12-24-2017, 01:04 AM | #29 |
Benched 86lb
Drives: Ultramarine FR-S
Honestly it does sound like there is an expensive problem with the clutch (unless the smell is a coolant smell or something else totally unrelated to the clutch system).
The Following 2 Users Say Thank You to pushrod For This Useful Post: | Swoldier86 (12-24-2017), Ultramaroon (12-24-2017) |
12-24-2017, 01:22 AM | #30 | |
humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Swoldier86 (12-24-2017) |
12-24-2017, 01:28 AM | #31 | |
* oil - smells like ..... burning oil * anti-freeze - smells sort of sweetish * clutch disk - smells like nothing else, except clutch disk * bad TOB - usually makes more noise than smell humfrz |
12-24-2017, 01:38 AM | #32 | |
Usually a bad TOB will squeal at you before it freezes up. Since the bearing is running all the time, a bad one can make one "squeal" sound, then when you push in on the clutch to make it work, the sound may be different ..... more of a howl than a squeal. humfrz |
12-24-2017, 01:45 AM | #33 |
Drives: 2013 BRZ Limited
There hasn’t been any sound that would indicate the TOB is bad.
The smell sort of smelt like brake pass, I just changed my pads all the way around a few weeks ago but I don’t think that is where the smell came from. I am going to see if the car smells after driving it to work tomorrow. My girlfriend just tested the clutch while I watched the slave cylinder move and she said it was sort of getting stuck at the bottom (which hasn’t happened to me yet). This may be a stupid question but does the brake fluid have anything to do with my clutch fluid, I ask because I changed brake pads but did not bleed the system. I wasn’t sure if I was supposed to. I just checked and my coolant reservoir is extremely low, slightly below the low line. Checked the car a few minutes ago and it started and went into gear just fine multiple times right upon starting from cold. |
12-24-2017, 02:02 AM | #34 | |
Did you change the brake pads or did someone change them for you .. ?? As far as your GF feeling the clutch sticks at the bottom, that just may be her feeling. On this car, the brake fluid system is separate from the clutch fluid system. As far as bleeding the brakes, it's a good idea to do so after the pads are changed. However, if no air was allowed in, it wouldn't be necessary. As long as the brakes don't feel "spongy", you're OK. When the car is cold, the coolant level is supposed to be about half way between the full and low marks. If it's just a bit low (like a cup or two) it would be OK just to add distilled or demineralized water. NOT tap water. Let us know how it's running after work tomorrow ...... humfrz |
12-24-2017, 02:23 AM | #35 |
Drives: 4wd zooks
If manual cars are parked for some time in a cold/wet/snow/icy environment.
Then the clutch plate can bind to a rusty flywheel and be difficult to engage first gear from a cold start. Rev matching can help to engage first gear. |
12-24-2017, 07:26 AM | #36 |
Urgent help needed please!
Try jacking both rear wheels off the ground and then start the car while in neutral. Push the clutch all the way to the floor and then push towards 1st while having someone watch the rear wheels. If the clutch isn’t fully disengaging then it will be hard to put in gear and it will make the rear wheels turn. That will rule out if it is clutch related or simply a cold temp problem.
The rear wheels should never turn while the clutch pedal is too the floor. If they do then you have a hydronic problem (which I doubt because the mechanic ruled that out) or the pressure plate is messed up. I suspect the mechanic is on the right track here. Just because a clutch isn’t slipping doesn’t mean it isn’t bad. The drive straps in the pressure plate can break causing it to not line up correctly which causes it to not fully disengage correctly. You also said you smelled what smelled like brake pads. Well a slipping clutch smells exactly like hot brake pads. Normally a bad pressure plate will make the engine vibrate like crazy. Could also be a bent release fork. I guess that is a common problem on this car. The intermittent part makes my lean towards the pressure plate more than anything. Edit: Don’t drag the problem out too long. If it’s hard to put in gear because of a clutch related problem then you are putting unnecessary wear on your syncros and the clutch is dramatically cheaper than rebuilding a tranny. |
The Following User Says Thank You to ermax For This Useful Post: | 22R (12-24-2017) |
12-24-2017, 08:50 AM | #37 | |
Yet it can be intermittent until it finally just lets go completely then the car won'move at all. The fact it smells leads me to back to the TOB. Odd it didn't squeal first though.
12-24-2017, 10:01 AM | #38 |
Update: Just got in the car a few minutes ago to head to pickup my girlfriends Christmas present before I go to work. Initial start up and it didn’t not want to go in gear I let go of the clutch pressed it back in and still nothing. Took my foot underneath the clutch and pulled up and it came up toward me (almost felt like it was stuck, not easy like free play but not extremely hard) I then pressed the clutch into gear and it went in fine. Currently driving right now with no issues and no noise.
12-24-2017, 10:19 AM | #39 |
My money is on the TOB which is binding and not letting the clutch fully disengage or engage. The TOB is only $17 but the labor isn’t cheap. You are out of warranty but not by much. There is a TSB on the TOB, maybe you could convince the dealer to do it for you. Probably not though.
12-24-2017, 10:36 AM | #40 | |
The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (12-24-2017) |
12-24-2017, 11:46 AM | #41 |
So how positive are you that is the TOB?
If it is the TOB I might as well upgrade the clutch and everything while they have everything taken apart since labor will be the most expensive part of this job. If I had a lift and stuff I would rather do it myself but I don't so I will paying a lot im sure. |
12-24-2017, 11:53 AM | #42 | |
The Following User Says Thank You to Tcoat For This Useful Post: | ermax (12-24-2017) |
Similar Threads | ||||
Urgent need of help | 86z | Issues | Warranty | Recalls / TSB | 6 | 11-12-2016 10:48 AM |
Urgent help needed to identify blown engine | driftking96 | Engine, Exhaust, Transmission | 30 | 06-14-2016 10:32 PM |
WTB: CAMSHAFTS urgent! | Ondreiko | Want-To-Buy Requests | 0 | 09-25-2014 01:17 AM |
FS LED kits(Urgent) [WA] | GTiko | Australia Classifieds | 1 | 10-29-2012 10:43 AM |
