Old 11-19-2017, 07:40 PM   #2269
stevesnj
stevesnj's Avatar
Originally Posted by jay_reef15 View Post
what color is this?
2012-2015 it's Ultramarine, 2016-17 It's Oceanic Blue (Lapis Blue Pearl K3X) Slightly more pearl and purple flake compared to Ultra.
My 2016 Build thread
Old 12-11-2017, 03:58 PM   #2270
Lust
Drives: 2017 Subaru BRZ
This thread needs some love
Lust is offline   Reply With Quote
The Following 10 Users Say Thank You to Lust For This Useful Post:
ApexEight (12-22-2017), BirgeyT1 (01-10-2018), Clipdat (12-11-2017), DaBoBo21 (12-22-2017), GalloVecchio (12-21-2017), Jive Turkey (12-20-2017), mmmcambelsoup (12-12-2017), sqd (01-02-2018), tintumz22 (12-17-2017), Wasabi (06-14-2020)
Old 12-11-2017, 04:19 PM   #2271
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
dude what shop is that? i wanna take my car to somewhere that clean!
Originally Posted by humfrz
I'm old and lazy
The Following 2 Users Say Thank You to Clipdat For This Useful Post:
Lust (12-11-2017), tintumz22 (12-17-2017)
Old 12-11-2017, 04:27 PM   #2272
Lust
Status Auto Inc in Redwood City. Shoot me a PM if you're local and I can put you in touch with the shop owner.
The Following 2 Users Say Thank You to Lust For This Useful Post:
Clipdat (12-11-2017), Ro_Ja (12-23-2017)
Old 12-20-2017, 11:17 PM   #2273
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by Dogster70 View Post
does anyone also know if ill be able to fit 18x8.5 +45 offset in the front, 18x9.5 +45mm offset WITH A DEEP LIP in the rear? and if so what would a good tire be?
stock struts?
+45 will never have a deep lip. you get that by going lower offset. much lower.
245/40 front 265/35 rear or just do square setup all around
Jive Turkey is offline   Reply With Quote
Old 12-21-2017, 09:55 AM   #2274
GalloVecchio
GalloVecchio's Avatar
Drives: Not a BRZ
Wheels: WedsSport SA10-R 18x9.5 +38 offset
Tires: Bridgestone S04 Pole Position 255/35/18
Coilovers: Fortune Auto 500
GalloVecchio is offline   Reply With Quote
The Following User Says Thank You to GalloVecchio For This Useful Post:
Leonardo (12-21-2017)
Old 12-21-2017, 10:29 PM   #2275
adrixe
adrixe's Avatar
Drives: 2014 Subaru BRZ
Im planning on getting the konig rennforms 18x9+38. I'm lowered 1" on eibach prokit.
Will that fit ok? And what is the meatiest setup I could do? Looking to buy them by boxing day so hopefully someone can help me out. Thanks!
Sent from my Pixel XL using Tapatalk
adrixe is offline   Reply With Quote
Old 12-21-2017, 11:10 PM   #2276
Lust
You can probably fit a 245-255. I wouldn’t go wider. Why not 17 if you’re going 9” wide?
The Following User Says Thank You to Lust For This Useful Post:
j.F.c.R.a.S (03-25-2018)
Old 12-22-2017, 08:52 PM   #2277
arthur93
Drives: Toyota 86 GTS
Here is my meaty tyre set up.
Enkei RPF1 17x9 +35 with Yokohama Advan AD08R 245/45R17
Check out my build: http://www.ft86club.com/forums/showthread.php?t=122736
Instagram: artym93
arthur93 is offline   Reply With Quote
The Following 3 Users Say Thank You to arthur93 For This Useful Post:
ApexEight (12-22-2017), DesertLava (12-22-2017), Spankopotomous (05-31-2021)
Old 12-22-2017, 09:57 PM   #2278
DesertLava
Drives: '17 Hot Lava
This is beautiful. Thinking of running the exact same wheel on my Hot Lava. Do you have stock suspension? Will 17x9+35 with those tires rub on stock suspension?
Sent from my Nexus 6P using Tapatalk
DesertLava is offline   Reply With Quote
The Following User Says Thank You to DesertLava For This Useful Post:
arthur93 (12-23-2017)
Old 12-22-2017, 10:35 PM   #2279
ApexEight
Drives: 2014 Subaru BRZ Limited 6MT SSM
@arthur93 how does that car feel with that wheel and tire setup? I've read some people say, especially those that are still NA, say that too much grip can take away the fun from the car and can "over-tire" that chassis. Thoughts?
ApexEight is offline   Reply With Quote
Old 12-23-2017, 12:12 AM   #2280
arthur93
Thanks man. Definitely love the RPF1. A very common wheel but I have only seen the bronze in 17x9 +35 on a blue brz and never on a white one on these forums.
I am currently running Bilstein B16 Coilovers. These reuse the stock front hats so also have Verus Engineering Camber plates for the front and Verus Engineering rear LCA. Front is dropped 30mm and rear 35mm. Have -1.7 camber up front and -1.5 in the rear.
There is a thread dedicated to the RPF1 in a 17x9 +35. I recently posted in it so it should still be on the first page. I don't believe you will rub on stock suspension but you will definitely have poke.
Instagram: artym93
The Following User Says Thank You to arthur93 For This Useful Post:
DesertLava (12-25-2017)
Old 12-23-2017, 12:17 AM   #2281
arthur93
It grips and grips and grips. Personally that is what I am after. I intend on tracking the car quite a bit and currently don't have enough money to have a dedicated track wheel/tyre combo. But personally, that is what I am after. I love grip. For n/a 245 is definitely not needed. Can easily get my tyres in a 225 and still have heaps more grip. But I much prefer the look of 17x9 RPF1 to the 17x8 as mine have the concave look. Also I intend on going turbo before these tyres are gone.
I do quite a few skidpans as well. I have kept my stock wheels with the prius tyres for that. I will however be using my new set up at a wet skidpan next week. My mate has the same 245 tyre but on 18" and he drifts like nuts so definitely still doable. That is next saturday. Happy to report the results.
Instagram: artym93
The Following 2 Users Say Thank You to arthur93 For This Useful Post:
ApexEight (12-23-2017), DesertLava (01-03-2018)
Old 02-05-2018, 06:55 PM   #2282
NAEightySix
Drives: 2015 Scion FRS 6MT (Asphalt)
RPF1s in SBC... 18x9.5 +38 paired with 265/35/18 Pirelli P Zero Rosso (got an amazing deal on them).
Feels amazing, and not noticeably heavier than stock. I absolutely love the grip, but it still needs rear LCAs and an alignment.
NAEightySix is offline   Reply With Quote
The Following User Says Thank You to NAEightySix For This Useful Post:
Raven86Project (02-05-2018)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
