Old 11-10-2017, 04:43 PM   #407
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
Originally Posted by johan View Post
That is a different type of belt. Tooth vs Rib.
Right, but the reasoning works the same. You have a small pully on your kit?
Old 11-12-2017, 01:28 AM   #408
johan
Drives: '14 981CS, '99 NB1
85mm. Stock is 95mm.
johan is offline   Reply With Quote
Old 11-28-2017, 12:37 AM   #409
Rolla
Drives: Rolla
@HarropOz
Does the Australian emissions tune come with any driveline warranty? Did you look at cylinder pressures like Cosworth for durability?
I'm interested in the base kit as a DD proposition.
Is the kit going to be modified for the 17+ cars?
Rolla is offline   Reply With Quote
Old 11-30-2017, 09:56 PM   #410
Rolla
Drives: Rolla
[ame="https://www.youtube.com/watch?v=I_Chws-XA70"]https://www.youtube.com/watch?v=I_Chws-XA70[/ame]
Flex fuel and flex boost setup
The Following 5 Users Say Thank You to Rolla For This Useful Post:
86 South Africa (12-01-2017), CxG (01-03-2018), Irace86.2.0 (12-01-2017), kuczynskika (11-30-2017), PR138 (12-18-2017)
Old 11-30-2017, 10:55 PM   #411
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Originally Posted by Rolla View Post
Flex fuel setup
Thanks. Posted on the front page!
kuczynskika is offline   Reply With Quote
Old 12-01-2017, 01:56 AM   #412
johan
Flex fuel setup
I'm glad they did this.
I noticed when installing the blower that it came with a dual port bypass actuator, making it possible to add boost-by-gear to the blower.
I plan to add this on mine at some point so I can turn boost down at low RPM (1000-2200rpm). With the automatic transmission in my car, the sudden boost at low RPM with the 85mm pulley makes the car really jerky and there's nothing to do about it without using the bypass to force the SC to bleed off boost.
Old 12-01-2017, 03:45 AM   #413
Kodename47
Kodename47's Avatar
Drives: UK GT86
Add in a shed load of cam overlap, that would essentially do the same thing. There is enough cam movement that you should be able to do this.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-01-2017, 04:38 AM   #414
johan
Already been down that road. Add too much and the car won't move (literally the car died on me several times when pushing the gas pedal to leave my driveway because the motor couldn't compress the air to splode it) add too little and it's bog (because of soul crushing ignition retard from having 12psi of boost at 1800rpm) then POWER (when it recovers), spinning the tires from every stop light looking like an asshat.
It's reasonably dialed in now, but I still get some gremlins when trying to drive sedately. Sometimes I'm tired and I just want to leave a stop light like a normal human being.
It'd be so much easier if I just had something statically pulling boost out at low RPM. Then the car could be tuned normally. I had a setup like this on a previously supercharged car and it was really nice.
The slushbox isn't doing me any favors here.
Old 12-01-2017, 06:42 AM   #415
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
@HarropOz
If I lived in aus I’d do this kit without question.
I like driving!
86 South Africa is offline   Reply With Quote
Old 12-01-2017, 07:30 AM   #416
Kodename47
Kodename47's Avatar
Drives: UK GT86
You shouldn't be in boost when driving at part throttle due to the bypass valve and you only need to add the cam overlap at higher loads for when in boost and not when at cruising. The tables in the ECU are 3D so are capable of doing this. This shouldn't give any driveability issues in either circumstances, pulling away you won't be in boost.... unless you nail it away from every stop Even then you only need enough to bleed away some boost.
Either that or you could just do throttle limiting at lower RPM.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-14-2017, 01:44 AM   #417
Irace86.2.0
At what throttle position does boost kick in or does not get bypassed?
Old 12-14-2017, 03:58 PM   #418
Kodename47
Kodename47's Avatar
Drives: UK GT86
A 3D log output of throttle vs RPM would easily show that.
On mine:
.: Stealth 86 :.
Kodename 47 DJ:
Irace86.2.0 (12-14-2017)
Old 12-14-2017, 08:30 PM   #419
Irace86.2.0
On mine:
Is it 1.36 bar or 19 psi including atmosphere or 5 psi of boost on the gauge, or is that 1.36 bar above atmosphere and thus 19 psi of boost on the gauge?
Old 12-14-2017, 09:44 PM   #420
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
I'd be aiming for 260-270 whp with this kit. I have a Tomei UEL header and overpipe plus an Invidia frontpipe and Q300 Catback.
Would I need the 85mm to achieve this or would the 90mm be okay? I don't want to stress the engine too much as this is my daily driver (Only drive it on weekends though)
Wise is offline   Reply With Quote
JDL turbo kit owners thread yomny Forced Induction 1352 01-08-2025 04:20 AM
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Harrop car lip kit? djdnz Cosmetic Modification (Interior/Exterior/Lighting) 15 12-15-2015 02:50 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
