Old 12-21-2017, 12:57 PM   #15
Originally Posted by NRXRaptor View Post
I remember a long time ago when I was in first grade or so I came to grips with my mortality. I realized for the first time that I will one day die. Took me a few days to get over it but boy was I scared for a while. Thanks - or not - for reminding me
Yep, I was about that age when I lied to my father, for the second time, about watering the hogs.
During the beating he gave me ....... I thought I was going to die (be killed).
That was the LAST time I lied to my father ........
Zentec (12-23-2017)
Old 12-21-2017, 01:35 PM   #16
I have probably changed 100+ exhausts over the years. I think maybe 2 of those were done by actually unscrewing the nuts.
@Tcoat with his main muffler shop tool ......
Old 12-21-2017, 02:49 PM   #17
Nope. Too advanced.
humfrz (12-21-2017)
Old 12-21-2017, 04:46 PM   #18
Zentec (12-23-2017)
Old 12-21-2017, 06:03 PM   #19
Scotian86
Drives: 2017 860 edition
If you soak them in penetrating fluid PB blaster let it soak then bang them with a hammer and spray again it will aid the capillary properties to penetrate deeper. Tighten a tad then loosen.
Scotian86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Scotian86 For This Useful Post:
humfrz (12-21-2017), Ultramaroon (12-21-2017)
Old 12-21-2017, 08:03 PM   #20
I reckon the handle and frame just gets in the way ??........
Old 12-21-2017, 10:35 PM   #21
I'm a minimalist.
Old 12-21-2017, 11:19 PM   #22
I'm a minimalist.
Is that the same tool you used to saw your way out of the brig ...... back in the day .......... ??
Old 12-21-2017, 11:33 PM   #23
I made E-6 in 5 years, skipping testing for both E-5 and E-6 until my command threatened me with NJP for dereliction of duty. That was the most trouble I ever got into in my military career.
Old 12-22-2017, 12:27 AM   #24
Well, ya ....... maybe that was all that was on record.........
Reminds me of the time when I was a young army officer and got beat up by an Asian lady.
A fellow officer and I had duty officer when we got a call from the NCO club manager saying that this sergeant E-8 from our unit that was drunk and out of control and unless we came and got him, they were going to call the MPs.
So, Lt Miller and I went over the NCO club and collected up sergeant Vorhees and drug and dumped his body into the back of out jeep.
We had already looked up where he lived ....... yep on the 4th floor of the NCO housing quarters (no elevators). Now, he was a BIG man and it was all we could do to drag him up 4 flights of stairs.
We got to the apartment and knocked on the door and his Asian wife "attacked" us, literally yelling nothing but Korean at us. Lt Miller contained her and I drug the good sergeant inside the apt. Lt Miller explained to me that the reason why the wife attacked us is that she thought WE were the ones who got him drunk.
Just another night as duty officer .....
THE END
Old 12-22-2017, 12:53 AM   #25
Well, not that week at least. You were on duty.
humfrz (12-22-2017)
Old 12-22-2017, 05:50 AM   #26
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
1) soak in PB Blaster or WD40 overnight. then hit them in the morning too.
2)make sure you have the right size socket. Exactly.
3) use a breaker bar and hammer/dead blow
If that doesn't work, you're kinda fuckled. Then you start heating it up. If that's doesn't work, then you have some work to do either drilling the bolt out or cutting stuff up
Thre OEM muffler isn't worth much, you may just want to replace the mid pipe too and just remove that pipe and the muffler together.
guybo is offline   Reply With Quote
Old 12-22-2017, 09:10 AM   #27
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
I just swapped front pipe and overpipe last night.
Use wire brush to clean the threads before anything. This way the nut doesn't get jammed on the rusty threads when removing it.
Spray pb blaster the night before.
Put a wrench on it and use dead-blow to tap and work the nut loose.
One the nuts and bolts are out, either replace them or soak them in varsol before putting them back.
Use some anti-seize on threads when assembling
or
if everything fails, whip out the dremel with cutoff wheel
Sideways is offline   Reply With Quote
Old 12-23-2017, 05:24 PM   #28
Zentec
Drives: 2017 Toyota 86
Yea I remember when my grandma would use the wooden spoon on my older brother when that broke my grandpa would use his hand that did not break and my brother could barely walk and that was the last time anyone was disobetant or rude to anyone. It should take one incident and you learn the proper respect. Now child services this and that and soft rude mediling kids. I took the direct approach with my kid. Simple on the wall you draw an out line of a hand, stick, paddle with holes, gun, grave stone. Punishment starts at the hand and explain it goes up from there. I was always partial of using a paddle but my boy was so good I never had to use any of it. Lol.
Zentec is offline   Reply With Quote
Muffler impossible/difficult to remove? Autocon Engine, Exhaust, Transmission 29 11-22-2019 07:34 PM
How to remove the stock antenna post_break DIY (Do-It-Yourself) Guides 27 07-06-2018 05:51 PM
WTB stock muffler tips and stock fender inserts Whitel Want-To-Buy Requests 0 04-24-2017 01:30 PM
How do you remove stock FRS GPS module? DC2R Electronics | Audio | NAV | Infotainment 1 05-06-2014 11:19 PM
Ideal resonator placement to remove drone on muffler deletes? CaptainSlow Engine, Exhaust, Transmission 22 05-20-2013 09:34 AM
