Old 11-08-2017, 05:07 PM   #1
ILLSMOQ
Drives: 2017 WR BLUE BRZ
2017 BRZ VORSHLAG/PURE AUTOMOTIVE LS SWAP
Finally! The swap begins. This is an LSX/T56 swap into a BRZ using Vorshlag Motorsports LS swap Hardware as well as Pure Automotives MOTEC plug and play LS swap computer and wire harness. @Pure Automotive @modernbeat @Fair!
Sold the motor so might as well start.
Transmission crossmember mount was pretty tough to get out
The shifter mount and drive shaft center bearing mount came out super easy. Used an air chisel. Cut them out with the chisel and then chiseled out the left over spot welds
With the tunnel cleaned out, the front subframe is next
Need to remove these engine mount pads from the subframe, grind the welds, smooth it out then bolt up the mounts
Something like this
Need to pull the center console and front seats to start drilling holes. Transmission mount goes here. Mount brackets are located in place with the single bolt from the bottom for the plastic under body covers...should make things easy...easier.
Here is what’s going in. Texas Speed 418ci making somewhere between 600-700 hp. And Vorshlags specified version of the T56 magnum XL
Car already has. A Fullblown Motorsports Ford 8.8 rear end
Vorshlag also supplied the clutch hydraulics which look really nice, the slave cylinder even has a nice coupler to make removing the transmission easier.
Adjustable Tilton clutch master cylinder
Engine mount brackets bolted on
ILLSMOQ is offline   Reply With Quote
Old 11-08-2017, 05:09 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Awesome!!!!
Old 11-08-2017, 05:34 PM   #3
ILLSMOQ
MOTEC plug and play
Old 11-08-2017, 06:42 PM   #4
ILLSMOQ
Cutting off the factory engine mount pads to fit the Vorshlag mounts
Need to clean and Paint but should look something like this
Old 11-08-2017, 07:05 PM   #5
imnotsureaboutbrz
Drives: between cars...
Just awesome!
imnotsureaboutbrz is offline   Reply With Quote
Old 11-09-2017, 09:19 AM   #6
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Thats some good progress! Can't wait to see more.
Old 11-09-2017, 11:22 AM   #7
ILLSMOQ
Yeah man! Thanks to you answering all my questions, saving me a ton of time not having to figure out how so many different parts go together!
Old 11-09-2017, 11:48 AM   #8
JoeeStacks
Drives: Brz
Been waiting for this build! Glad to see it coming along so nicely!
Daily Project: Honda s2000
Track: 707 WHP Turbo Honda Civic EG
Old: Kraftwerks Supercharged Subaru Brz
JoeeStacks is offline   Reply With Quote
Old 11-09-2017, 12:19 PM   #9
amcp1
Drives: frs
This gun b gud.
amcp1 is offline   Reply With Quote
Old 11-09-2017, 12:47 PM   #10
ILLSMOQ
I’ve been waiting too! Haha. Still waiting on the headers, which may be here in December?
Since I sold the motor, I figured now is as good a time as any to get started and at least I can have plenty of time to get all the other details handled exactly the way I want.
Old 11-09-2017, 01:22 PM   #11
servemebeer
CAN Bus Sniffer
I see a lot of folks going with TSP engines, I'm looking at them as well. Can you share your build list/specs for the TSP engine? Also can you share the part number for the T56 Magnum XL? Looking nice so far!
servemebeer is offline   Reply With Quote
Old 11-09-2017, 01:52 PM   #12
ILLSMOQ
The transmission, I’m pretty sure, is some kind of custom order, but here is the tag on the box it came in. It’s chevy in the front and ford in the back as far as I can tell.
This is the engine package I started out with, I changed a few things (intake, cam, skipped the computer and harness since I knew I was doing the motec)
Though mine is a 418 (light overbore I think) and mine has a compression ratio
of 11.25...seems like they’ve changed it up a little.
https://www.texas-speed.com/p-3584-t...y-package.aspx
Texas Speed has a pretty good track record from what I seen online...my other choice was MAST but it would have been another $10k or so.
Old 11-09-2017, 04:15 PM   #13
mkivsoopra
Awesome! Debut at the Dec 86CUP event?
mkivsoopra is offline   Reply With Quote
Old 11-09-2017, 04:32 PM   #14
ILLSMOQ
Would love to.... but I’ll be jumping for joy if I even have the headers by then! I still need to ship them to swaintech to be coated...and then finish assembly and then tune...so realistically, I expect to be driving it sometime in Jan/Feb.
Really want to see your car in action too!
Pure Automotive's MoTeC Plug and Play V8 Swap Thread Pure Automotive Engine Swaps 51 11-25-2017 11:10 AM
Pure Automotive's 2017 Race and Show Schedule Pure Automotive Mid-Atlantic 4 01-21-2017 12:07 PM
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 06:11 PM
Pure automotive pre meet KslayFRZ Mid-Atlantic 0 07-19-2013 11:32 AM
Anybody want to help me pick up my car at Pure Automotive? TyperRspec789 Mid-Atlantic 4 01-31-2013 02:07 PM
