Old 07-04-2012, 09:40 PM   #407
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Thanks Tim... Appreciate the great explanation...awesome
Scooby South is offline   Reply With Quote
Old 07-05-2012, 06:20 AM   #408
Scooby South
Conedancer
Someone ask if I was going to change Brake pads...The Brakes are surprisingly good.. I do have lines and fluid done. I have Subaru 4pots if I want to make the change. however after 3 events, I haven't seen the need.
So whats done at this point:
-rims/tires with lightweight forged lugs
-brakelines and fluid
-coilover suspension w/camber plates
-rear end links
-3 different size rear bars if needed
-lightweight battery
-performance alignment
-muffler delete with 2lb trun-down installed
Future Things that will/needs to be done:
-Corner Weight
-Tune/Cobb AP
-Header/complete exhaust with Cat
-All suspension Bushings (have Kartboy Rear Diff Bushings to install if I get time)
-Kartboy Short Shifter*When Developed along with Kartboy Shifter bushings.
-Kartboy Lightweight Crank pully
-OS GIKEN 1.5 way Rear Diff
-Lightweight seats
-some type of aero package... front lip, side skirt, rear wing.
-some other minor enhancements that I know of.
Some of this won't be this year...because of budget constraints..but it is planned for the future sometime...
Bill
The Following User Says Thank You to Scooby South For This Useful Post:
Asterisked Accolade (07-08-2012)
Old 07-05-2012, 10:53 AM   #409
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
good stuff
so having an inverted strut in a standard case would help increase rigidity of the unit for McPherson strut applications?
Old 07-05-2012, 10:56 AM   #410
bimmerboy
Drives: 2009 135i
Awesome progress. Do you have any more shots of the car with the coilovers, preferably from farther away from the car? Not sure if you have mentioned, but is there any tire rub now that you're lowered? IIRC you are running 245s correct?
bimmerboy is offline   Reply With Quote
Old 07-05-2012, 11:06 AM   #411
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Originally Posted by 7thgear View Post
good stuff
it can be used to increase structure against side loading, really the biggest thing that affects structure is the bearing span (distance from upper seal and bearing to piston position when in full droop). Aside from that though, it also adds a layer of protection against the strut becoming contaminated with dirt and debris. If you think about a typical strut, the bumpstop is protected by the boot, which does an OK job, but not great at protecting dirt and debris from getting on the rod and bump stop. when dirt does get in there, the bump stop basically compacts dirt and debris against the seal and wiper, which wears it down until it gets torn, cracked, or cut. At that point the damper leaks and you start to lose your damping abilities.
Sccabrz192 is offline   Reply With Quote
Old 07-05-2012, 10:41 PM   #412
Scooby South
Conedancer
Mad Camber... ... actually I was testing the Range of camber on the plates....
Lots of range with the plates... 0ish to -4.5... 6 degrees of caster. settled on -2.5 and 0 toe
rear... -1.8... .1/16th toe in for the rear on both sides..
Old 07-06-2012, 01:40 PM   #413
Jdogg180
Jdogg180's Avatar
Drives: 2008 Fit Sport
How do the KW's feel so far? Can't wait to hear your feedback from the next event!
Jdogg180 is offline   Reply With Quote
Old 07-06-2012, 04:27 PM   #414
VCMC-STC
Team Leader
VCMC-STC's Avatar
Drives: 2012 Scion FR-S
Looking better at the time sir!
What camber plate manufacturing are you using?
TIA!
Richard
VCMC-STC is offline   Reply With Quote
Old 07-06-2012, 05:31 PM   #415
jamal
jamal's Avatar
Drives: Legacy GT
They used to be blue I think.
Have you considered turning flipping and turning them to get more caster or is it more useful for you to be able to make quick camber adjustments?
jamal is offline   Reply With Quote
Old 07-06-2012, 10:22 PM   #416
Scooby South
Conedancer
TIA!
Richard
Cheap no names... ..and thank you..
They are flipped...they are for a RS.....and I already have 6degrees of caster..
Bill
Old 07-07-2012, 12:31 AM   #417
jamal
jamal's Avatar
Drives: Legacy GT
Bill
NOT ENOUGH!
Old 07-07-2012, 09:15 PM   #418
Scooby South
Conedancer
Wheeeeew....what a GREAT day.....Met a bunch of 'friends' that I have never met in person... and the Car is getting more more competitive and dialed in... Pretty much, I love the KW's...they are awesome... pretty much didn't adjust them all day...I did take 2 clicks of rebound out of the front... tire temps never got over 112 degrees..so I didn't even spray them.... Right now, in the first day of a 2 day Divisional...the car is in 2nd and 5th in STX out of 10 and in Pax 34th and 77th out of 175 cars... My Co-driver, Bart, is a wheel....he knows street tires..where I have been used to r-comps and havn't used street tires since Dunlop W10's were popular..and I am a bit more timid about trusting street tires..currantly, Bart is 1.34 secs off the leader...in 2nd...the leader, Neal Tovsen is driving a National level prepped 328i... so for the BRZ to be that close to him...I know I have made the right decision... for those that are following along..STR with Colin Fiedler is about 2 secs ahead of STX...soo the big question is: Should the BRZ be in STR or STX... for the stage of prep the BRZ is..It should be Very competitive in STX...STR...probably not so much.. I am sitting in 5th .008 out of 4th, 4/10's out of 3rd...and 9/10's out of 2nd... so I am not that far back.. we are finding the Sweet spot for the rack..the handling is absolutely amazing...
The Following 2 Users Say Thank You to Scooby South For This Useful Post:
civicdrivr (07-08-2012), Spaceywilly (07-07-2012)
Old 07-08-2012, 12:00 AM   #419
ImAwesome
Drives: 99' M3, 13' SWP Brz
impressive
ImAwesome is offline   Reply With Quote
Old 07-08-2012, 12:12 AM   #420
kanundrum
Drives: 2013 Whiteout FR-S
I finally redid my suspension with Full Custom Coil overs...
Too bad its not on the FR-S! haha.
Congrats on the Autox!
Subaru/Scion warranty and autocross Ribface Tracking / Autocross / HPDE / Drifting 55 06-17-2015 08:30 PM
Will you Autocross your 86? Ribface Tracking / Autocross / HPDE / Drifting 131 06-22-2012 05:48 PM
Which autocross class? jpdarty7 Tracking / Autocross / HPDE / Drifting 66 06-21-2012 05:53 PM
FR-S at a CA Autocross oneday Scion FR-S / Toyota 86 GT86 General Forum 57 03-26-2012 03:38 PM
