Old 07-05-2012, 10:50 PM   #15
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by Bonburner View Post
I'm coming from a "scientific" background - chemistry major, about to graduate in a few months with my B.S. (while it isn't an amazing degree) I fully understand what it takes to produce a good test and results.
The only thing that is absolutely conclusive is that different octanes receive different concentrations of additives.
What additives have not been described other than precipitates from boiled X volume - which probably is not done using precise and accurate volumetric means.
Maybe I'll go out and do this test myself one day.
I'd also like to see the mass spectrum of this.
Shoot me a PM if you decide to do this. I work as a quality/regulatory scientist so we can probably brainstorm together some ideas to make this a fair test. To be honest though, my particular field is pharmaceuticals if my signature never gave this away. Either way, let me know!
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
Bonburner (07-05-2012)
Old 07-05-2012, 10:54 PM   #16
fistpoint
Drives: Supercharged Golf Cart
Originally Posted by Jared0934 View Post
When I bought my ferrari...
Lies!
BP 87 Octane 17.2 milligrams per 100 milliliters
BP 93 Octane 26.4 milligrams per 100 milliliters
Citgo 87 Octane 6.0 milligrams per 100 milliliters
Citgo 93 Octane 9.4 milligrams per 100 milliliters
Exxon 87 Octane 20.0 milligrams per 100 milliliters
Exxon 93 Octane 21.2 milligrams per 100 milliliters
Pilot 87 Octane 5.8 milligrams per 100 milliliters
Pilot 92 Octane 8.8 milligrams per 100 milliliters
Shell 87 Octane 16.2 milligrams per 100 milliliters
Shell 93 Octane 31.0 milligrams per 100 milliliters
Thanks for posting that list. I too have often heard Shell has the best gas, but no one ever broke it down into detail like that. I personally use Exxon over Shell though because I'm fairly certain I get 1-2mpg better with Exxon vs Shell from my own tests doing the math on every tank(calculator, not the overly generous and inaccurate ones built into most vehicles).
I say "fairly certain" because no matter how hard I try by driving the same distances in the same area in the same manner with and without A/C, there are many variables that could have altered my results by that small 1-2mpg difference. However, this difference seems to occur every time I try Shell. Hmm.
Originally Posted by Black Tire View Post
On a side note, oil companies keep the price of gas high partly by limiting the number of refineries that are operating
No sir, you can thank Congress and the EPA for that ball of wisdom.
fistpoint is offline   Reply With Quote
Old 07-05-2012, 11:07 PM   #17
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I personally want to go into pharmaceuticals but my roots will always be chemistry.
I've loved it forever haha.
I'll need to get some small jugs to fill gas with and then pester the Mass Spectrum dep't heads to run their machines with gasoline - it really isn't cheap but my curiosity will win one day ...
Regardless this sounds like a great off time project one day!
Old 07-06-2012, 09:12 AM   #18
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
The problem I see with the test is that part of the residue will be non-productive impurities and part of the vapor could be volatile additives.
Old 07-06-2012, 11:24 AM   #19
smbrm
smbrm's Avatar
Drives: Scion FRS Ht Lva(AT)
Correct. It is never as simple as folks perceive.
smbrm is offline   Reply With Quote
Old 07-06-2012, 12:23 PM   #20
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
When I got my range rover they said only premium, chevron if you can. (Chevron has techron, google it if you want to know more)....
When I bought my ferrari, they said ONLY Premium SHELL... V-Power...
Ok, so I don't have a ferrari... but I've heard that that's honestly what ferrari dealers will tell you.
This diagramishthing below is a test scientiest did by taking 1 galon of each both 91 and 92/93 from the top 8 brand name gasoline stations. They did the same test conducted annually on gasoline stations by boiling the gasoline, and seeing how much residue is left behind. The residue being the detergent added to the fuel which results in a cleaner, healthier engine and more MPG. The test was done in 2011 and Shell premium came out on top by a good amount. Explains why ferrari dealerships say shell only. For those confused on who the fck BP is, they are ARCO....
Read more: http://www.abcactionnews.com/dpp/new...#ixzz1zcPzLiVD
edit: as for the ferrari mention, I found out dealers only tell you that because Shell is partnered with Ferrari/Ducati racing. But even still, I've been reading countless websites about gasoline and there is constant mention to Shell being the cleanest.
Yeah, I swear by Shell V-Power. There are other highly tuned cars like the Evo FQ-400 that require V-Power too. And I saw another test where a Subaru STI gained several HP just by using V-Power over other premium fuels because the ECU was designed to take advantage of better fuels and so it could use more boost. So not only is it the best, but Shell stations are available almost everywhere in the world.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 07-06-2012, 01:06 PM   #21
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
Ditto here for Shell and BP , have heard this from many Subaru technicians over the years. We've been running strictly Shell high-test for years and have had no issues.
FWIW, I'm a big believer in Seafoam as well. I put a some in with each fill-up, and treat the oil with it 30-50 miles before a change. I have the intake cleaned with it every 15K. Ounce of prevention kinda thing.
Don't text while driving, everyone around you will appreciate you not endangering their lives.
Stu baru is offline   Reply With Quote
Old 07-06-2012, 04:05 PM   #22
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
chulooz is offline   Reply With Quote
Old 07-06-2012, 09:11 PM   #23
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Harcore, Stu Baru is harcore.
Old 07-06-2012, 10:56 PM   #24
Brimford
Drives: Whiteout / MT FR-S
Would it be fine to go ahead and start adding seafoam in my tank? I didn't know if it would be bad with the engine being so new? I would always put some seafoam in my gas after an oil change (will start adding it to my oil) on my TC but it had 83k. That stuff is awesome!
Brimford is offline   Reply With Quote
Old 07-06-2012, 10:58 PM   #25
ahausheer
Re-member
Drives: Toyota camry
The test is pointless. Yes gas quality does vary but that test doesn't prove anything from a scientific point of view. Although I generally agree with the rankings on a personal level. Also note that Mobile is not ''Top Tier''. Mobil meets all of the requirements of Top Tier but doesn't want to pay for the distinction. The companies must pay for the tests themselves. Top Tier is not funded entirely by third parties which makes it slightly dubious. I like Shell, Chevron, and Mobil. my 2c, based purely on anecdotal data.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-06-2012, 11:13 PM   #26
ahausheer
Re-member
You don't need seafoam. That stuff is for engines that have been abused and not maintained at all. I have first hand experience with that stuff and the one time I used it it made my wifes 86 corolla burn oil. The carbon inside the cylinders were actually helping reduce oil consumption and the seafoam f-ed up the mechanical/chemical balance that engine was in. A properly maintained car can last hundreds of thousands of miles WITHOUT seafoam. Just take care of her and you wont need seafoam. But if you must, add it prior to an oil change not after, otherwise your oil properties might be off.
Old 07-06-2012, 11:18 PM   #27
Mr. Mcoupe
Mr. Mcoupe's Avatar
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
Did you add the Seafoam to the oil or to the gas tank?
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[]
Mr. Mcoupe is offline   Reply With Quote
Old 07-10-2012, 05:12 PM   #28
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Anyone know if Ethanol free gas is better or worse for the BRZ engine?
slizoth is offline   Reply With Quote
Sound quality of Bluetooth streaming music robo_robb Electronics | Audio | NAV | Infotainment 20 06-08-2012 11:37 PM
Subaru: I'm coming back to you. I hope your quality is on point. Lighting Red BRZ First-Gen (2012+) — General Topics 35 04-09-2012 03:30 AM
Subaru paint quality speed-wiz BRZ First-Gen (2012+) — General Topics 61 04-02-2012 05:56 PM
Good quality BRZ pictures Sushi BRZ Photos, Videos, Wallpapers, Gallery Forum 31 02-24-2012 03:59 PM
