Old 12-23-2017, 02:12 PM   #1
Jared.FR-S
Drives: 13 Scion FR-S
New to Cars
So I am starting to get into cars (I’m a noob!) and I own a ‘13 FR-S.
A few problems I am having with it:
-Squealing noise when I start it up in the morning (30-45 degrees) not sure what it is??
-Check engine light, says it’s the o2 sensor, the o2 sensor has been replaced twice and it’s burned them up. I do not have a header but I do have a Borla axle-back exhaust on it ( pretty sure, haven’t jacked it up to see what exactly is going on under it ) . I got the car modified like this and not sure if it was tuned... or if it even needs a tune. I’ve been to multiple mechanics
Jared.FR-S is offline   Reply With Quote
Old 12-23-2017, 02:53 PM   #2
Manual transmission? If so the squeal is probably the clutch throw out bearing. If it is starting to go it is always the worst on startup.
Axle back will not cause an O2 sensor issue. Positive there isn't a header?
Old 12-23-2017, 03:03 PM   #3
Jared.FR-S
It’s automatic
And there is no header, I’m positive
The Following User Says Thank You to Jared.FR-S For This Useful Post:
Tcoat (12-23-2017)
Old 12-23-2017, 03:08 PM   #4
It’s automatic
Hmmmm I am baffled then.
Old 12-23-2017, 03:13 PM   #5
Hello Jared.FR-S and welcome to ...... The Forum .......
On your next cold start, I suggest you open the hood, lean over the engine, have someone else start the car and see (hear) if you can isolate where the squeal is coming from.
Since your car has an AT, my guess would be a lose serpentine belt or a bearing in the idler pulley or A/C compressor or the alternator.
The axle back muffler shouldn't require the engine to be "tuned" nor should it cause a O2 code to be thrown.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
DaBoBo21 (12-30-2017), strat61caster (12-23-2017), why? (01-07-2018)
Old 12-23-2017, 03:22 PM   #6
Jared.FR-S
Ok I’ll do that thanks!
I Just need to figure out this o2 sensor issue.
Old 12-23-2017, 04:38 PM   #7
Someone will be along shortly to help you out with that sensor thing.
That is waaay over my pay grade ....
Old 12-23-2017, 06:52 PM   #8
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Sounds to me like you got someone else's shity tune. Contact previous owner ask them what kind of shity tune they put in there. Once you know bring everything thing back to stock factory settings.
The start up wine could be a lose belt. I guess since there is no vid or something.
Old 12-24-2017, 04:50 AM   #9
scottman
scottman's Avatar
Drives: 13 mt fr-s
You could try an o2 sensor defouler, they are a super cheap option they may help ya'
scottman is offline   Reply With Quote
Old 12-24-2017, 05:22 AM   #10
Jared.FR-S
That will fix the light but what if that leads to damaging something else?
Old 12-24-2017, 06:32 AM   #11
scottman
scottman's Avatar
Drives: 13 mt fr-s
Could be caking up your sensors by running too rich.
Or burning them out by running too lean.
Can be caused by an aftermarket exhaust your car doesn't like.
Try and find out if it was retuned...
Old 12-30-2017, 08:28 AM   #12
Jared.FR-S
Update: So the car was never tuned. So now what?
Old 12-30-2017, 11:02 AM   #13
davidsn_670
Drives: 2015 Scion FRS
Are you replacing them with aftermarket 02 sensors or OEM ones? Also, no other codes? And how many miles on the car?
davidsn_670 is offline   Reply With Quote
Old 12-30-2017, 12:54 PM   #14
stevesnj
stevesnj's Avatar
Squeal could be a bad serpentine belt.
My 2016 Build thread
Kit cars pushrod Other Vehicles & General Automotive Discussions 56 09-09-2022 02:11 PM
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 2 07-03-2016 02:50 AM
CARS AND BAGELS/CARS AND CAKES car meet (SAN DIEGO) edwinisdumb15 Southern California 0 06-26-2016 11:57 AM
Why do people lean on their cars when posing with their cars? tzhu07 Other Vehicles & General Automotive Discussions 26 03-15-2014 08:51 AM
Kickstarter: MODARRI CARS (Cars for kids) dem00n Off-Topic Lounge [WARNING: NO POLITICS] 1 02-04-2014 12:19 PM
