Old 12-06-2017, 01:24 PM   #729
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by Imp View Post
So on the rear, adjusting camber effects toe? Not separate? (Looking at parts install now... I guess so... hmmm)
--kC
Two links control camber and toe, one is not factory adjustable, both are replaced by the SPC kit. The big beefy one with the green arrow is the 'lca' and the white arrow is 'toe' link (factory adjustable and not required to be replaced per the rule you quoted), they act like adjusting the two eccentrics on a Miata's lower a-arm, need to tweak both to dial in rear alignment.
I still go back to the suspension walkaround Edmunds did over five years ago, great pictures, solid descriptions. If there's a car I'm interested in understanding I search for a post like this first.
https://www.edmunds.com/car-reviews/...alkaround.html
A view from the back of the car, Yellow arrow is factory adjustable "toe" link, green is non-adjustable factory, SPC puts their adjustment on the other end via slotting the arm and having a cam on the bolt, I can't imagine it's any more precise than the factory toe eccentric which I hate with a passion at this point.
ineedyourdiddly
Old 12-06-2017, 01:32 PM   #730
Imp
Bring out your dead
Drives: '14 BRZ (SSC), '00 S2000
Ahhh ok. Thanks. Ok, so really, I'm going to say put some more force into those bolts to lock them down, welding shouldn't be needed or used.
--kC
Imp is offline   Reply With Quote
Old 12-06-2017, 02:11 PM   #731
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
--kC
I don't think anyone has really checked an SSC car at RRautox.
iLuveKetchup is offline   Reply With Quote
Old 12-06-2017, 02:14 PM   #732
Imp
Bring out your dead
Yeah, some have. Just don't weld it. SCCA rules don't permit it.
--kC
Old 12-06-2017, 02:14 PM   #733
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
I thought we had to use the adjustable toe arms too? (Not the bushings since those are for the stock arms.)
Under "mandatory parts":
SPC Performance® Adjustable Alignment Kit, part # 60620T, including:
• 81305 [(2) EZCam® XR bolts,14mm]
• 67660 [(2) rear adjustable lower control arm]
• 67655 [(2) rear adjustable toe arm]
Twinz is offline   Reply With Quote
Old 12-06-2017, 02:19 PM   #734
iLuveKetchup
Drives: EFF JAY
Yes, while the SPC rear adj toe arm is not needed (OEM adjustment is fine), you need to install part # 67655.
Old 12-06-2017, 02:26 PM   #735
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Yep, which annoys me a lot. Unnecessary costs.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
DaWorstPlaya (12-06-2017)
Old 12-06-2017, 04:24 PM   #736
tony_r
tony_r's Avatar
Drives: '15 STX
We checked, it didn't move. Last alignment was months ago. About 70 runs so far on concrete (two weekend events, one single, 3-4 drivers).
tony_r is offline   Reply With Quote
Old 12-06-2017, 04:52 PM   #737
iLuveKetchup
Drives: EFF JAY
And you tq'd to what spec?
Old 12-06-2017, 04:55 PM   #738
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
I'm guessing it was torqued to tight lb-ft
G_Ride is offline   Reply With Quote
Old 12-06-2017, 04:57 PM   #739
Twinz
Twinz's Avatar
I torqued to ~70ft lbs and marked them. 3 drivers and about 50 runs...still good.
Old 12-06-2017, 04:58 PM   #740
tony_r
tony_r's Avatar
Drives: '15 STX
Yeah the spec with a breaker bar and some muscle.
Old 12-06-2017, 06:21 PM   #741
ka-t_240
--kC
Any time you adjust camber you impact toe, and vice versa. That is why you always set camber(and caster if adjustable) prior to toe.
The BRZ does not have factory camber adjustment; however, it has factory toe adjustments.
ka-t_240 is offline   Reply With Quote
Old 12-06-2017, 06:23 PM   #742
ka-t_240
So you can get DQ'd for only have the control arms, and not also having the toe arms?
Upgrading brakes on the lower spec GT86 (the standard spec outside of US market) OnionTou Suspension | Chassis | Brakes -- Sponsored by 949 Racing 55 07-01-2016 01:36 AM
what's the difference between twin screw, centrifugal, single turbo and twin turbo? warplane95 Forced Induction 86 04-17-2014 02:36 PM
my twin RWDGUY Mid-Atlantic 2 04-08-2013 09:23 PM
JDM Spec-C V9 Twin Scroll VF36 complete Nico TURBO Engine, Exhaust, Bolt-Ons 0 12-05-2012 11:20 AM
