Old 12-08-2017, 03:09 PM   #463
Leonardo
Country Boy 4 Life
Leonardo's Avatar
via Imgflip Meme Generator
I LIKE TIRES!
Old 12-08-2017, 07:48 PM   #464
funwheeldrive
If I owned a RX8 I would wrap the car in camo and put in some fake radiators just to mess with people.
The Following User Says Thank You to funwheeldrive For This Useful Post:
vh_supra26 (12-10-2017)
Old 12-09-2017, 12:59 PM   #465
vh_supra26
Site Moderator
Drives: Supra
vh_supra26 is offline   Reply With Quote
The Following 2 Users Say Thank You to vh_supra26 For This Useful Post:
gymratter (12-09-2017), Leonardo (12-09-2017)
Old 12-09-2017, 03:02 PM   #466
LancePower
Drives: 2020 BRZ tS
I've never seen a test mule with those wheel hub thingies on before.
LancePower is offline   Reply With Quote
Old 12-09-2017, 03:17 PM   #467
gymratter
Drives: BMW
MB had something similar.
gymratter is offline   Reply With Quote
Old 12-12-2017, 04:36 PM   #468
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I wonder if part of their "cooling" issues mazda is running into is because theyre using the RX8 body. One could design a passive airflow design that allows for heat vents and side vents and have the space for those extra cooling bits. Don't know. Not an engineer.
Old 12-12-2017, 07:19 PM   #469
reni
Nobody beats the B[I|R]Z
reni's Avatar
Drives: shopping cart i stole from walmart
Alternate possibility - what if Mazda is actually planning is not a rotary but a new coupe based on their turbo 4?
reni is offline   Reply With Quote
Old 12-12-2017, 11:16 PM   #470
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Well, if this really is just a power train mule, it's likely they have extra cooling capacity to experiment with. It's cheaper to design a one-off cooling system with more capacity than you need and some active valves to control how much of that cooling capacity you actually use, than it is to design 10 one-off cooling systems and rotate through them.
They also probably have a million sensors and computers in the car that you can't see, which need ventilation as well.
You are also correct that the rx8 is likely not aerodynamically optimized for said cooling system.
Alternatively, Mazda could just be throwing something that looks cool out there to gauge interest or simply mess with people. I certainly would do something like that if I knew photographers were waiting to 'spy' something interesting.
Old 12-13-2017, 12:22 PM   #471
vh_supra26
Site Moderator
Drives: Supra
The Mazda mule can be seen for a few seconds around the 10:50 mark.
[ame="https://www.youtube.com/watch?v=q-r82eJIkKM"]BEST-OF Industry Pool on the Nürburgring 2017! M3 CS, Corvette ZR1, M5 CS & MORE! - YouTube[/ame]
Old 01-10-2018, 12:49 PM   #472
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
next gen gt86/rx9 confirmed, built in USA, likely a Corvette killer for $19k, mid-engined?
brz to go turbo diesel awd shooting brake
probably changing over in 2019 for the 2020 model year, if Fiat can do a 2 year car I have faith in Toyota
http://www.autonews.com/article/2018...autonews-blast
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Cole (01-11-2018), funwheeldrive (01-10-2018)
Old 01-10-2018, 01:08 PM   #473
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Are you trying to get a job with that highly reputable Australian automotive news site?
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 01-10-2018, 01:12 PM   #474
strat61caster
I'm gunning for vh_supra's job, more potential to 'make the world a better place', they're not utilizing the full potential of synergetically copy-pasting articles into forum posts to 'disrupt the industry'
If I can steal viewership from motoring.au all the better, the true measure of 'changing the world' is how hard we millenials can tank 'old business'
ineedyourdiddly
Cole (01-11-2018), Rampage (01-11-2018)
Old 01-10-2018, 02:28 PM   #475
gymratter
Drives: BMW
Mazda files patents for a sequential twin-turbo setup
Mazda has a history of interesting engine technologies, from yesterday's rotary engine to tomorrow's compression ignition engine, and new patents show it still may have some internal combustion tricks up its sleeve. The one on display in these patents isn't especially new in concept, though. A sequential twin-turbocharger setup is something Mazda itself used on the third-generation RX-7. But it's something we haven't seen much of lately. It looks like it could have some possible advantages over older sequential systems, and it has some potential advantages for enthusiasts.
First a quick and dirty primer for what makes a sequential twin-turbo system distinct from other twin-turbo systems. In many twin-turbo engines, there are simply two turbos that work together as one bigger turbo. They're the same size, and they spool up at the same time. With a sequential setup, at low rpm, a smaller turbocharger is spooled up first at low-rpm for quicker throttle response, and as the rpm and exhaust pressure increases, a valve opens up that allows a larger turbocharger to also spool up and provide high-rpm boost.
That's basically how the Mazda design shown above functions. A big flap blocks off the larger turbocharger exhaust inlet, channeling all the exhaust to the smaller turbo. When more exhaust is available at high rpm, it looks like that flap opens up to spool up the big turbo, too.
What's interesting here is that the way the turbochargers are packaged takes up less space than past systems. It looks like both turbos are contained in one unit that shares the same exhaust outlet, meaning the exhaust manifold could be kept simple and compact. In fact, the piping for compressed intake air could also be shared, reducing the amount of piping, which would further decrease the amount of materials and possible failure points.
There are a number advantages of making this system smaller. The potential applications of the system are much greater, since it could fit in smaller cars with smaller engine bays. Making the system smaller also means that there won't be as much weight, which is important from both fuel economy and performance standpoints. Finally, the smaller setup likely uses fewer materials, which could make the system cheaper and thus easier to offer on a wider range of vehicles, or at least more profitable for Mazda. And of course, the system could still have the throttle response and power benefits of a more conventional sequential turbocharger setup, depending on how it's optimized.
We do have several unanswered questions. For instance, why would Mazda look into a twin-turbo system when variable-geometry and twin-scroll turbochargers can provide similar results? They also each only use a single turbocharger, which could hypothetically be lighter and cheaper than two. Perhaps the two turbos can provide more effective boost over a greater rpm range. Also, what would this engine go in? We would love to see it power a new high-performance Mazda3, but maybe it would be used for a largr luxury sedan based on the Vision Coupe. Only time will tell. We'll be watching this development closely.
https://www.autoblog.com/2017/12/08/...n-turbo-setup/
Old 05-22-2020, 04:52 AM   #476
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
MAZDA RX-VISION GT3 CONCEPT
Damn it Mazda, please put out an actual product.
It's the race version of their vision concept car.
Official: Nissan Concept 2020 Vision Gran Turismo revealed, hints future R36 GT-R vh_supra26 Other Vehicles & General Automotive Discussions 42 01-17-2016 02:28 AM
Fs: Brand New BRZ OLM Vision LED Fog Lights ucsmfu Canada Classifieds 12 03-12-2015 05:22 PM
I have tunnel vision: 2004+ BMW 330ci ZHP D4ng3r Other Vehicles & General Automotive Discussions 3 08-24-2012 08:54 PM
Mazda MX-5 Yusho concept introduced at AMI Leipzig quik1987 Other Vehicles & General Automotive Discussions 6 06-27-2012 04:36 PM
2010 Mazda Shinari Concept WingsofWar Other Vehicles & General Automotive Discussions 18 09-07-2010 06:42 PM
