Old 11-30-2017, 12:58 PM   #43
iLuveKetchup
My VTEC fluid is full
iLuveKetchup's Avatar
Drives: EFF JAY
Originally Posted by cfordart View Post
Found this in a thread, don't know if it's accurate or not...
http://www.ft86club.com/forums/showp...98&postcount=6
Good luck with it!
Awesome thanks!! Looks like the Monogram matches but the FRS base is different. No worries. I'll just re-pin and make sure to keep it consistent between the two connectors.
iLuveKetchup is offline   Reply With Quote
Old 03-12-2019, 12:28 PM   #44
gurshawnbal
Drives: 2017 Subaru BRZ
Really wish this guy still made some more of these harnesses Just bought some release series headlights for my base model and could really use them.
gurshawnbal is offline   Reply With Quote
Old 03-13-2019, 02:00 AM   #45
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Doesn't hurt to buy the 8pin connectors and do some re-pinning :P I thought about re-creating the harness but currently do not have time to do so.
Bach415 is offline   Reply With Quote
Old 04-23-2020, 05:20 PM   #46
H_K
Drives: '13 Scion fr-s
Hey guys, just wondering if there's any traction on where to buy a 6- to 8-pin harness to convert my '13 fr-s headlights to 17+ 86 headlights. Please let me know!
Also, would MY17+ BRZ headlights have the same 8-pin configuration?
H_K is offline   Reply With Quote
Old 04-23-2020, 10:52 PM   #47
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
I actually have the same exact question. I can't find anywhere that sells 6 to 8-pin headlight harnesses.
I found this place, but they are in Australia and it does not look like they ship to the US. They also would not be straight plug and play for the 2017+ because they require you to splice into the turn indicator wires so the indicators in the headlights will work.
The only option might be to buy these 8-pin plugs and do the re-pin yourself. The major downside to this is it will be more difficult to put the stock headlights back on unless you also found the 6-pin plug somewhere and made you own adapter.
Mike_ZN6 is offline   Reply With Quote
Old 04-23-2020, 11:11 PM   #48
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I just bought a pair of 8-Pin Connector for the vehicle-side off of eBay and swapped the pins over to work with the headlights. They came with extra pins to crimp to your own wires as well
https://www.ebay.com/itm/1x-Connecto...72.m2749.l2649
My old 6-pin connectors are just in storage now. If I ever wanted to put them back, I'd just depin the 8-Pin connector and put them back in the right slots
For any headlight that has integrated turn signal, you'll have to spice in the signal wire yourself anyway
EndlessAzure is offline   Reply With Quote
The Following 2 Users Say Thank You to EndlessAzure For This Useful Post:
H_K (04-24-2020), Mike_ZN6 (04-24-2020)
Old 04-24-2020, 12:19 PM   #49
H_K
Regarding the turn signals - in order to make them work, I would need to connect a wire from the turn signals on the fr-s to the correct terminal on the 8-pin connector, correct? Any advice on doing that step?
Old 04-24-2020, 02:28 PM   #50
EndlessAzure
Wheels for Brains
Not in particular. I haven't done it. I have the Monogram/RS lights.
You could make a jumper or harness and bring it up, or just splice
Old 06-23-2020, 05:40 PM   #51
Kaleb765
Kaleb765's Avatar
Drives: 2015 Scion FR-S Raven Black
Hello, I have RS1.0 headlights on a FRS, purchased the LED86 adapters from Australia, but I get no LED DRL functionality, anyone here familiar with their harness? It does have a loose yellow wire that I thought was only for turn signal functionality on BRZ headlights, but potentially affects the RS1.0 led drls?
Kaleb765 is offline   Reply With Quote
Old 06-24-2020, 11:18 AM   #52
EndlessAzure
Wheels for Brains
I don't know anything about LED86 and their custom harnesses. Maybe contact them?
If you want DRL, you have to tap into the High Beam power or do the DRL Splice from the DRL resistor power lead. Both involve removing/unplugging the DRL resistor.
The Following User Says Thank You to EndlessAzure For This Useful Post:
Kaleb765 (06-24-2020)
Old 06-24-2020, 01:35 PM   #53
Kaleb765
Kaleb765's Avatar
Thank you!
Old 09-19-2020, 11:31 AM   #54
zypher10
zypher10's Avatar
Drives: GT86
You can get it here also
https://modssociety.co/collections/t...z-frs-gt86-frs
zypher10 is offline   Reply With Quote
The Following User Says Thank You to zypher10 For This Useful Post:
Kaleb765 (10-01-2020)
Old 10-24-2021, 03:25 PM   #55
15WhiteFRS
Drives: 15 FRS
Originally Posted by zypher10 View Post
Are these plug & play with DRL?
15WhiteFRS is offline   Reply With Quote
Old 10-28-2021, 09:08 PM   #56
15WhiteFRS
Drives: 15 FRS
Bump
Harness Bar diirk Tracking / Autocross / HPDE / Drifting 38 07-21-2017 01:15 PM
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
wiring harness so26 Electronics | Audio | NAV | Infotainment 5 10-30-2013 03:19 AM
WTB: Subaru BRZ Headlight Harness Parts enderr Exterior Parts (Aero, Lighting, Etc.) 3 08-28-2013 05:39 PM
Lighting Harness wawro569 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-09-2012 11:28 AM
