Old 10-25-2017, 05:57 AM   #211
lazyluka
Drives: GT86
Try as I might I could not get oil past 111C. I gave up after 30 minutes as it wasn't really going anywhere.
I would say that my driving style is to over drive the car. This track is fairly technical.
OBD Logged Temps:
Max Ambient = 24C
Max Oil = 111C
Max Coolant = 94C
Tyres = Dunlop Z2 225/45 R17
Car is NA, running ACE header, ACE FP, CSGxMXP Touring 86 exhaust and Delicious EcuTek tune.
Coolant and oil temp axis on the left in C.
RPM axis is on the right.
I have also attached my best lap for the day, happened during this logging session. Car is probably good for a much faster time but I need to improve as a driver before I can get it sub 1:50.
(BTW that foam I placed around the radiator is still fine, actually did some temperature testing vs the OEM stuff and it held up slightly better, not bad for regular foam from the hardware shop)
Huge thanks to @CSG Mike and @CSG David. Also huge thanks to Jackson Racing. Totally satisfied with my purchase.
lazyluka is offline   Reply With Quote
The Following 9 Users Say Thank You to lazyluka For This Useful Post:
Bonburner (10-25-2017), cbryant514 (10-26-2017), CSG Mike (10-25-2017), CxG (01-10-2018), gtengr (10-25-2017), Jackson Racing (11-16-2017), jbailey8748 (05-25-2018), OwlDance (09-19-2019), Teseo (10-25-2017)
Old 10-25-2017, 04:16 PM   #212
CSG Mike
CSG Mike's Avatar
I love data.
Old 11-06-2017, 07:36 PM   #213
Jyukai
Drives: scion FR-S MT
I ran grattan racing earlier this year, outside temp was about 18C.
I didnt log the data, but the highest oil temp was 108C, and it drop very quickly.
water temp was very stable at 88C, didnt move more than 2C in the whole day
Jyukai is offline   Reply With Quote
Old 11-15-2017, 01:10 AM   #214
voyager2285
voyager2285's Avatar
Drives: WRB BRZ
Noob question, is this a bit of an overkill for someone planning to stay NA?
voyager2285 is offline   Reply With Quote
Old 11-15-2017, 01:35 AM   #215
BRX
BRX's Avatar
Drives: Toyota GT86
For street/daily driving, yes. For the track it's not really necessary but you will NEVER overheat lol.
Sent from my Pixel XL using Tapatalk
BRX is offline   Reply With Quote
Old 11-15-2017, 06:18 PM   #216
voyager2285
Drives: WRB BRZ
I probably should be a bit more specific...
The only major performance mod I have is the JDL UEL headers, so no heatshield. Nothing else planned so far.
I do plan to do a few track days a year. My car seems to be burning coolant on the track on a cool October day at Seattle, so much so that I lost half a day waiting for the car to cool down before I can fill it back up. I'm planning to go down south to Laguna Seca in the coming summer so I though I'd go prepared this time. I'd hate to waste another half a day due to cooling.
The Following User Says Thank You to voyager2285 For This Useful Post:
chaoskaze (01-02-2018)
Old 11-15-2017, 06:21 PM   #217
Hawk77FT
Drives: GTS 86
Not really necessary for the track? No need for an oil cooler for the track? In what parallel universe that is even possible?
Hawk77FT is offline   Reply With Quote
Old 11-15-2017, 06:22 PM   #218
BRX
BRX's Avatar
Drives: Toyota GT86
Then I would highly recommend it for you. Oil and water temp should be very stable with this radiator cooler combo. From my experience you could highly benefit from running a thermostat that opens a bit earlier as well as it had the most dramatic effect in my case. But once it gets cold I would put the stock one back in.
Old 11-15-2017, 06:28 PM   #219
BRX
BRX's Avatar
Drives: Toyota GT86
For an NA in cool weather and let's say autocross or a drifting track, no it's not necessary.
For a high-speed track with long straightway, it would be recommended but it all depends on the weather condition. My temps dramatically changed when driving in 100 degrees weather vs 90. I doubt you would overheat an NA in less than 90 degree weather.
Old 11-15-2017, 09:11 PM   #220
Hawk77FT
Drives: GTS 86
If we are talking here about oil, I can tell you that on track after two or three aggressive laps, your oil will scream to be cooled down. And I would definitely recommend an oil cooler for track. Especially in hot climate! Not so much a new radiator as it will do the job just fine. Unless..you go FI, then a bigger radiator is recommended then too!
Old 12-05-2017, 05:18 PM   #221
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I drift in the midwest (cold temperatures), with an NA setup, and spent the steep price for this setup for a reason... if you go hard tracking, no matter the weather or the type of tracking, you'll end up needing an oil cooler
tato.valverde is offline   Reply With Quote
The Following User Says Thank You to tato.valverde For This Useful Post:
CSG Mike (12-05-2017)
Old 12-05-2017, 05:30 PM   #222
BRX
BRX's Avatar
Drives: Toyota GT86
From my experience both NA and FI on a small drifting area (Yas Marina VDA) a session takes about 2-3 minutes. Temperature here almost never drops below 70 degrees and you're lucky if it's in the 80s. I never had oil temp issues when I was NA or on my T518z turbo setup without an oil cooler.
On a longer track sure, but if you're tracking that hard might as well get an oil cooler regardless.
Sent from my Pixel 2 XL using Tapatalk
Old 12-05-2017, 05:46 PM   #223
tato.valverde
If you only drift 2 minutes, sure.. but if you're doing long sessions, no matter if it's hotlapping or waiting in line, you'll overheat
Old 01-01-2018, 10:22 PM   #224
Paulo86
Paulo86's Avatar
Drives: Toyota GT86 euro version
Hi guys ! Just ordered mine !
Does anybody know if there is a 1/8 npt thread in the sandwich plate so i can put my pressure sensor in it ?
Paulo86 is offline   Reply With Quote
Jackson Racing Scion FR-S & Subaru BRZ Dual Radiator/Oil Cooler Jackson Racing Engine, Exhaust, Bolt-Ons 0 04-25-2016 06:35 PM
Jackson Racing Oil Cooler, NA, NEW IN BOX, NEVER INSTALLED. OkieSnuffBox Engine, Exhaust, Bolt-Ons 5 01-12-2016 12:26 PM
Jackson Racing Supercharger and JR Oil Cooler bobsacamenoh Engine, Exhaust, Bolt-Ons 20 12-12-2014 03:00 AM
Jackson Racing oil cooler for NA vs FI ayau Engine, Exhaust, Transmission 1 05-29-2014 12:04 PM
