Old 12-19-2017, 08:04 AM   #1
cliff
Drives: subaru brz
cliff
Does anyone know how to adjust headlights level?
cliff is offline   Reply With Quote
Old 12-19-2017, 08:20 AM   #2
http://www.ft86club.com/forums/showthread.php?t=98115
http://www.ft86club.com/forums/showthread.php?t=98668
http://www.ft86club.com/forums/showthread.php?t=57122
Old 12-19-2017, 09:33 AM   #3
gtengr
Drives: 2017 BRZ
cliff
cliff, if you have a 2017 I don't think the LED's are adjustable, or at least I haven't figured it out
gtengr is offline   Reply With Quote
Old 12-19-2017, 10:08 AM   #4
Tokay444
Anti stance.
Tokay444's Avatar
They auto level. There is an indicator light in the cluster that notifies you that this process is happening, Usually just after start-up.
Old 12-19-2017, 10:17 AM   #5
gtengr
Drives: 2017 BRZ
I have my doubts that the LED's do. Unless it's done in a way that is hard to detect visually. My M3 had auto level and it was obvious from behind the wheel. When I'm driving adjacent to thick foliage/walls in the BRZ I can see the beam pattern strictly following the pitch of the car.
Old 12-19-2017, 10:44 AM   #6
They do auto level on the 17s. Probably not as good a system as an M3 though.
Old 12-19-2017, 11:17 AM   #7
spike021
spike021's Avatar
They definitely do. I’ve noticed it while driving in darkness. Again, like Tcoat said it’s probably not as precise as other car’s but it does work.
spike021 is offline   Reply With Quote
Old 12-19-2017, 11:21 AM   #8
STV3
Señor Member
STV3's Avatar
cliff
STV3 is offline   Reply With Quote
Old 12-19-2017, 11:48 AM   #9
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
cliff
Slammillionaire is offline   Reply With Quote
Old 12-19-2017, 11:55 AM   #10
gtengr
Drives: 2017 BRZ
"Works" and "works effectively" are 2 different things I guess. I don't think I've ever been flashed by oncoming traffic with my low beams on in +20 years of driving until I got this car. Now it is a regular occurrence. The height of the low beam looks correct when I park on a level pad with a wall in front of it. My M3 had a mechanical adjustment for the beam height that worked independently of the auto leveling. I've looked and don't see an easy way or really any way to adjust on the BRZ. Maybe someone will design a turn buckle for the leveling arm in order to provide some adjustment because I have had the sense that the beam height is too high from day 1 of ownership.
thanks,
cliff
Old 12-19-2017, 12:25 PM   #11
Tokay444
Anti stance.
Tokay444's Avatar
I have LEDs and they autolevel.
Old 12-19-2017, 12:32 PM   #12
gtengr
Drives: 2017 BRZ
Can you describe the situations in which it is apparent from the driver's seat?
Old 12-19-2017, 01:02 PM   #13
Tokay444
Anti stance.
Tokay444's Avatar
Starting the car on a hill.
Old 12-19-2017, 01:02 PM   #14
Tokay444
Anti stance.
Tokay444's Avatar
Will you please describe the situations in which it is apparent from the driver's seat?
Driving off the cliff SquadRon Off-Topic Lounge [WARNING: NO POLITICS] 12 09-05-2017 05:14 AM
Idiot drives his M3 off a cliff DIM Other Vehicles & General Automotive Discussions 32 06-14-2013 09:40 PM
Are you willing to push your car off a cliff? ayau Tracking / Autocross / HPDE / Drifting 118 03-01-2013 09:27 AM
