Old 11-09-2017, 04:49 PM   #15
ILLSMOQ
Drives: 2017 WR BLUE BRZ
ATI SUPER DAMPER #ATI917266 for CTSV to go along with a CTSV accessory drive kit due in today or tomorrow
Some assembly required lol
ILLSMOQ is offline   Reply With Quote
Old 11-09-2017, 04:49 PM   #16
mkivsoopra
Originally Posted by ILLSMOQ View Post
Would love to.... but I’ll be jumping for joy if I even have the headers by then! I still need to ship them to swaintech to be coated...and then finish assembly and then tune...so realistically, I expect to be driving it sometime in Jan/Feb.
Really want to see your car in action too!
This Saturday at Sonoma, or Dec 9 at Laguna Seca!
mkivsoopra is offline   Reply With Quote
Old 11-10-2017, 08:46 PM   #17
ILLSMOQ
Accessory drive system arrived today.
Chevrolet performance ctsv accessory drive system # 19155066
https://www.summitracing.com/parts/n...5066/overview/
This kit comes with everything, accessories, mounting brackets and bolts. I couldn’t find it without the power steering parts so just left them out and @DustinS pointed me to the correct, shorter belt (dacco # 5060560 56” belt) and ribbed pulley (dacco #49021 https://www.summitracing.com/parts/n...5066/overview/ ) needed to delete the power steering components.
Swapped in the ribbed pulley, has to take the sleeve from the smooth pulley, grind it down and shim the ribbed pulley out with a couple washers to get it lined up correctly too.
Old 11-11-2017, 12:55 PM   #18
Lonewolf
Lonewolf's Avatar
Drives: Moped
Super excited to see and hopefully hear the finished product!
Old 11-11-2017, 01:54 PM   #19
ILLSMOQ
Me too and I’m surprised at how hard it is to find more good videos of ls swapped 86’s. I’ll be putting up plenty for sure!
Old 11-13-2017, 10:45 AM   #20
NOHOME
Drives: RAVEN
I also found that there are very few driving videos of these swaps. Looking for some in-car narration!
NOHOME is offline   Reply With Quote
Old 11-13-2017, 11:01 AM   #21
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I have been meaning to get some. Just dropped the ball. Also doesn't help my exhaust is kind of loud and drones. Not sure how it would be picked up by the MIC.
I am excited to see some videos of ILLSMOQ's car. Should be amazing.
Old 11-13-2017, 02:44 PM   #22
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
wow. this is awesome. can't wait for this to be finished. thank you for documenting!
pgranberg11 is offline   Reply With Quote
Old 11-13-2017, 07:05 PM   #23
ILLSMOQ
No problem, I’ll post up the details and part numbers to make it easier for the next guy.
Old 11-14-2017, 07:03 PM   #24
ILLSMOQ
Did a lot of clearanceing today
Pounded in the driver side firewall
Also moved the brass brake line splitter up and away from where the exhaust will go. You can see where the lines where in the pictures above.
Opened up the shifter hole too
Pulled all the radiator stuff and I started planning the air intake. I want the air to come from the front....I think I can work with the available room.
Yanked the foam bumper pad from inbetween the bumper and the crash bar
Thanks again to @DustinS for all the tips
Old 11-15-2017, 01:08 PM   #25
mrg666
pessimistic skeptic
mrg666's Avatar
Your attention to detail is impressive (well ... budget too). I can't wait to see your car running.
Old 11-15-2017, 09:10 PM   #26
ILLSMOQ
had to see how it all fits so today I did the mounts.
Loosely put the motor mounts in
Then the motor
Shot of the back of the motor
Even though I beat the tunnel pretty good the transmission still didn’t fit...had to beat it some more
Actually beat it in all the way to the top for the reverse lock out solenoid
Passenger side
Looks like enough room behind the intake
Hood closes, but it’s close
Moving quick! I’m gonna get stalled out waiting for those headers though.
Pretty happy with the engine and transmission mount kit. Fit really well and clean with good clearance for the AC and heater lines. Good job Vorshlag!
Old 11-16-2017, 06:59 PM   #27
ILLSMOQ
Took the transmission out to clearance a bit more and seal up some holes.
There was some tension on the bolts for the transmission mount. With all the side bracket bolts tight, the mount pulled the tunnel together a bit and when the bolts came out it opened back up throwing off the bolt hole alignment. I couldn’t get the bolts that hold mount bracket together back in.
Took some turnbuckles and pulled the tunnel together some and got the holes close, then slotted the holes on the bracket 1/8” on either side which was enough to be able to easily install the bolts
Currently, I’m able to get the transmission in and out with the engine in place...however I do not have the clutch installed. Once the clutch is in and attached to the engine I’m pretty sure installing the transmission is going to be impossible. It’s looking like the engine will have to be lifted and moved forward from the engine mounts to allow enough room to mate the transmission to it.
Clutch should be here soon and we can find out.
Old 11-16-2017, 08:20 PM   #28
tehShirt
tehShirt's Avatar
Drives: 2014 Subaru Forester
Lots to love in this thread, can't wait to see it all finished.
What are your plans for the exhaust?
tehShirt is offline   Reply With Quote
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Pure Automotive's 2017 Race and Show Schedule Pure Automotive Mid-Atlantic 4 01-21-2017 12:07 PM
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 06:11 PM
Pure automotive pre meet KslayFRZ Mid-Atlantic 0 07-19-2013 11:32 AM
Anybody want to help me pick up my car at Pure Automotive? TyperRspec789 Mid-Atlantic 4 01-31-2013 02:07 PM
