Old 07-03-2012, 10:40 AM   #1
Fugazi
Fugazi's Avatar
Drives: SWP BRZ 6 Speed Limited #888
Noob how often do you check you oil
I checked mine after 1k and. It looked like normal yellowish color to me.
I got nervous after reading the forums of a dealer not putting in transmission fluid.
So do you check yours every week or do many miles?
Fugazi is offline   Reply With Quote
Old 07-03-2012, 10:53 AM   #2
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
I check under my car more often than I check the dip stick. Looking at the oil itself can be helpful when I've blown a gasket, but I honestly don't expect that, so I only look at the dipstick when I change the oil to confirm I've added enough.
b.e is offline   Reply With Quote
Old 07-03-2012, 10:56 AM   #3
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Whenever i want to perv on my motor... In my 6 Litre it was often.... Probably even more so when i attach a snail to the 86.. But as b.e stated above its always good to check under the car.... Obviously if there is any leaks thats where u will find it.... Also before and after ever track day.....
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
Old 07-03-2012, 11:12 AM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
You should check your oil level at every fill-up. Monitoring your oil level can help you catch developing problems if you suddenly see higher consumption levels.
Old 07-03-2012, 12:23 PM   #5
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
I check mine twice a week until about 5000 miles, then once per week.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
Old 07-03-2012, 01:04 PM   #6
Lytheum
Drives: 2013 BRZ Premium 6MT
if its a a new unmodified car under warranty? prolly once a month
once engine/power mods are added i would check more often to make sure nothing is going wrong.
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 07-03-2012, 03:20 PM   #7
10splaya22
Drives: 2009 370z 6MT
I don't check my oil very often to be honest. About once a month. If the car has been modified, I would definitely check it more due to the aftermarket parts potentially causing problems.
10splaya22 is offline   Reply With Quote
Old 07-03-2012, 03:37 PM   #8
DeeezNuuuts83
Drives: 2006 Evo IX SE
I check my oil every time I fill up at the gas station and also after every service.
DeeezNuuuts83 is offline   Reply With Quote
Old 07-03-2012, 03:42 PM   #9
GenkiElite
GenkiElite's Avatar
Drives: 91 Corolla (dd) S14 (daily drifter)
Once a month when its cold.
GenkiElite is offline   Reply With Quote
Old 07-03-2012, 04:40 PM   #10
hav0c
hav0c's Avatar
Drives: WRB BRZ Limited (AT)
Huh. Checked mine and there wasn't a drop of oil in there. Apparently they filled it with unicorn blood instead? Anyone else run into this? Seems to run fine, in any case.
hav0c is offline   Reply With Quote
Old 07-05-2012, 09:21 PM   #11
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
Who got juked with no tranny fluid?
Jared0934 is offline   Reply With Quote
Old 07-06-2012, 05:58 PM   #12
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
I check my oil when im filling up at the gas station
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Noob lowering question. bazguitarman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-21-2012 03:53 PM
Noob question fitcious Cosmetic Modification (Interior/Exterior/Lighting) 2 05-02-2012 11:18 PM
Noob to the forum! Altezza_86 Off-Topic Lounge [WARNING: NO POLITICS] 14 12-19-2011 05:34 PM
