Old 11-30-2017, 01:04 PM   #15
Teseo
Drives: frs
I can reproduce tip-in knock at will in the same way that OP describes. I don't know much about what the ECU is doing except that it's waking up from fuel cut.
1. Drive for a good long period a steady highway speed.
2. Lift completely for long enough to go into fuel cut.
3. Stab at it. Doesn't take much.
Like @ermax describes, it can be avoided by applying throttle in two stages. First crack it open to wake up the injectors. Then go ham-fisted (footed?) with confidence.
Bravo!! I thought i got paranoic and filled the car with "race gas" (95 oct) because knock. Thanks mate, i feel like rubbish for spend 40 dollars at that pump.
Teseo is online now   Reply With Quote
Old 11-30-2017, 01:05 PM   #16
ermax
ermax's Avatar
Tip In Knock?!
The TB is almost silent. Go out to your car and turn on the ignition but don’t start the car. Now go all nuts on the throttle. You will hear the TB moving but it’s very faint. Definitely not loud enough to hear over the engine. You will sometimes hear air rush into the intake but this isn’t the ping/knock sound as heard in the video.
Old 11-30-2017, 02:16 PM   #17
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Right, I know that the air induction noise isn't related, but I have heard on numerous accounts what the OP is describing. Though, it only happens on WOT shifts for me.
DaBoBo21 is offline   Reply With Quote
Old 11-30-2017, 02:43 PM   #18
ermax
ermax's Avatar
Okay, I was just clarifying. I firmly believe the sound we are all hearing is knock. I just can't believe a modern car would knock right from the factory the way our cars do.
Old 11-30-2017, 03:21 PM   #19
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
You're good! It is interesting, though. Has there been any reports where this leaded to serious damage (specific to our cars)?
Old 11-30-2017, 04:05 PM   #20
ermax
ermax's Avatar
So we all know about the early 2013 having the messed up transient retard table which was blowing injector seals. They fixed this in mid 2014. Well this table was updated again on the 2017 to pull even more timing.
Tor talks about tip in knock in this thread:
http://www.ft86club.com/forums/showthread.php?t=118629
He seems to have solved the knock by dropping the 2017 table into his rom. I think I am going to try this tonight and see how it goes. It does impact throttle response a little though. Hopefully it isn't unbearable. I am real picky about laggy throttle response. But if it prevents knock I will suck it up.
Old 11-30-2017, 05:20 PM   #21
Bah! Nothing wrong with mixing in some good stuff. I bet you noticed the difference.
Old 11-30-2017, 05:46 PM   #22
steve99
Drives: FT86
Stock tune in 2012-2016 cars will knock even on 93 fuel in 2000-4000 rpm under high load
2017 stock tune is better
Old 11-30-2017, 05:53 PM   #23
Teseo
Drives: frs
Yup, at 6k rpm vvti kicked in yo
Old 11-30-2017, 06:08 PM   #24
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I think a data log of the throttle position in sync with an audio recording may be handy.
Agreed, watch the car's knock sensors.
http://www.ft86club.com/forums/showp...20&postcount=3
60k on stock early tune, almost 5k on the OFT tune, noise is exactly the same before and after.
Oh but now with added VVT noise as with the video in the OP.
ineedyourdiddly
Old 11-30-2017, 06:17 PM   #25
ermax
ermax's Avatar
I have recreated the sound while logging and there are no signs of knock in the data. But knock sensors aren’t 100% definitive one way or another. You can bog this car in 2nd from a dig and it will ping like a bitch and still not show in the data. I just can’t imagine what else the sound could be if it isn’t knock.
I will report back what impact the K00C transient retard table has.
Old 11-30-2017, 08:12 PM   #26
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
A knock sensor will pick up a knock WAY before you can hear it. By the time you hear a knock your engine is pretty much fucked, which is why the piezo speakers that are knock sensors pick up any knock well before your ears can.
That noise isn't knock.
guybo is offline   Reply With Quote
Old 11-30-2017, 08:20 PM   #27
ermax
ermax's Avatar
Why does it go away when pulling timing then? If it isn’t knock, what to you think it is?
Old 11-30-2017, 09:11 PM   #28
I understand from speaking with more learned friends that the stock tune, at least for the zenki, is actually optimized for 94 octane.
And before this devolves into a panic, let's remember what the owner's manual says about it. On this page alone, the owner is reassured four times that a little pinging is normal. The system is designed to constantly look for the knock threshold and keep timing right up against it.
Tip in knock Tor Software Tuning 32 03-22-2018 12:13 PM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
Oft knock brady86 Software Tuning 26 07-15-2015 10:14 PM
Tip in knock? bmsi30 Issues | Warranty | Recalls / TSB 17 08-25-2014 04:12 PM
