Old 12-23-2017, 11:03 PM   #15
Originally Posted by Swoldier86 View Post
No I haven’t bled the system or filled it. Should I do this?
I just left work, started the car and put it into reverse on the first try with no trouble it has been sitting there for about 8 hours the temp is about 45 degrees.
Well, first off, I would suggest that you check the fluid level in the reservoir.
If it's a little low, just add some fluid.
If it's really low, some air might have entered the system, which would cause the clutch not to work too good. In that case, you should bleed the clutch hydrolytic system.
If the fluid is low, check for leaks, it went somewhere .....
Now, keep in mind, ol humfrz is usually the one that will suggest the easiest and simplest "fix" ....... which usually doesn't fix the problem .......
I hope you get it fixed so Santa doesn't have to bring you a new master and slave cylinder, hoses, clutch disk, flywheel, pressure plate and throw out bearing........
Old 12-23-2017, 11:28 PM   #16
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Slave cyl is on top. It's actually real close to the master. Shortest clutch hydro hose I've ever seen.
If it's just hard to get into low gears when it's cold, there is no problem.
If you've lost any fluid in the cluch fluid reservoir, you have a leak somewhere and will need to replace whatever is leaking.
pushrod is offline   Reply With Quote
The Following User Says Thank You to pushrod For This Useful Post:
Swoldier86 (12-24-2017)
Old 12-23-2017, 11:42 PM   #17
Swoldier86
Swoldier86's Avatar
Drives: 2013 BRZ Limited
Thanks again for all of your help.
So update: their was a smell of something burning last night after driving but I had the A/C on in the car for the first time in a while and didn’t know if this would have caused the smell somehow. The fluid reservoir is full and the fluid is a yellowish see through color so it’s not dark or anything.
I took a picture of the Slave Cylinder just now and I am going to post it. I believe the rubber boot is not on correctly and this may be my issue but I am not sure.
Swoldier86 is offline   Reply With Quote
The Following User Says Thank You to Swoldier86 For This Useful Post:
humfrz (12-24-2017)
Old 12-23-2017, 11:44 PM   #18
Swoldier86
Swoldier86's Avatar
Once I figure out how to upload a picture lol.
Old 12-23-2017, 11:56 PM   #19
Post to imgur then link image here inline.
Swoldier86 (12-23-2017)
Old 12-23-2017, 11:56 PM   #20
Swoldier86
Swoldier86's Avatar
Name:  Slave Cylinder.jpg
Name:  Slave Cylinder 2.jpg
Old 12-23-2017, 11:59 PM   #21
looks fine.
Old 12-23-2017, 11:59 PM   #22
Swoldier86
Swoldier86's Avatar
Thank you.
I got onto my laptop and emailed to myself then attached it. I guess either way works, or is imugur better?
Old 12-24-2017, 12:00 AM   #23
Swoldier86
Swoldier86's Avatar
looks fine.
So the slave cylinder looks fine?
I thought maybe the rubber boot was supposed to cover the whole piece and it looks like it didn't go back or something.
This is the piece that the mechanic looked at and had me press in on the clutch while he watched it and after I pressed the clutch he watched it move and then determined I need a new clutch....
Old 12-24-2017, 12:07 AM   #24
The pushrod goes through the dust boot into the piston. My guess is he watched it move normally and ruled out the clutch hydraulics as a source of the problem.
humfrz (12-24-2017)
Old 12-24-2017, 12:11 AM   #25
Swoldier86
Swoldier86's Avatar
Okay, so what about the burning smell? Me and my girlfriend could smell it last night after we got home and I pulled into the garage. I do not smell it in the cabin while driving.
I didn't check it tonight for some reason when I got home but my girl went downstairs to the garage to do some laundry and she said she could smell it.
Old 12-24-2017, 12:18 AM   #26
Swoldier86
Swoldier86's Avatar
Is this your first winter with it? If so it may be as simple as you need to change the oil in the tranny. Many people have issues getting it into first or second when it gets cold out. Changing the oil seems to help.
Yes this is my first winter with the car. So I need to maybe change the transmission fluid?
Old 12-24-2017, 12:25 AM   #27
I'm out of guesses.
Old 12-24-2017, 12:44 AM   #28
Swoldier86
Swoldier86's Avatar
I seen a vid on youtube where the throw out bearing gets too hot or something. The video showed the bearing and it looked melted. This could be the smell maybe?
So if it is the throwout bearing, could that be something that is intermittent? I apologize I am asking so many questions but I truly appreciate your time and advice, I love my 86 and want to take care of it so I am trying to find the issue so I can fix it asap. Also hoping it doesn't cost me a kidney and a leg though lol.
Urgent need of help 86z Issues | Warranty | Recalls / TSB 6 11-12-2016 10:48 AM
Urgent help needed to identify blown engine driftking96 Engine, Exhaust, Transmission 30 06-14-2016 10:32 PM
WTB: CAMSHAFTS urgent! Ondreiko Want-To-Buy Requests 0 09-25-2014 01:17 AM
FS LED kits(Urgent) [WA] GTiko Australia Classifieds 1 10-29-2012 10:43 AM
