Old 11-26-2017, 02:25 AM   #1
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Understeer after new wheels
A few months back I bought a new set of wheels, the old bronze xxr 527's 18x8 +42, and I had them installed by Firestone since I have their lifetime alignment, with new 225/40r-18 Raptor tires.
I did notice, however, that after installing these wheels with the new alignment the car started to understeer a little. It feels very heavy at the end of the turn, and it just doesn't turn as much.
At the time of, the rep who worked with me said he expected to see some 5mm spacers with the wheels and asked if I had them, to which I said no, of course, since my own research brought me to believe I did not need them.
So:
1) Should I have gotten wheel spacers with the new wheels?
2) If not, did they simply not align them correctly?
3) What could be some causes for this effect?
4) Did I dun goofd?
I'll probably end up going back to Firestone to have it re-aligned, but assuming everything was aligned to be squared off and everything else is fine, should I request some custom alignment?
At times like these I hate how helpless I am.
No suspension mods, by the way.
carsebuco is offline   Reply With Quote
Old 11-26-2017, 02:30 AM   #2
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
Check the simple stuff first...
Tyre fitment look good. Tyre pressure good. Then alignment.
I like driving!
86 South Africa is offline   Reply With Quote
The Following User Says Thank You to 86 South Africa For This Useful Post:
humfrz (11-26-2017)
Old 11-26-2017, 03:02 AM   #3
So:
4) Did I dun goofd?
........ snap out of it.
I'd suggest you have the car aligned again ...... tell them you don't like understeer.
If that don't work ....... ...... it's in your head .......they are different tires.
Old 11-26-2017, 03:09 AM   #4
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Hahah I wish. I remember being able to get another full turn out of the steering wheel with the stock tires.
I'll be taking her there again, just wanted to have a plan this time.
The Following User Says Thank You to carsebuco For This Useful Post:
humfrz (11-26-2017)
Old 11-26-2017, 05:12 AM   #5
dutchman1
Drives: 2017 86 6-Speed
"I remember being able to get another full turn out of the steering wheel with the stock tires"
Yea, there's something quite wrong if you're not able to get as much steering angle as you used to.
I may be wrong, but I believe you are misusing the turn "understeer." Understeer is when you try to go around a corned and the car keeps going straight because the wheels are sliding sideways.
If you mean to say that the steering wheel won't turn as far as it used to, something's up.
2017 86 set up for CS STX autocross
dutchman1 is offline   Reply With Quote
The Following User Says Thank You to dutchman1 For This Useful Post:
wparsons (12-04-2017)
Old 11-26-2017, 07:35 AM   #6
Teseo
Drives: frs
Would be helpful if you can post the allignmemt specs
The Following User Says Thank You to Teseo For This Useful Post:
guybo (11-26-2017)
Old 11-26-2017, 08:17 AM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
@Teseo beat me to it. Scan the alignment sheet show us whatcha got
guybo is offline   Reply With Quote
Old 11-26-2017, 08:39 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
Maybe for some reason steering angle was intentionally reduced to not rub? But it involves adding shims to steering mechanism, first time hearing that any shop doing wheel install/swap would touch that.
Old 11-26-2017, 10:24 AM   #9
Teseo
Drives: frs
Or tires did not broken in or allignment is shitty
Racecomp Engineering (11-26-2017)
Old 11-26-2017, 12:23 PM   #10
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
No, that's exactly what it does, but the way I mentioned is what it feels like in practice.
I don't have a copy of my last one, so I'll get it re-aligned this week and I'll drop it in here once I do. I don't know if they keep digital copies of previous alignments, but it won't hurt to ask.
I'll be back.
That's why I wanted to give it a few thousand miles before saying anything.
Old 12-02-2017, 01:51 AM   #11
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Here you go. I was told the tire wear was a little uneven so that's why the numbers aren't the same on both sides.
I will say the car steers a lot better now. It doesn't feel like it's trying to keep me going straight when taking fast turns.
Judging by the numbers before alignment, can anyone tell me why it was happening?
Old 12-02-2017, 02:05 AM   #12
ermax
ermax's Avatar
Oh the old uneven tires excuse for not nitpicking the alignment. Hahaha
Old 12-02-2017, 03:27 AM   #13
Hint: Always look for the yellow or red on alignment reports.
Your front toe was off pushing the limit and the steer ahead was off so the front wheels were actually fighting each other a bit.
Old 12-02-2017, 03:43 AM   #14
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Thanks. Sometimes a different lingo is necessary for me to finally get it. You hit the nail for me on this one.
Now, going off on what the guy said above, should I tell them I expect the same numbers on both sides next time?
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 05:05 AM
Not understeer, not oversteer... something else? Mazikowski Tracking / Autocross / HPDE / Drifting 15 07-25-2016 10:24 PM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 10:42 AM
BRZ stock suspension understeer... what to do? mtimney Tracking / Autocross / HPDE / Drifting 40 07-31-2013 01:48 PM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 12:06 PM
