#113 |
Killed Scion
Drives: 2013 FR-S Whiteout
New brake setup!
In preparation for a upcoming tack day I installed all new rotors and pads on all 4 corners. For pads I chose the winmax W3 pads due to the information on this thread http://www.ft86club.com/forums/showthread.php?t=68486 To me it seemed like the W3 pads were the best all around for a DD/street vehicle that does spirited drives on the weekends and occasional track days. They supposedly make very minimal noise and have some bite even when cold. I paired these pads with DBA T2 slotted rotors to try them out on the track and see how they perform on the street as well. Also, the T2 are almost half the price of the T3 2 piece DBA rotors.
![]() ![]() ![]() ![]() ![]() post track review; I have very little time with these pads on the street but after bedding these in they REALLY like to bite when warm. You definitely notice the difference when these pads are warm vs cold. The cold performance isn't horrible, approximately the same as stock brake pads. Driving around town and on the freeway I didn't notice many noises coming from the pads themselves beside the occasional squeal when coming to a very slow stop at low speeds. I noticed the noise from the slotted rotors more than the pads themselves. Now at the track these brakes got to temperature quickly and performed very well. Unfortunately the track I was at is brake intensive and found that the paint on the outside had started bubbling from the heat. These would be great pads for someone who is just starting to track their car and don't want to run dedicated track pads. Unfortunately for me, I've learned that I'll have to run dedicated track pads because I feel that I was overheating these pads and pushing them past their potential. The day after the track day Neal over @The Racers Line had noticed and informed me that there was quite a bit of pad smear on the rotors. Also after the track day I have noticed louder and more frequent squeaking coming from these pads, but they may just need to be bedded in again.
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
#114 |
Killed Scion
Thunderhill West 2 mile track day! 10/29/17
On 10/29/17 my girlfriend had purchased a track day at Thunderhill Raceway for my birthday. (Pretty awesome girlfriend am I right?
)Anyway, we did the West 2mile configuration with Exclusive Track Days organization. The day went very well and the car behaved very well with no hiccups throughout the whole day.. until the last session.. but I'll get to that later. Brakes were doing great, tires were performing tremendously, and had great weather with no overheating problems at all. My fastest time of the day was a 1.32.00 measured with Harry's Lap Timer. I felt that was a pretty good lap time but I also feel like I could've gotten a better time.. all of these photocreds go to my GF. here's a raw video clip of my 5th session. Unfortunately the 6th/final session had my fastest lap. Some of the laps in this session had multiple 1.32.xx [ame="https://www.youtube.com/watch?v=3bttcIRsAng&t=6s"]Thunderhill West 10/29/17 FR-S (Driver POV) Raw footage Session 5 - YouTube[/ame] Anyways, during the last session on the last half of the last lap the driver behind me had noticed some smoke coming out of the rear of my car. After pulling into the paddock he had informed me what he saw and my GF had gotten up out of her chair because the car was smoking so bad she had thought I caught fire. We inspected the car and found that the driver's side axle had popped out of the diff and flung axle grease and diff fluid everywhere. The smoke had resonated due to the grease and fluid hitting the exhaust pipe that runs right under the driver's axle. After a quick call and some diagnosing later, we decided to pop the axle back into the diff limping the vehicle to a gas station near the track and then rechecking for more grease/fluid. We didn't find any new fluid so we limped the car 130miles home with a fellow Norcal86 member who was at the track day and was willing to caravan behind us on the way home.
#115 |
Killed Scion
FT86SpeedFactory Lightweight Battery kit
After a couple of early mornings where the vehicle would barely start and with some no starts I knew the car was due for a new battery. Instead of going with the same stock 30lb battery from Toyota I decided to go with the FT86speedfactory lightweight battery kit. I went with this kit/setup because everything is direct bolt on and FT86SF claims to see 19-20lbs worth of weight reduction. This kit includes a Braille 11lb battery and FT86SF's own battery tray and battery tie downs. The tie downs were somewhat of a bolt on.. It ended up fitting in the end but one of the tie down rods, the one that screws into a pre-existing hole in the chassis. It did not want to screw in and required quite a bit of fiddling and plier/lube to finally get the rod in, I almost had to resort to drilling out the hole a bit bigger just to get it to fit. The threads on the top of the rod cut up my fingers due the force/fiddling I had to do to get that rod securely in but kind of my fault for not wearing gloves.. The battery tray itself was a ok fit, the little rubber grommets that are supposed to go into the preexisting battery tray holes were a tad too large causing the battery tray to not want to seat perfectly. With these being noted after installing the battery and tightening it down, It does seem secure. It doesn't seem like it's going to tip over or move so that's a plus.
| The Following User Says Thank You to MisterSheep For This Useful Post: | Mr.Impreza (12-06-2017) |
#116 |
Killed Scion
Monogram/10 series/RS1.0 USDM headlights!
I finally was able to find a great deal on some used USDM Monogram/10 series/RS1.0 headlights. They actually came off of a RS1.0 that was parting out. Anyways, they were a pretty simple bolt-on that required some modification. First off I had to buy the female 8pin connectors and repin the wires from the stock 6pin into the 8pin connector. Good thing I had a friend of mine help out with the wiring because I am not that experienced when it comes to wiring. After everything was wired up correctly the headlights worked properly just as if it was on a monogram series frs. Only difference is that my base frs does not have the level adjuster dial on the interior of the vehicle which is alright due to there being an adjustment dial on the back of the headlights. These totally change the look of the vehicle and look way better than my faded/oxidized stock headlights!
#117 |
Drives: Whiteout FRS
This looks perfect
#118 | |
Mr.Fujitsubo
Drives: 2018 STI
I will probably consider this in the future since I basically have nothing else to do to the car anymore haha. Oh yeah...and nice build
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
| The Following User Says Thank You to Mr.Impreza For This Useful Post: | MisterSheep (12-06-2017) |
#119 |
Site Moderator
Drives: ichi 86 Project
Damn! So many update so quickly! Keep it up!
| The Following User Says Thank You to ichitaka05 For This Useful Post: | MisterSheep (12-06-2017) |
#120 |
Killed Scion
It had been long over due
| The Following User Says Thank You to MisterSheep For This Useful Post: | ichitaka05 (12-06-2017) |
#121 |
Killed Scion
NYE Photoshoot
Some of the local east bay 86 guys went out on New Years Eve to take some proper pictures of the cars. All photo creds go to @maxpowa
Blue 17 BRZ: @NeedsBoostt White BRZ: @maxpowa Yellow FR-S: @Pizazu White FR-S: Me ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
#122 |
Killed Scion
:DDDDDD!!
Hey everyone,
I know I haven't updated my build in awhile but I've added a couple of things to Miyuki's rear end. One in particular I have been waiting for since the beginning of my build back in 2015.. Finally got my TRD Release Series 1.0 rear bumper lip painted and installed! Before the "NeEdS qUaD tIpS bRo!" I have the RS1.0 quad catback just waiting on new gaskets plus hardware. Also I had installed a Seibon CSL carbon fiber trunk. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() absolutely in love with the rear end now and finally the rest of my TRD parts are coming together nicely.
#123 | |
Are you going to paint-match the new TRD bumper/rear lip?
Looks awesome, but it's pretty easy to tell in this pic that it's a different blend/shade of white... Edit: clearly I’m blind because you did get it painted. Guessing that’s just a trick or the lighting in the picture. My bad.
Instagram: @spike.grc
#124 | |
Killed Scion
#125 |
Killed Scion
More photos of the build from a recent small photo shoot that my GF took of my car for Wekfest San Jose Application. Also 1 of the pictures is showing off my new TRD carbon fiber aero fins.
| The Following 2 Users Say Thank You to MisterSheep For This Useful Post: | ichitaka05 (04-26-2018), Lococholo84 (05-07-2018) |
#126 |
Killed Scion
Finally installed my JDL Catless UEL header with black ceramic coating
Video of a "cold start" about high 60's outside with the car sitting for approximately 4 days. [ame]https://www.youtube.com/watch?v=_3dqLe57Ye8[/ame]
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque Last edited by MisterSheep; 05-12-2018 at 06:53 PM. |
| VuDism's WHITEOUT FRS 6MT Daily Driver Journal | VuDism | Member's Car Journals | 44 | 03-28-2017 06:13 PM |
| My Journal | Weasel Soup | Member's Car Journals | 27 | 10-03-2016 04:07 PM |
| < RYO > Car Journal | RYO | Member's Car Journals | 3 | 04-16-2015 12:48 PM |
| Suaveflooder's Whiteout FRS Journal | suaveflooder | Member's Car Journals | 139 | 07-18-2014 11:04 PM |
| Going S1DEWAYS Whiteout Journal | jinberry | Member's Car Journals | 8 | 12-03-2013 05:40 PM |
