Old 11-15-2017, 04:27 PM   #15
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Originally Posted by mav1178 View Post
I wanna bet $3.50
I'm trying to capitalize. If I go hard on a 'sure thing' maybe I can get my RCG4's back, and a set of Electras.
JazzleSAURUS is offline   Reply With Quote
Old 11-15-2017, 04:32 PM   #16
Azzudien
Drives: 2017 Series Yellow BRZ
I put the original post into google translate, than I tried several different languages, though I could not find Floridian.
Results:
I installed KW coils and by doing this it lowered the car substantially which put in excessive negative camber. Since there is no rear camber adjustment on the BRZ I had to buy LCA's to correct the rear camber.
When trying to find LCA's only 1 was listed for use on the 2017 PP cars on the websites
Brembo brakes and LCA could not be translated in the same sentence.
Azzudien is offline   Reply With Quote
The Following 4 Users Say Thank You to Azzudien For This Useful Post:
arkanist (11-15-2017), Captain Snooze (11-16-2017), JazzleSAURUS (11-16-2017), soundman98 (01-09-2021)
Old 11-15-2017, 04:38 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Results:
Mr. Chairman, I would like to recognize the sacrifice made by the gentleman from the honorable state of New York.
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
Captain Snooze (11-16-2017), finch1750 (11-15-2017), soundman98 (01-09-2021), wparsons (11-16-2017)
Old 11-15-2017, 04:58 PM   #18
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by 8RZ View Post
As a fellow Floridian....
WUT?
Downvote for lack of meme usage
Old 11-15-2017, 06:28 PM   #19
Grady
Grady's Avatar
I lowered mine an inch and was only out of limits -.4 deg on one side. Just bought the whiteline bushings, problem solved? Not going to track mine daily and need to adjust it all the time. Find one setting that works good and be done with it.
Old 11-15-2017, 07:17 PM   #20
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Originally Posted by humfrz
I'm old and lazy
Old 11-16-2017, 05:26 AM   #21
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Grady View Post
I lowered mine an inch and was only out of limits......
I lowered myself 2 inches so I get those 6 inch stilettos to handle properly.
x808drifter (11-16-2017)
Old 11-17-2017, 10:11 PM   #22
ka-t_240
Results:
Sounds like you are too low.
ka-t_240 is offline   Reply With Quote
Old 11-22-2017, 04:24 PM   #23
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
Light Sensor Bracket
Originally Posted by JazzleSAURUS View Post
I'm in, but I've spent all my money on car parts. Can I bet my RCG4's? Or maybe my OEM RGR's?
Yeah, OP should of just taken some measurements and bought some SPC's. I think there's a set in the classifieds for $130 right now.
Well, I guess I was too technical in what I wrote. I will take that bet! If the rear camber arms you buy DO NOT have a bracket for the headlight sensor, You all have a problem in Houston. That's why my comment on the Verus arms ( See pictures)
007BRZ is offline   Reply With Quote
Old 11-22-2017, 04:28 PM   #24
007BRZ
007BRZ's Avatar
Results:
What LCA did you use? Did they have the sensor bracket for the headlight sensor??
Old 11-22-2017, 05:16 PM   #25
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
How your OP should have been worded then....
Beware if you need rear LCA for your 2017 PP.
To keep the headlight leveling working correctly you will need to make sure your LCA's come with a way to attach the sensor to them.
The only ones I could find that had a way to attach the sensor were the Verus ones.
The Following 7 Users Say Thank You to x808drifter For This Useful Post:
Cole (11-22-2017), JazzleSAURUS (11-23-2017), JohnJuan (11-28-2017), soundman98 (01-09-2021), TofuJoe (11-23-2017), Tor (11-25-2017), wparsons (11-23-2017)
Old 11-22-2017, 10:25 PM   #26
nico_rsx
Drives: BRZ 2017 Pure Red, MT
Not just the PP, but the BRZ limited (at least the 2017) also have the auto headlight sensor (don't know about the base version).
nico_rsx is offline   Reply With Quote
The Following User Says Thank You to nico_rsx For This Useful Post:
Old 11-22-2017, 11:48 PM   #27
churchx
churchx's Avatar
Drives: 2014 GT86
Stock alike like spc (and probably very similar whiteline & eibach) have attachment points for leveling sensor just like stock rear lca-s.
JohnJuan (11-28-2017), wparsons (11-23-2017)
Old 11-23-2017, 11:01 PM   #28
nico_rsx
While we are on the subject, how can the level sensor continue to work with coil-overs? I mean even with aftermarket LCA, if you change the height of the car doesn't it change the angle of the LCA? If yes, then do you have a way to adjust the angle of the sensor according to the height you adjust the coilovers?
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 230 11-01-2023 12:31 PM
2017 BRZ Performance Package C&D Lightning Lap lynk26 FR-S / BRZ vs.... 27 10-04-2017 05:49 PM
1slowbrz's 2017 wrb performance package 1slowbrz Member's Car Journals 3 05-20-2017 05:03 PM
WTB: OEM 2017 Performance package wheels mjanmohammad Want-To-Buy Requests 1 03-03-2017 02:35 PM
