#17879 |
Huge E85 fan!
Drives: 2016 Scion FRS
I put it in the back. Even without a jack, I'll keep the spare so that I won't need a tow should I get a blow out.
One thing that confuses me though.... people in this thread are saying to take out the spare that may come in really handy... but keep the rear seats that won't fit a full size adult..... OK, well, I choose to do it the other way. As for raising the COG of the car, I think it'll even out and the COG won't move. There are several things that I deleted besides the seats and they were up near the roof and have some heft. Plus the side plastic panels. The seat back has some weight and that is fairly high as well. I'm really tempted to delete the headliner and carpet- but then wind/rain/road noise will be bad.
#17880 | |
#17881 | |
Drives: '14 981CS, '99 NB1
#17882 |
Huge E85 fan!
#17883 |
Oh crap I just realized that I "won" on the internet!
#17884 | |
The Dictater
Drives: '13 Red Scion FRS
This is the reason Porsche continue to contend that rear engine cars are the ideal design. Moving the cg back makes it easier to rotate the car. |
#17885 |
#17886 |
#17887 |
The humfrz 1st law of backing up. Just ask @Tcoat ,which way his head wanted to go, when I backed into that pillar ......
![]() humfrz |
#17888 | |
If my goal was weight reduction, I'd remove the tire and leave the seats, just because it looks better and accomplishes the same thing (more or less). If your goal is to move the center of gravity forward (not sure why you would want to do that), then removing the tire and leaving the seats is the better option. The tire is further out on the arm for weight and balance, so removing that mass from the rear has more impact than removing the seats. Removing the seats and moving the tire forward probably has the same impact (again more or less) as removing the tire only letting you keep the tire. Removing the seats has minimal impact on CG but does impact weight. Leaving the tire in has no impact on weight (obvious) but moving it or not moving it does impact CG. So, given all that into consideration: If my goal was to remove weight, I would remove the tire, and leave the seats. I'd rather have a clean cabin and no spare than a spare and no interior (but this is my DD, not my racecar) If my goal was to impact CG (move it forward) I would remove the tire and leave the seats for the same reason. If I was building a racecar, well all bets are off.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#17889 |
I'm 41 now and in all my years of driving and all my cars I have never once needed a spare. I have picked up nails plenty of times but if you pay attention to your tires you will spot the problem way before the tire comes flying apart. I carry plugs and most of the time I plug at the house. Only once did I have to install a plug in dress cloths while out to lunch. I suspect anyone driving an FRS is going to be very aware of tire pressures. Especially with TPMS. If you are the type that ignores a nail and rolls around at 10psi regularly or like to drive on corded tires then yeah.. you need the spare.
#17890 |
Sidewall damage would be another issue. Unless there is a a sidewall repair solution out there.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#17891 | |
You are lucky then. I have had several tires suddenly and catastrophically shredded, cut or torn beyond repair where a spare was the only answer. Nails are not the only hazard out there.
#17892 | |
Not a troll
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
