12-24-2017), Cole (12-24-2017)
Old 12-24-2017, 05:31 PM   #14
If part of the exhaust system is rubbing on another part of the car ..... WD-40 would, at best, be a temporary remedy.
You should find the root cause ...... then separate the offending pieces.
Yep, Bubba style ....... a crow bar and some baling wire ......
Cole (12-24-2017)
Strange woosh sound on some start ups Stefanchrstn Issues | Warranty | Recalls / TSB 6 04-16-2016 06:14 AM
Strange sound when shifting into first or second Jfheisenberg Engine, Exhaust, Transmission 35 06-23-2015 02:13 PM
Strange Rapid Fire Sound? Synkronicity Issues | Warranty | Recalls / TSB 29 06-03-2015 07:01 AM
strange fluttering sound at high rpm for SC JoonPrime Forced Induction 4 10-10-2014 02:17 PM
Yet another strange interior sound. DCStorm Issues | Warranty | Recalls / TSB 5 10-25-2013 11:05 AM
