Old 12-05-2017, 08:59 PM   #99
Chen
Regional Moderator
Chen's Avatar
Drives: 00-AP1 20-A90 06-Z33 07-FA5 93-NA1
Hey, I'm not the one who got the delinquent notice ...... with those big bucks you moderators make, you would think you could afford to pay your bills .....
Or, do I have to come over to the regional forum and tend to you ......??
I only get to mod the nw section. I can’t hang out with you peasants in the main section.
Chen is offline   Reply With Quote
The Following 2 Users Say Thank You to Chen For This Useful Post:
humfrz (12-05-2017), Tcoat (12-05-2017)
Old 12-05-2017, 09:06 PM   #100
Well, SOMEONE has to lend some civility to the unwashed masses .....
Old 12-06-2017, 01:21 AM   #101
Chen
Regional Moderator
Chen's Avatar
Thank you for doing your part. I knew it was left in good hands. If you run into a rut. Don’t look for me.
The Following User Says Thank You to Chen For This Useful Post:
humfrz (12-06-2017)
Old 12-08-2017, 04:43 AM   #102
AZ94
Drives: 2017 Toyota 86
Hey guys I've had a Toyota 86 for a few weeks now and I'm getting used to the car and I'm noticing some things that I wanted to ask about.
How long does it take for your car to go from start up RPM to below 1000 RPM? I know on cold days it'll take longer for the engine to warm up but on most other cars I've driven it doesn't take this long. It was 35 degrees out and it took at least 5 minutes to drop to 1000 RPM and I was wondering if that's normal for this car...
It's a manual transmission with TRD exhaust. I'm probably going to install the TRD intake as well which'll clear up the engine bay and get rid of the sound tube...it makes me feel like I'm listening to more a "resonating" sound as opposed to the actual engine sound.
AZ94 is offline   Reply With Quote
Old 12-10-2017, 03:03 PM   #103
With my 2013 FR-S, when it's about freezing outside, and my car is cold and in my garage, it takes about a minute for it to come off of "fast idle". In the summertime, it takes it about 30 seconds.
Old 12-10-2017, 03:17 PM   #104
I have had the car through temperatures in the negatives and it has never taken more than about 2 minutes to drop. Keep in mind that even when the idle drops the car is still not up to operating temperature so take it easy for the first few miles.
Old 12-10-2017, 06:20 PM   #105
AZ94
Hmm ok thanks maybe I'll get it checked out. What I notice is when I start the car, the needle for engine temp is well below the line for Cold as expected since it's freezing outside while the RPM's sit at about 1500-1600. As the car slowly warms up, the needle slowly rises to the Cold line which takes a few minutes. Once it hits that line, that is when the RPM's drop to normal idle speeds below 1000. So everything seems like it's working properly but the process takes up to 5 minutes which is longer than every other car I've driven.
Thanks for the responses!
Old 12-10-2017, 06:25 PM   #106
These cars have an extremely large cooling system for the engine size so they do take a bit longer to warm up than some. Sounds like everything is fine.
Old 01-31-2018, 03:49 PM   #107
ShadowWolf_99
ShadowWolf_99's Avatar
Drives: 10 Series #895
Looking for info on the pioneer head unit to see if anyone has figured out how to do a custom start up image. Let me know if this has been covered elsewhere and post the link to the correct thread thanks!
Sent from my SM-G950U using Tapatalk
PDX86 / 86 Sessions / 86Squad / DarkSquad
ShadowWolf_99 is offline   Reply With Quote
Old 01-31-2018, 03:58 PM   #108
Nobody has been able to crack that one.
Old 02-15-2018, 01:52 AM   #109
juan_11
Recently been looking into getting window visors and some hood pins but not sure which ones to get. Any suggestions?
juan_11 is offline   Reply With Quote
Old 03-18-2018, 12:09 PM   #110
tay.green
Drives: Toyota 86 2018 Halo
Read through and very informative, thanks guys.
tay.green is offline   Reply With Quote
Old 10-06-2018, 03:34 PM   #111
RyMi
Drives: 2001 Honda Accord
What to buy with a 13k Budget?
Hello! I've chosen the 86 platform for my next daily car after my 300k mile 2001 Accord finally gave out on me. My budget right now is around 13k, and ideally I want a 2013 BRZ Limited with a manual transmission. Those, I can find with around 80-90k on them.
However, I can also find 10 series FRSs with a manual with like 50k on them for about the same price. I prefer the Subaru, and thats what I've been lusting over for the longest time, but should I put aside my preferences and go with the FRS?
I'll be driving the car on almost strictly highways to class during the week and spirited driving on the weekends. No track days or anything.
I'm also assuming I won't be able to talk a dealer down from $14k (around 60k miles on those) or so to 13k on a BRZ Limited. Am I wrong?
PS: Please forgive me if this is in the wrong spot, I'm new here. Let me know and I'll be happy to ask my question in the appropriate thread
RyMi is offline   Reply With Quote
Old 10-06-2018, 03:39 PM   #112
JD001
JD001's Avatar
Drives: Subaru BRZ
Have I accidentally found 'Random Thoughts - part trios'.
New Member & have question? Read here first! ichitaka05 BRZ First-Gen (2012+) — General Topics 6 10-22-2021 05:43 AM
New Member - paint question kberkel BRZ First-Gen (2012+) — General Topics 21 03-26-2014 09:38 PM
New Member FRSupra Scion FR-S / Toyota 86 GT86 General Forum 22 12-20-2012 11:25 PM
New member brz007 BRZ First-Gen (2012+) — General Topics 2 06-02-2012 09:37 AM
New Member/ Quick question sikse7en Scion FR-S / Toyota 86 GT86 General Forum 3 11-28-2011 08:57 PM
