Old 12-09-2017, 01:41 PM   #1
gutbuster
Drives: 13 FR-S
Rear Seats folded down for Subs in trunk?
This might seem like a silly question, but for subs in the trunk (Custom, Stealthbox or OEM audio, etc) do the rear seats need to be laid flat? If they are up does it compromise the output of the subwoofer?
Former rides: 78 Scirocco, 80 Corolla, 79 Celica, 91 CRX, 90 CRX-Si,02 GTI, 87 944s, 86 911 3.2 Carrera, 03 MR2 Spyder
gutbuster is offline   Reply With Quote
Old 12-09-2017, 02:12 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
My sub sounds better with the seat up. It is slightly louder with the seat down. It is your preference really. There is no right or wrong way. There is just more optimal or less optimal sound. Opening your windows changes the sound of the sub too a little. Where the sub is placed in the trunk and which direction it's facing will also change how it sounds.
I LIKE TIRES!
Old 12-09-2017, 02:35 PM   #3
Chimera
Drives: FRS
It has an effect. I generally ride around with my seats down.
Old 12-09-2017, 07:21 PM   #4
dvniemela
dvniemela's Avatar
I've always thought sub's sounded better with the rear seat up.
dvniemela is offline   Reply With Quote
Old 12-09-2017, 11:07 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Silly question indeed. But it's your ears, your car.
Personally I think if you need to fold down the seats your sub and amp suck major donkey you know what.
The Following 2 Users Say Thank You to Mr.ac For This Useful Post:
Tcoat (12-10-2017), x808drifter (12-13-2017)
Old 12-10-2017, 08:27 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
If you ride with the seats down, make sure the sub and everything else back there is tied down. In an accident that can be dangerous.
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
Tcoat (12-10-2017)
Old 12-10-2017, 11:01 AM   #7
LOL!
Old 12-10-2017, 12:04 PM   #8
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Very true. I don't have a sub, but I have the Schrader performance rear seat delete. The back of the delete is just a light panel snapped in place, basically like having the seat down. One time my wife and I had a case of sparkling wine in the trunk coming home on Skyline and a jerk coming the other way cut right in front of me going into a driveway. I slammed on the brakes and the case of wine tore right through the delete and hit the back of my seat. Luckily nothing was damaged. If you have the seats down (or a delete kit) make sure anything in the trunk is tied down.
The Following 3 Users Say Thank You to Sapphireho For This Useful Post:
Chimera (12-11-2017), humfrz (12-15-2017), new2subaru (12-11-2017)
Old 12-11-2017, 09:40 AM   #9
Kerrija
Drives: 2016 Subaru BRZ Limited
With the seats up the trunk itself becomes part of the sound chamber for the subwoofer and making it sound louder in some cases.
Kerrija is offline   Reply With Quote
Old 12-11-2017, 10:29 AM   #10
Chimera
Drives: FRS
I keep mine down most of the time, I mounted my sub amp on the opposing side of the stock door amp, and cut a vent where the channel between the rear seat and the trunk is. I'm not really sure its necessary, the amp usually doesn't get hot unless it was already hot from sitting in the summer heat, but it's there. I think when the seats are up that location basically doesn't have any air flow availability.
The Following User Says Thank You to Chimera For This Useful Post:
Leonardo (12-13-2017)
Old 12-12-2017, 11:23 AM   #11
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
You get a lot more road noise in the cabin with the seats down which might contribute to muddling the sound of the sub.
Damn, that is good to know. I have considered getting one down the road but knowing this and how much I haul around in my car might not be such a good idea (or at least needs to be modified.
Old 12-12-2017, 08:01 PM   #12
CraigVM
Drives: Car Collector
Seat based Db meter
Start with the seats up and when then fly back down, you know your bass is hitting some serious Db levels.
finch1750's response
CraigVM is offline   Reply With Quote
The Following User Says Thank You to CraigVM For This Useful Post:
Chimera (12-13-2017)
Old 12-13-2017, 07:04 PM   #13
DAEMANO
Time Traveller
Truth be told it's not worth the effort to think about. Trying to find the sweet spot in a tiny car with long bass frequencies that are being reflected, mixed, rarefracted, etc is near impossible because these positions change with the bass note being played. Do whatever is most comfortable for you.
http://realtraps.com/art_waves.htm
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 12-13-2017, 07:51 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I've changed boxes and subs three times. And tried different combos of each. It's important to have the right box for your sub. What is not as important: if your seat is up, down, or deleted.
I LIKE TIRES!
Mounting 10" subs in the rear side area CypriniousM Electronics | Audio | NAV | Infotainment 3 05-01-2017 07:36 PM
SARD Seats Cover(Rear Seats Only) elgin63 Interior Parts (Incl. Lighting) 0 04-22-2017 09:05 PM
SARD Seats Cover(Rear Seats Only) elgin63 Interior Parts (Incl. Lighting) 0 04-22-2017 09:03 PM
Interior door panel, rear seat belts, and rear seats wrxdrifter Interior Parts (Incl. Lighting) 0 06-17-2016 10:46 AM
Scion FRS Stock Full Seats (Driver / Passenger / Rear seats) for sale Sehwan Kim Interior Parts (Incl. Lighting) 1 01-28-2015 07:35 AM
