Old 11-28-2017, 12:32 PM   #57
jvincent
jvincent's Avatar
@churchx, good point.
I burned through the Primacies on the stock wheels in my first season at the track before I upgraded wheels / tires.
Old 11-28-2017, 01:49 PM   #58
JSube
JSube's Avatar
Drives: 2017 ISM PP BRZ
Originally Posted by jvincent View Post
Depends on your definition of worse and what you want out of the car.
Moving to wider, stickier tires will mean you lose the ability to get the car sliding as easily as it does out of the box. If you don't want that, then you have arguably made the car "better".
If you plan on tracking the car at all, then stickier is probably better.
Personally, I find the car's stability and traction controls to be adjusted well for the 2017 cars. The new calibrations allow a bit more slip but when they activate they do so effectively. In the rain, on loose surfaces like gravel and definitely snow, leave all the electronic helpers on.
But what you retain on dry roads with the Primacys is the light, nimble feeling of the chassis and it really is a spectacularly well-designed chassis, especially with the electronics turned off. You'll get more grip and learn less about car control with what people often call the "best" tires. And, btw, I have dedicated track wheels and tires.
I encourage you to learn your car's chassis the way it came set-up by some extremely talented engineers. And have as much fun as Chris Harris in the link below!
[ame="https://www.youtube.com/watch?v=JUhLXvxlQR4"]Toyota GT86 / Scion FR-S v Nissan 370Z v Used Porsche Cayman S - /CHRIS HARRIS ON CARS - YouTube[/ame]
JSube is offline   Reply With Quote
tires and wheels, tires help, wheels help
2017 BRZ wheels and tires 750 miles - SOLD THANKS! ILLSMOQ Wheels and Tires 2 10-03-2017 03:21 PM
FS Set of 2017 BRZ OEM Michelin HP 215/45R17 Tires jmark Wheels and Tires 2 09-24-2017 04:28 PM
Stock 2017 BRZ limited wheels/tires with 539 miles joeyf1986 Wheels and Tires 8 08-27-2017 12:38 AM
C Street Guys with 2017 PP What size tires? imnotsureaboutbrz Tracking / Autocross / HPDE / Drifting 19 04-15-2017 11:21 AM
WheelsCO - 2017 Michelin UHP Tires Spring GROUP BUY ( PS4S / PSS / PS Cup 2 ) wheelsco CANADIAN Sales 0 02-16-2017 01:07 PM
